Paint problems..... I just took the pinstripes off.. - Honda Accord Forum : V6 Performance Accord Forums
Old June 17th, 2004, 07:45 PM   #1
Well.. I decided to take my pin stripes off on my nbp accord coupe that I had for 1 week. I actually scrubbed it too hard to get off the sticky craps and it has scratches.. minor hairline scratches.. i'm just so pissed...
anyway, that's beside the problems. I still see the lines in the sun light at certain angle.. what can I do to remove this??? what can I use to remove scratches???
YESA! 6.5
ex2k4 is offline   Reply With Quote Quick reply to this message
Old June 17th, 2004, 10:13 PM   #2
7th Gen ACcord
xjdMb16a2six's Avatar
hmmmmm try using a polish on it. you should have use rubbing alcohol to take off the sticky stuff.
Old June 17th, 2004, 10:51 PM   #3
you gotta rub to dub!
relentless's Avatar
Yeah, use a polish on it. But I would do a whole detail on the car if your gonna polish the pinstripe area. If you use alcohol, you will strip off everything if you havent waxed it already.
Old June 18th, 2004, 01:15 AM   #4
Get Fuzzy
kpdoughboy's Avatar
Send a message via AIM to kpdoughboy
use WD40 to get the sticky stuff off
&mpt=[CACHEBUSTER]">
kpdoughboy is offline   Reply With Quote Quick reply to this message
Old June 18th, 2004, 01:20 AM   #5
Old Member
Du3ce's Avatar
goo gone
Old June 18th, 2004, 05:35 AM   #6
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Try a polish first. If that doesn't fix it, try a light compound and then the polish. And finish it off with wax.
Old June 18th, 2004, 08:03 AM   #7
what's a good polish to use?
I've been reading the detail forum and many people suggested maquires. It's a brand new car and I don't really see point of doing clay bar and all the steps that involves it...
anyone suggest a good setup?
YESA! 6.5
Old June 18th, 2004, 08:51 AM   #8
03LXV6Guy's Avatar
Personally, I use the S100 products.
So, for a polish, I would use the S100 SEC (Shine Enhancing Cleaner). For scratches, I use Scratch-X first, then S100 SEC, then S100 wax.
Old June 18th, 2004, 09:49 AM   #9
OUTATIME's Avatar
I used turtle wax tar and bug remover with bounty and I got absolutely no scratches while scrubbing.
OUTATIME is offline   Reply With Quote Quick reply to this message
Old June 19th, 2004, 12:07 AM   #10
God of Car
i3igpete's Avatar
Send a message via AIM to i3igpete
NO GOO GONE! it's bad for the clearcoat!
use 3M automotive adhesive remover. it's been designed to be used by shops, and is developed to not harm automotive paints or finishes.
