Horrible Stock Stereo - Honda Accord Forum : V6 Performance Accord Forums
Old February 6th, 2005, 10:00 AM   #1
7th Gen Accord
BlueV6Accord's Avatar
Send a message via AIM to BlueV6Accord
Angry Horrible Stock Stereo
Does anyone get alot of static when trying to listen to their radio or even ipod in their car? Or is it just mine. I get static on about 3 out of my 6 channels. My old car never got static with these stations. Is there any mod i can do to help this or should I let Honda check it out? Thanks
BlueV6Accord is offline   Reply With Quote Quick reply to this message
Old February 6th, 2005, 10:28 AM   #2
As for static, are you listening to AM, FM, or XM. I have found the reception on Honda (and Acura) radios for AM and particularly FM to be very weak. Don't know if it's the radio's specs or just a poorly designed (or placed) antenna.
lead_sled_dog is offline   Reply With Quote Quick reply to this message
Old February 6th, 2005, 12:05 PM   #3
hmmm i dont have a problem with my radio...maybe ur just in an area where the signal isnt that great....the radio stations in so. cal are pretty good and i can get them practically everywhere cept some mountain areas
adamkim83 is offline   Reply With Quote Quick reply to this message
Old February 6th, 2005, 12:15 PM   #4
the same thing happens to me in my 6th gen. i live in miami so it should come in clear but alot of times i get static
TotallyJDM is offline   Reply With Quote Quick reply to this message
Old February 6th, 2005, 12:28 PM   #5
http://www.circuitcity.com/ssm/Audio...oductDetail.do
this is a fairly universal part i use for the ipod input, i have installed it on my 5th gen, my dads 02 CRV, an 02 stratus, 01 F-150. and an 05 pt cruiser convertible. i started off with the belkin fm transmitter, it sucks and messes up your ipod headphone jack. i got this box and the difference is night and day. you plug the cars antenna feed and plug this box into the headunit, give it a ground and 12v power supply. when you turn it on it cuts off the cars antenna and gives you an RCA audio input straight into the stereo, it sounds amazing and you can keep the stock stereo with it.
ethlar is offline   Reply With Quote Quick reply to this message
Old February 6th, 2005, 01:11 PM   #6
The Poker KING
Yup our stock stereo is a piece of ****.
My iPod is perfect though, but that may be because I got the AUX port for it =)
Old February 23rd, 2005, 02:58 PM   #7
How did you get the AUX port? Where/how does it hook up to the stock Accord stereo?
MysterGoode is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2005, 04:34 PM   #8
St. Louis!
Kingof3rdinput's Avatar
soundgate hond3 (think thats the part #) it hooks up to the bottom of your stock setup, through a special adapter. It is originally designed for the CD-changer function, but will work w/ anything that has a 3.5mm output i.e. ipod, mp3, satellite, etc....
Old February 23rd, 2005, 05:52 PM   #9
6MT
SlayerGTR's Avatar
as for me, i use a iCarPlay (pretty good FM Modulator)
I dont really get any static on it while i hear many complaining about the FM modulators made by apple. Maybe cuz mines 80 bux and those are 30-40. u get what u paid for
But thing is, if u are going to use a FM modulator, i find that you lose a lot of treble, so you'll have to crank it up in ur stereo settings and do TREBLE BOOST in ur ipod if you want clearer sound. Bass out of our stock stereo isn't that bad, prolly cuz our cars lose or w/e, rattles a lot. My friend once asked if I had subs in my car, all i had was stock system and I turned da song up a bit. I would say our system isn't too bad considering its only 120watts, iono if its RMS or max, but it sounds exceptional for da class of cars our accords are in. Not like we're driving BMWs or Lexus
Old February 24th, 2005, 01:09 AM   #10
03ondubs's Avatar
mad static for me on fm radio
03ondubs is offline   Reply With Quote Quick reply to this message
Old February 28th, 2005, 06:36 PM   #11
Zipy
Had much better reception in my GSR with its power mast type antenna. Mast type will beat out wires in the glass every time.
Zipy is offline   Reply With Quote Quick reply to this message
Old February 28th, 2005, 07:01 PM   #12
ex scientia vera
kramer2k's Avatar
My FM reception is substandard as well. I also believe my location contributes to the problem. I'm between 3 different areas.
Old March 1st, 2005, 05:01 PM   #13
Jackthewack's Avatar
I dont listen to the radio, the radio sucks balls.
Jackthewack is offline   Reply With Quote Quick reply to this message
