Dome and Map light bulb length? - Honda Accord Forum : V6 Performance Accord Forums
Old August 11th, 2004, 09:46 PM   #1
snipes's Avatar
I would like to install Led bulbs.
Probelm is that I found so many on ebay with different lengths, I don't know which to purchase.
I can't check right now because my dad has borrowed the car for a 2 day trip.
Can someone that has change the bulbs, please tell me the length of the bulbs?
Is it 31, 36, 39 or 42mm?
snipes is offline   Reply With Quote Quick reply to this message
Old August 11th, 2004, 10:08 PM   #2
Send a message via AIM to macboi
does the length really matteR? can't you just ask the guy that's sellin those LED if he has size "DE3175" ? if u're talkin about that page that dowell is selling LED, GET IT. ITS FREAKIN SWEET. i have the white and it's amazing.
macboi is offline   Reply With Quote Quick reply to this message
Old August 11th, 2004, 10:16 PM   #3
snipes's Avatar
So you bought a DE3175 and it works, eh? Guess that is what I will buy. Thanks
I wonder if the "31" means 31mm.
I was just con fused cause the FAQ says to replace with a DE3022.
Old August 11th, 2004, 10:19 PM   #4
here snipes, email this guy [email protected] he can definitely help you out, he has the best LED i've seen yet, and he's realliy coool. Talk to him and he'll figure it out for you,
Old August 11th, 2004, 10:21 PM   #5
snipes's Avatar
Thanks bro
Old August 12th, 2004, 07:40 AM   #6
SIN
http://www.v6performance.net/forums/...22&forumid=146
SIN is offline   Reply With Quote Quick reply to this message
Old August 12th, 2004, 01:12 PM   #7
ipribadi's Avatar
They are all 31mm in length.
I had mine all changed to supposedly white xenon filled bulbs, but they're stilll quite yellow to me.
I once tried the super white LEDs but they were just not bright enough and were quite purple.
The two front dome lights would fit longer bulbs with a bit of modification to the metal clips (I have 39mm ones there), the center dome one is harder b/c of space limitation.
Anyone have good results in replacing they're bulbs to xenon white ones?
Mine are only whiter but still has a yellow cast to it.
Old November 21st, 2004, 11:42 AM   #8
Cage Hater
Rather Ride's Avatar
I have an intermittant connection issue in one of my map lights. I don't see any slots for screwdriver access to pry the lenses down and don't want to damage anything in the process. What is the propper procedure for accessing these bulbs in the map light console.
Rather Ride is offline   Reply With Quote Quick reply to this message
Old November 21st, 2004, 11:46 AM   #9
St. Louis!
Kingof3rdinput's Avatar
get a butterknife in there, its alot slimmer than screwdriver, they pop right out.
Old November 21st, 2004, 11:55 AM   #10
Cage Hater
Is there a side that is prefered?
Side that you press
Hinged side
Front of Vehicle
Rear of Vehicle
Thanks for the fast reply
Old November 21st, 2004, 12:24 PM   #11
St. Louis!
i believe, not positive, but think the clips are on the interior side, or "middle"
Old November 21st, 2004, 01:09 PM   #12
St. Louis!
Just remembered this site, this thing has it all. Hope this helps out. just scroll down a bit.
http://www.cardomain.com/memberpage/650229
