Amp Mounting (No clue where to do it) - Honda Accord Forum : V6 Performance Accord Forums
Old February 16th, 2005, 01:27 PM   #1
Jackthewack's Avatar
Hey guys, i recently just put 2 amps in my accord coupe. I had some major problems with mounting them. They dont seem to fit anywhere, so i just put some heavy duty velcrow with adehesive on the bottom of the amps and put them as far back in the trunk as possible, the subs sit infront of them. Sorry i dont have any pics. Does any one know of any good spots i might have missed, No BACK SEAT MOUNTING, i dont like how it looks, besides they probably dont fit on them either. I was actually thinking of putting some shelves together and carpet them and then use those, any one got oppinions? I also have xbox in there so i need a spot for that aswell. Also if i were to put in the shelves i wouldnt be able to screw into the floor of the trunk but how about the side walls? Ive been drawing up some things and i think it would look best if i mounted the back of the shelves to the walls of the trunk then the front of the shelves would have legs, maybe some sorta slant on the shelves. thanx guys
Jackthewack is offline   Reply With Quote Quick reply to this message
Old February 16th, 2005, 01:31 PM   #2
bryan <3's bomex
mastadulog's Avatar
how about the area for a spare tire
Old February 16th, 2005, 01:32 PM   #3
I need the spare..... or atleast am better off with it.
Old February 16th, 2005, 01:43 PM   #4
Raddy21's Avatar
i have mine on my seatback but if you dont like it you will have to do a custom setup and since you are leaving your spare in, you can kiss your truck space bye bye, but look around at some pics in the meantime, b.c im sure your not the only one with the dilemma
http://www.v6performance.net/forums/...ght=tuning+amp
Old February 16th, 2005, 01:46 PM   #5
How about a wedge that backs up to the back seat and the amps mounted to that?
Old February 16th, 2005, 04:38 PM   #6
constantly in pursuit
hammer03's Avatar
I have two amps, one under the passenger seat, one under he driver seat. i like em. younever seene m unless you sit in the back seat, but then again, i never have anyone in the back seat, so its not like they step on em or something... no room behind my seats cause i have em all the way back haha. pics here: http://www.uweb.ucsb.edu/~dhamman/pics/ numbers 8 and 9
Old February 16th, 2005, 06:03 PM   #7
I mounted mine on the side in my sedan...just on a piece of MDF I had lying around...
graphite28 is offline   Reply With Quote Quick reply to this message
Old February 16th, 2005, 06:05 PM   #8
Nice amp I should work on doing something similar.
Old February 16th, 2005, 06:13 PM   #9
ex scientia vera
kramer2k's Avatar
That's how I have mine. Works great for me too!
Old February 16th, 2005, 07:57 PM   #10
St. Louis!
Kingof3rdinput's Avatar
mount it to the box itself
Old February 16th, 2005, 09:05 PM   #11
It might not be such a good idea to mount it to the box. The amp will get messed up most likely. I like what graphit28 did, will that work for both sides? cause i have to mount 2 amps. Also im assuming you used screws for the mounting of the amp wall to the car right? if i were to do it to the other side like that will i hit the gas line leading to the tank?
Old February 16th, 2005, 09:36 PM   #12
I actually used plumber's strap that's screwed into the car, and then into the board. That way, I can actually lift up the amp, so it's like it's on hinges.
As for mounting the amp to the sub box, I didn't like that because I remove my sub box when I go camping, skiing etc. And if the amp was on there, then I'd have to remove all the power wires, ground, remote which would could cause a shock. I'd be too lazy to remove the fuse. WIth the amp separate, all I have to do is remove the quick release speaker wires which I installed on my custom box.
Old February 16th, 2005, 09:43 PM   #13
bryan <3's bomex
mastadulog's Avatar
mines mounted to the box without any big problems so far, well except possibility of theft. but im debating whether or not i should put it in the backseat, but if i do then ill block out the ski opening which i open up in the summer to give the amp some ventilation room
Old February 16th, 2005, 09:45 PM   #14
hammer03's Avatar
^^ thats why i got a single box for each of my 12's. if i need room, i take one out, without losing all my bass. if i need all the trunk space, which i havent yet, i can take em both out.
Old February 17th, 2005, 12:44 PM   #15
well i have 3 jl 10" subs in the custom jl box and 2 amps phoenix gold amps that are both bigger then 1 foot long and about 1 foot wide. so i think im gonna build a little shelf to sit above the subs. It looks like it will work if i just screw into the trunk sideing will it fall out? or will i drill into anything, considering i have enough room with out actually drilling out the other side, but will i hit any gas lines leading to the trunk u know on the left side, cause the gas cap is right there.?
Old February 17th, 2005, 01:07 PM   #16
i was just lookin around my trunk and just realized i cant mount a shelf back there, THE TRUNK ARMS SWING DOWN. So back to the drawing board.
Old February 19th, 2005, 03:55 PM   #17
Ok i did it! i mounted the four channel amp to the top of the trunk, i used 3 inch screws with spacers to "hang" the amp nice and tight, it was hard because i had to find the right spots to drill the holes, alot of **** moves up there so u have to watch out u have clearence, for the sub amp i mounted it on the left side of the trunk right under the tail light compartment, and i wired through the tail liight to make it look neat. ill have pics as soon i can find my camera.
Old February 19th, 2005, 04:04 PM   #18
Tofu Delivery Boy
The_Tofu_Shop's Avatar
Send a message via AIM to The_Tofu_Shop
i have one mounted to the top of my box and one on the back seat. it all will change tho, cause i wanna re do my system with full fiberglass and all
Andy 2
SoCal Pride
G-Spec Points: 40
The_Tofu_Shop is offline   Reply With Quote Quick reply to this message
