aftermarket headlights - Honda Accord Forum : V6 Performance Accord Forums
Old June 21st, 2014, 03:33 PM   #1
looking to purchase some aftermarket headlights. what are you guy using?
gasmask34 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2014, 04:02 PM   #2
Honda enthusiast
michaellowrider's Avatar
I think most ppl are going retrofit or inspire.
Old June 21st, 2014, 04:22 PM   #3
Depo has always been popular among the aftermarket headlights
atrx is offline   Reply With Quote Quick reply to this message
Old July 21st, 2014, 09:03 AM   #4
Depo and Anzo Lights i have both personally used and they work great
Jasmine6-6 is offline   Reply With Quote Quick reply to this message
Old August 7th, 2014, 01:27 PM   #5
Inspire
mdozard32 is offline   Reply With Quote Quick reply to this message
Old August 30th, 2014, 01:06 PM   #6
Mr. Detail
Scottwax's Avatar
What would be the best to use with HIDs? Don't want to be that guy with the glare from HIDs in a reflector housing.
Old August 30th, 2014, 01:40 PM   #7
Retrofits. Inspire glare because of the flare is on the opposite side since inspires are RHD
Old September 1st, 2014, 09:52 PM   #8
The Jester
Retrofits are fun if you go and replace the low beam slot.
If you replace the high beam spot they're kind of a *****.
Still working on quads.
Old September 3rd, 2014, 07:47 AM   #9
Mr. Detail
Scottwax's Avatar
Are they plug and play or do you need to modify them? HIDs are pretty inexpensive now, want to do this as painlessly as possible. The one thing I really miss from my Maxima is the factory HIDs.
Old September 3rd, 2014, 08:40 AM   #10
doing retrofit is easy. If you can get the lens off and screw in the projector your golden. PM me if you need discount from TRS
easiest kit out there
http://www.theretrofitsource.com/com...-3-kit-h1.html
Old September 3rd, 2014, 07:57 PM   #11
The Jester
Yup^
Might recommend painting the housing though to prevent unnecessary glare.
Old September 26th, 2014, 10:46 AM   #12
AJB
Do these just replace the stock sockets? Is the wiring plug and play for a 2006 accord sedan?
AJB is offline   Reply With Quote Quick reply to this message
Old December 5th, 2014, 05:02 PM   #13
Sosi baklazhani bydlo
LiquidXplosion's Avatar
Send a message via AIM to LiquidXplosion
Oem jdm.
LiquidXplosion is offline   Reply With Quote Quick reply to this message
Old December 20th, 2014, 08:53 AM   #14
Anyone know of any good plug and play headlights? Mine are faded and since I'll be installing fogs in a couple of weeks I wanted to install new headlights. I like the halo spec D's but honestly I feel like they are super cheap. I am looking to spend pretty decent money on a pretty decent headlight.
7.5GenV66MT is offline   Reply With Quote Quick reply to this message
Old December 20th, 2014, 05:19 PM   #15
honda_inspired's Avatar
I have seen the halo spec d's in person before
Any plug-and-play aftermarket headlight featuring "projectors" or "halos" is going to look super cheap like you said. If you want to pull off this look properly you will need to retrofit these components yourself (ref.
Depo makes a great direct replica. Fitment is exact and I have had a pair installed for close to a year now with no sign of premature wear. From my research, spec D is another reliable brand however you will want to go with the direct replica.
I went with this version with the black bezel *purchased from amazon for ~$130 shipped:
Depo 317-1131P-US2
p.s. regularly applying a headlight protectant (I generally just use wax) will help prevent fading/hazing of the lens
current: 2007 Accord Coupe EX-L i4 MT Graphite Pearl
&mpt=[CACHEBUSTER]">
former: 2000 Accord Sedan EX-L i4 MT Gold Metallic
1995 Accord Sedan EX i4 AT Bordeaux Red Pearl
honda_inspired is offline   Reply With Quote Quick reply to this message
Old December 20th, 2014, 05:24 PM   #16
Get a retrofit. Google my screen name and retrofit.
Old December 22nd, 2014, 12:13 PM   #17
I tried to check your stuff out but a lot of the photobucket pics were removed so I couldn't see your work.
Old December 27th, 2014, 12:21 AM   #18
another tip, most aftermarkets eventually have leaking problems and could heat and reseal them before any condensation probs
