Aftermarket XMers - Honda Accord Forum : V6 Performance Accord Forums
Old February 13th, 2005, 10:49 AM   #1
Aftermarket XMers
I just got XM for my honda (delphi skyfi 2 unit). If you have XM, where did you mount your unit? If you have pics, it would be great.
Thanks for the help!
Dcarp is offline   Reply With Quote Quick reply to this message
Old February 13th, 2005, 01:00 PM   #2
I put my commander in the ashtray.
The Skyfi is a little bigger so if I had to do it, I'd put it in the cubby. Good luck!
Old February 13th, 2005, 02:59 PM   #3
I tried to put it in the ashtray, but no luck its too big. Right now its leaned against a cigar box inside the cubby. I'm planning on building a bracket to push the XM unit as far to the front of the cubby as I can. (any DIY's on pulling the cubby?)
Thanks again for the help.
Old February 13th, 2005, 03:05 PM   #4
St. Louis!
Kingof3rdinput's Avatar
http://www.cardomain.com/memberpage/650229
Old February 13th, 2005, 08:38 PM   #5
I fabricated a custom bracket from aluminum that is sort of shaped like a Z. The cubby is easy to remove. I think (but I don't really remember exactly) you have to pop the trim from around the shifter to get to the screws to remove the coin pocket and power port. Once the coin pocket is out, you can get to the screws that hold in the cubby.
jbbrann is offline   Reply With Quote Quick reply to this message
Old February 14th, 2005, 04:57 PM   #6
pomhonda's Avatar
Send a message via AIM to pomhonda
does anyone know which satelite radio company is better, ie..sirius or xm?
pomhonda is offline   Reply With Quote Quick reply to this message
