installing TSX Steering Wheel controls: any help appreciated - Honda Accord Forum : V6 Performance Accord Forums
Old June 2nd, 2015, 04:21 AM   #1
this goes back to an older Thread about interior parts and always wanted these Controls:
Searching for Interior Shifter Trim - Drive Accord Honda Forums
FINALLY got my hands a set w/out having to buy the Steering wheel but...right Side Cruise control is completely different and not usable....for now hopefully
pic of the Controls:
one of the main reasons i want them is mine are faded, i listen to music 24/7 and fairly loud. 1 thing i hate when at a stoplight is someone blaring their music so i almost always turn my music down when stopped and could have contributed to them being this faded
the Cruise Control side still looks new since i rarely use it. please excuse the mess, doing the OEM Navi Install and things down there are a bit hairy
problems: Cruise Control side, didn't try Radio control side yet
1. this may only apply to 2003, but the Cruise Control button for some reason is slanted at an angle on mine a perfectly straight on TSX. i'm thinking this may just be a 03 thing and they may have updated in 04+. TSX Controls were from a 04
2. this Tab that goes behind the Airbag Cover are different sizes and make it impossible to get it behind there w/out shaving it
3. circuit wiring is different, mine has 5 pin/wire blk connector coming from a perfectly shaped plug into the Steering Wheel and the TSX has 3 wire wht connector + a 4 wire white connector
easiest solution would be to swap the body off the OEM to the the new TSX cover but again, doesn't fit without lotta shaving
4. lastly buttons and covers are not interchangeable, best pic but main Cruise Button will not slip in and fit into the Acura one, side by side pic
5. even getting these two Philips screwdriver bolts is not easy
will report back on if the Radio controls is more a direct fit and if i can get in the Cruise Control buttons in. If i had to do it again, i would probably paint the OEM ones
main prob w/painting is masking off the buttons since it is a smaller piece to paint, probably best using a touch up paint of some sort (could possibly try this route)
Old June 2nd, 2015, 08:55 AM   #2
accord325's Avatar
I want the whole steering wheel. GL, sorry I dont have any knowledge to this
Old June 2nd, 2015, 12:16 PM   #3
Okay, from the pictures, the controls you bought are not from an 04 tsx because they come in all silver. I believe both accord (06-07) and tsx (06-08) came with the controls you pictured (silver body, black buttons). The only difference is that the 06+ illuminate while the all silver do not. This could explain the extra wires?? There are threads out there that should help you with the wiring. GL
deathangel is offline   Reply With Quote Quick reply to this message
Old June 4th, 2015, 04:20 AM   #4
thanks, yeah the whole steering is even more extensive since you'll need to swap airbags...that steering looks sick
its actually a goldish/bronze color. almost 100% sure they are from a 2004. the camera flash doesn't show their true color
yeah i'll look into the threads and i don't mind them not illuminating as much as the writing being visible during the day
Old June 10th, 2015, 11:23 PM   #5
Vol, Mode, CH buttons don't work without some soldering so for the time being, got a set of OEM controls and painted them
pinter's tape to mask buttons:
tried w/Gunmetal color but a bit too shiny, will post installed pics but i am not the best painter
Old June 14th, 2015, 01:12 AM   #6
final OEM Honda painted Steering Wheel controls. it brightens up the Interior a bit and will do until i get some time to solder the Acura ones correctly
had an extra set of A/C Vents and decided to paint them as well. didn't come out 100% but i like them so far, may paint different color
Old June 15th, 2015, 01:00 PM   #7
Awesome, I didn't even know this was possible.
Where did you buy your steering wheel?
jdmspec is offline   Reply With Quote Quick reply to this message
Old June 18th, 2015, 05:11 PM   #8
Steering WHEEL was not replaced. the Steering Wheel controls from the TSX involves solder so what i opted for in the mean time is to just paint the OEM ones
if you are good at soldering, it can be done and you could even have the illuminated ones
painting the current ones is a less complicated option
Old June 24th, 2015, 05:00 AM   #9
Could you tell me steereng wheel from rdx bolt on?
sasa is offline   Reply With Quote Quick reply to this message
Old June 24th, 2015, 05:01 AM   #10
I want buy it, or from acura csx (Honda Civic Japan or Russia)
Old June 28th, 2015, 04:50 AM   #11
i'm not 100% sure RDX will fit, they may but make sure wiring is the same, you can cut a small slit if like the TSX ones a bit thicker on backside
the wiring should be similar if not exactly the same assuming you already have steering wheel controls
good luck
