s2000 rimes.. will they fit accord? - Honda Accord Forum : V6 Performance Accord Forums
Old June 23rd, 2004, 01:39 PM   #1
I was looking at those s2k rims for 2004 and they look damn nice. Will they fit accord? I know s2k has dif. size front and back.. if the lug pattern and everything works.. i was thinking about getting 2 pairs of front or something...
YESA! 6.5
ex2k4 is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2004, 01:46 PM   #2
PMantis24's Avatar
Send a message via AIM to PMantis24
It might work if you find 2 sets of fronts. But, I would only do this if you can find it cheap, it's not worth it if you have to pay dealer prices.
The front rims are 17X7 55+ weigh around 17lbs. Same bolt pattern as the Accord.
I'm not sure about the centerbore though...
PMantis24 is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2004, 02:07 PM   #3
vroom vroom
ctsport's Avatar
I think they look great too!
The rears do have a higher offset but they also are wider too (I think 8inches?) so they might fit the Accord.
I just phoned a local Honda dealer and got qouted for approx. 475/rim. Not too bad imo.
03 SBP J30A4 6MT
Old June 23rd, 2004, 04:11 PM   #4
7th Gen ACcord
xjdMb16a2six's Avatar
^^^ ya the rear are like 8.5
Old June 23rd, 2004, 07:12 PM   #5
was that with the tires or without??
YESA! 6.5
Old June 23rd, 2004, 07:43 PM   #6
God of Car
i3igpete's Avatar
Send a message via AIM to i3igpete
i dont know about you, but if i was going for max cornering prowess (which SHOULD be the only reason anyone upgrades wheel size), why get all skinnys? if you've got the clearance, go for four fat tires.
i used to have 223whp/259wtq. damn theives
Old June 23rd, 2004, 08:36 PM   #7
vroom vroom
ctsport's Avatar
Wider does not neccessarily equate to better handling.
On FF cars, wider rear tires may actually slow you down.
03 SBP J30A4 6MT
Old June 24th, 2004, 12:59 AM   #8
God of Car
i3igpete's Avatar
on the race track, it has been proven that although you may FEEL slower, rest assured that that is not the case. this is because even though you may want neutral handling, it usually comes at the cost of reduced grip to the rear. so although a neutral feeling car may SEEM faster and more balanced, you will have a quicker lap just understeering your way around the track.
regardless, why have all skinnies when you can have all fatties? this way, you will have more cornering ability with the same amount of stable understeer. hell, putting the fatties on front and skinnies on rear would work as well.
Old June 24th, 2004, 08:14 AM   #9
hmm.. .how about i just use whole set of s2000 rims.. will that work? 2 front in front, widers in the back?
YESA! 6.5
Old June 24th, 2004, 11:09 AM   #10
God of Car
i3igpete's Avatar
widers in the front, skinnies in the back. it's not like we have power going to the rear wheels we have to worry about.
Old June 26th, 2004, 10:25 AM   #11
6MT
SlayerGTR's Avatar
i asked about this in a similar post... herez a pic:
Old June 26th, 2004, 10:27 AM   #12
Banned
snikwad's Avatar
Send a message via AIM to snikwad
i think someone should do it.
Old June 26th, 2004, 11:55 PM   #13
6MT
SlayerGTR's Avatar
problem is, there are aftermarket rims that look jus like that, so getting those would be a heck lot cheaper than the s2k ones...
Old June 27th, 2004, 12:56 AM   #14
7th Gen ACcord
^^^^ ya. the S2k wheels are made for s2k not accords.
Old June 27th, 2004, 03:26 AM   #15
Get Fuzzy
kpdoughboy's Avatar
Send a message via AIM to kpdoughboy
i would get knockoffs cuz theyre so expensive. I work at honda so i get dealer net price and they were still $350 a piece.
&mpt=[CACHEBUSTER]">
kpdoughboy is offline   Reply With Quote Quick reply to this message
