EBay Fog Light Help - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By deathangel
  • 1 Post By Mrfr3sh2def
Old September 22nd, 2014, 12:15 PM   #1
EBay Fog Light Help
Hello,
I purchased and installed my new headlights and fog lights this past weekend with HIDs.
It took a lot longer than expected, but I got it all connected.
I was able to get the headlights working with no problem but am unsure how or where to power the fog lights. I am almost 95% positive that I have everything connected correctly but there is 2 cables left and I have no idea where they go.
Any help would be greatly appreciated. I searched the forum and found numerous questions regarding installing fogs but non of them helped please help if you can.
Mrfr3sh2def is offline   Reply With Quote Quick reply to this message
Old September 22nd, 2014, 12:31 PM   #2
one goes to the battery. One needs to be spliced to a trigger that will turn on the fogs ( I.E use the wire that lights up the moon roof when you flip the parking lights on or anything else that lights up while the parking lights are on.)
I can't find me wiring diagram
Old September 22nd, 2014, 10:06 PM   #3
This should help eBay Fog Light Harness - Drive Accord Honda Forums
I extended the red wire and connected it to the battery. I think you might be able to get away with not using the brown connecter? Hope it helps
Mrfr3sh2def likes this.
deathangel is offline   Reply With Quote Quick reply to this message
Old September 23rd, 2014, 09:41 AM   #4
Exactly what I have been looking for, thanks a lot deathangel!
Also, thanks @thisaznboi88 but I was still a bit confused after your response.
Old October 5th, 2014, 08:11 AM   #5
I still am not getting light to the fogs. I tested by connecting to the battery and the switch is getting power but I am still not getting anything to the fogs. Is there a fuse or something that needs to be in place?
Old October 5th, 2014, 11:18 AM   #6
bozos_si's Avatar
does the one you used to go to the battery have a fuse in it? If it doesnt I wouldnt wire it directly to the battery. Good way to get a car fire. The wires that you have for HID's are the plugged in correctly? I know with the HID set I have you can plug them in wrong and they wont work.
Old October 5th, 2014, 04:32 PM   #7
I am pretty positive it does have a fuse. My setup looks just like the pic below
Old October 5th, 2014, 05:40 PM   #8
the problem is the Whiteline goes to the power battery and I think the red one goes to the trigger (aka parking lights) .
Old October 5th, 2014, 06:43 PM   #9
Stay ^
Frostyy's Avatar
For my fogs, I tapped into the wiper motor wire for my trigger. This way, as soon as the car shuts off, my fogs shut off (even if I leave the switch on). I would think the red wire goes to the battery, and the white wire goes to the trigger, but maybe it's the opposite. Try switching them and give it a shot!
Frostyy is offline   Reply With Quote Quick reply to this message
Old October 11th, 2014, 11:35 AM   #10
We got 1 light to come on and then we when we hooked up the 2nd it begins to flicker and goes off. If we swap the lights and ballast it also stays on fine.
Old October 11th, 2014, 08:29 PM   #11
Me and my boy finally got it
Domi_no likes this.
