wooops electric went wrong....help - Honda Accord Forum : V6 Performance Accord Forums
Old January 29th, 2005, 03:53 AM   #1
hello!this will be my first post....
ne waiz. i was trying to do some diy led work
under my dashboard and i was trying to wire it (power)
from the moonroof switch(which was stupid in the first place)
i grounded it to one of the bolt under the handle
yeah led was working juss fine
i was just trying to change the aiming of the LEDS
and spark and it poped.
now the windows, moonroof dont work.
ingnition and audio, headlight works fine.
and the weird thing is
dash board gauges turns on fine
but once i start the engine, it turns off.
and i get off locked the car, there is yellowish amber light flashing
below the gas meter.
and besides that the biggest problem is
ok i start the engine, trying to back up my car,
the brake is hard like it's locked(like it's before you start engine)
so i can't change my gear, so basically
juss trying to install some leds, got my car not drivable.
my car's 03 honda accord coupe, and
i am probably gonna go to honda dealer with my other car
and get the power window fuse for my underhood fusebox
does anyone have ne idea what went wrong????
xizeroix is offline   Reply With Quote Quick reply to this message
Old January 29th, 2005, 08:14 AM   #2
St. Louis!
Kingof3rdinput's Avatar
sounds like you blew a bunch of fuses maybe? Start checkin all fuses.
Old January 29th, 2005, 09:06 AM   #3
fuses for sure.
Old January 31st, 2005, 08:01 AM   #4
wow...maybe next time u should disconnect the battery before u start messing around with your electric >,<
a504boi is offline   Reply With Quote Quick reply to this message
