10 inch type r sun with jl amp - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By 1bLwN_AcCoRd
  • 1 Post By oraclem19
Old December 19th, 2013, 05:55 PM   #1
So i have a 10inch type r sub right now with a 650w alpine amp n its not pushing to where i want it so i was going to try out my friends 1000w jl black series amp. Is it even safe to run the jl amp on the type r sub? And i dont plan on blowing up the sub just wanted a high wattage amp for a bit more bass
BHom_ex is offline   Reply With Quote Quick reply to this message
Old December 19th, 2013, 06:27 PM   #2
The Jester
Is it wired as a two ohm or a one ohm? The type r can handle up to 1000 RMS watts. The JL can produce that with the correct wiring.
Old December 19th, 2013, 08:58 PM   #3
Kevin
Nguyen-er's Avatar
Send a message via Skype™ to Nguyen-er
If it is the slash series amp then the it should give out 1200 RMS at whatever ohm you wire your sub down to.
Nguyen-er is offline   Reply With Quote Quick reply to this message
Old December 19th, 2013, 10:30 PM   #4
Its wired to 1ohms right now. I'm afraid my sub will blow since the amp is running at a constant 3ohms. Its not a slash series
Old December 20th, 2013, 02:51 AM   #5
1bLwN_AcCoRd's Avatar
Send a message via AIM to 1bLwN_AcCoRd
couple things, the alpine can handle 1000 watts no problem. second the JL slash amps, they use a special technology, RIPS, that allows them to put out the same wattage over 1.5,2,3,4 ohms. so if your sub is wired to 1 ohms, the amp will not see this constant 3 ohms your mentioning....
also regarding the 1000 watts, there are many factors to those numbers, volume, music type, and voltage. you would need to put volume right before clipping, and have the proper amount of power to reach 1000 watts. Also your music choice will have some play in reaching the 1000 watts....
sorry to ramble on and on
BHom_ex likes this.
1bLwN_AcCoRd is offline   Reply With Quote Quick reply to this message
Old December 20th, 2013, 07:34 AM   #6
The Jester
You would need to test the setup at varying frequencies at the highest volume level before clipping on your stereo, tune the amp to 1000w if not 950 to keep the sub cooler, then confirm with a clipping indicator like the smd-1 to make site the signal is going through clean. I would test this on various songs and test tones before leaving it as a set rig to ensure no clipping. The difference in sound between 800w and 1000w is minimal, the difference in clipping or overheating on the subwoofer is the thin line between max output and a blown speaker however. Make sure to take into account manufacturing defects and whether your car is idling or only powered on when you do this though.
BHom_ex likes this.
Old December 20th, 2013, 09:33 AM   #7
Ok thanks a lot for all the advice guys. I think my sub is 2ohms since I belive my brother bridged the sub. But I will definitely try out what u guys told me
Old December 20th, 2013, 11:43 AM   #8
Super Mod
aprevo15's Avatar
Here's a tip on how to set the level on your amp. If your amp is setup correctly, your sub shouldn't blow the sub unless you max out the volume or something or do something crazy.
How to Adjust Amplifier Gains Using a Digital Multi-Meter - Knowledge Base
The Type R subs can handle good power. I've put a Kicker 1200.1 to a 12: Type R and it handled it really well.
Old December 20th, 2013, 02:22 PM   #9
You should find out how he has it wired. you have 2 options: series (4ohms) or parallel (1ohm).
you should wire it for 4 ohms, because technically the JL amp's minimum impedance is 1.5ohms.
a DMM is a good starting point to set gains, but unless you have a Fluke DMM 120 series or higher your still guessing.
also the OP has a 10" type-r. the 12" type r has a higher power handling capability
Old December 20th, 2013, 02:25 PM   #10
by the way thats a good point in order to increase sound levels by 3db you need double the power... so you wont see a HUGE difference in sound levels.
Old December 20th, 2013, 09:12 PM   #11
The Jester
3db is barely pervicevable, although anytime "db" gain is mentioned it is assumed that more is better. Sometimes it needs to be matched to the rest of the system, especially if you have stock speakers or unamplified door and rear speakers.
We will need to know which Type-R you have though, depending on the year it will be rated for 500, 600, or 1000w. The new ones at 1000w are very durable, the older 600 had some issues when going above 550.
There are also dual 2 and dual 4 ohm configurations, is there any chance you have the box, or can pull the sub out to grab a part number?
Otherwise a picture of the cone and an ohm reading on the leads from the box can help us better determine the model and capabilities of what you have.
Old December 24th, 2013, 08:53 PM   #12
My type r is the old one not a new one. i got it off my brothers friend. but i will look for the part number once i get back in town
