Adding an AMP to 03-04 Accords w/ Navi, no pop sound! - Honda Accord Forum : V6 Performance Accord Forums
Old June 7th, 2004, 09:20 PM   #1
yea it flies!
Xccord's Avatar
Send a message via AIM to Xccord
Lightbulb Adding an AMP to 03-04 Accords w/ Navi, no pop sound!
For those who already have an amplified sub in you Accord w/ Navi and get a "pop" sound when you turn on or off your vehicle or when you turn your radio off, DEI makes an Remote power Adapter which fixes this problem.
Part Number: DEI 55000A
Item uses the speaker signal and converts it to a remote turn on for your amp(s). Using this piece your amp(s) will now turn off with the radio and no "pop" sound will be heard.
For those of you with this problem, you know how anoying this sound gets after awhile.
-Chris
Xccord is offline   Reply With Quote Quick reply to this message
Old June 8th, 2004, 11:30 AM   #2
does this "pop" sound happend with all sub/amp setups?
darsh09 is offline   Reply With Quote Quick reply to this message
Old June 8th, 2004, 12:08 PM   #3
yea it flies!
Xccord's Avatar
yes, it happens because by leaving the factory navigation untouched, you cant grab a Remote turn on signal. So the amp(s) do not turn off with your radio.
Old June 8th, 2004, 05:31 PM   #4
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
i have a 6th gen no navi and i hear that pops sound .. sometimes only tho ..
Old June 8th, 2004, 06:58 PM   #5
yea it flies!
Xccord's Avatar
if you still have your factory radio installed with an amp, try turning off your radio while your car's running and hear what happens...
(Brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr)
Old June 8th, 2004, 10:42 PM   #6
THLA 2009 Bombsquad
nope , no factory radio here .. everything dealing with the sound in my car is aftermarket ..
actually .. if i think about it ....
after i put in my new cd player .. i heard that sound when i turn on the car ..
Old June 11th, 2004, 10:06 PM   #7
DOO
Senior Member
DOO's Avatar
Re: Adding an AMP to 03-04 Accords w/ Navi, no pop sound!
-Chris
can you explain how you added an amp with the factory nav? did you have to take the nav unit out to get to the back of the radio?
DOO is offline   Reply With Quote Quick reply to this message
Old June 11th, 2004, 10:50 PM   #8
sandwiches's Avatar
To add an amp to your factory stereo, you just need to run power from the battery. Then ground to a bolt somewhere in the trunk. Tap the signal from the rear speakers and you're set.. no need to even touch the head unit.
LX V6
Old June 12th, 2004, 01:23 PM   #9
DOO
Senior Member
DOO's Avatar
Great! Now where do I get the remote wire?
Old June 12th, 2004, 09:40 PM   #10
Who's yo daddy?
Mackdaddy's Avatar
Switched +12VDC. I grabbed mine off a feed close to the drivers side fuse panel. No big deal actually.
2010 PMM Accord EX-L V6 Navi Sedan
Mackdaddy is offline   Reply With Quote Quick reply to this message
Old June 13th, 2004, 08:09 AM   #11
yea it flies!
Xccord's Avatar
It's not good to grab your remote from the switched wire in the drivers kick, because your amp wont turn off when your radio's off with the car still running.
'04 Xccord Coupe NAVI and Helicopter rotor
When Accords fly!
Old June 13th, 2004, 08:34 AM   #12
Who's yo daddy?
Mackdaddy's Avatar
Trust me, it works fine. When I drive the radio is on. I have no issues with it the way it is. I wouldn't do it this way if there were any problems. Using a JL 300/2 amp brigged for the sub, BTW.
Old June 14th, 2004, 05:55 AM   #13
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
All you need to do is tap the power antenna wire behind the headunit (yellow/green). Make sure you use a relay. When you turn off your radio, the amp shuts off as well.
--Don
'03 6MT Coupe/Navi with Lots of mods...Sold
'05 G35 Premium/Aero/Sport...
6spdcoupe is offline   Reply With Quote Quick reply to this message
Old June 14th, 2004, 06:58 AM   #14
Send a message via Yahoo to ctorres
Finally I have hope with your suggestion, but...
Hi, some days ago I installed some car-audio components to my '04 Accord Coupe:a subwoofer, 6 speakers (i changed the standard speakers from Honda), an equalizer and an amplifier.
No modifications on Honda original stereo.
All of them from well-known brand names, and the audio is now amazing. The only problem is that when i turn on the car, eject a CD from the 6-cd changer, insert a CD or turn off the car I hear an annoying noise.
The guy who installed all this stuff said that there is a difference of voltage (?) between the subwoofer and the car-stereo (original from Honda). He installed a 'relay' but the noise is still there.
Do anyone has experienced this problem after installing car-audio components like these? What's the solution? Please help me.
- I read the post Adding an AMP to 03-04 Accords, no pop sound - Will this solve my problem?
Thanks a lot guys
ctorres is offline   Reply With Quote Quick reply to this message
Old June 14th, 2004, 07:20 AM   #15
yea it flies!
Xccord's Avatar
you need a remote power adapter, it ties in with your speaker signal to kick on your amps, so there's little or no difference in voltage.
http://www.directed.com/audio/essent...io/default.asp
read audio adapter at bottom of this link
When Accords fly!
Old June 14th, 2004, 07:21 AM   #16
6spdcoupe's Avatar
What sort of "noise" is it?
Old June 14th, 2004, 07:26 AM   #17
6spdcoupe's Avatar
The Accords like all Hondas have no problem retaining an accurate 12volt signal. The only purpose of the relay onto the power antenna lead is to boost the volatge from its originally intended use (power antenna). Can it work without the relay? Probably depending on your setup, but adding a relay is a couple minutes of time anyway.
Just tapping the power antenna wire, is the simpliest most direct route to achieving the desired function (turn on and off with the radio).
--Don
Old June 14th, 2004, 07:28 AM   #18
yea it flies!
Xccord's Avatar
its caused by a difference in voltage backfeeding into your amp from your remote wire. This happens because your amp initially shuts off 2-3 seconds after power is taken away from your remote wire. The Dei 55000A adapter adds a 2-3 sec. delay which corrects this.
When Accords fly!
Old June 14th, 2004, 07:32 AM   #19
yea it flies!
Xccord's Avatar
--Don
true, but in order to tap into this wire, you need to remove the giant radio. With the remote power adapter you dont. Saves alot of time
When Accords fly!
Old June 14th, 2004, 07:41 AM   #20
Thanks Xccord for your advice. I will look for that remote power adapter.
6spdcoupe, the noise is like when you turn off a home stereo without turning down the volume (like a 'pop'). After turned off (and you saw the information in the LED display dissapears) I heard a noise. The same happens when insert or eject a CD.
Before installing the relay, the noise was really loud. After that, the noise was reduced but is still noticeable...and annoying.
Old June 14th, 2004, 07:41 AM   #21
6spdcoupe's Avatar
Very well understood. Ive removed mine so many times now, I just didnt think of it that way.....
--Don
Old June 24th, 2004, 11:22 AM   #22
Lightbulb The last question about the remote power adapter
I already ordered the remote power adapter here in Honda Mexico. Still waiting.
But I have some last doubts about this device. I think that this will solve the turn on/off problem (I won't hear the noise again), but....will this adapter solve the noise I hear when eject or insert a CD?
Thanks guys.
