Really stupid question - Honda Accord Forum : V6 Performance Accord Forums
Old February 19th, 2005, 10:35 AM   #1
Ok...one question. Is the easiest way to change your headlights bulb (low beam) is to go through the tire well? My passenger side burnt out and I'm not sure if its easier to go under the hood or through the well....
Thanks.
ruelas33 is offline   Reply With Quote Quick reply to this message
Old February 19th, 2005, 11:13 AM   #2
6MT
SlayerGTR's Avatar
u jus open hood
and look behind the headlights and pull it out
its kinda like pulling a plug outta a wall
Old February 19th, 2005, 03:55 PM   #3
Tofu Delivery Boy
The_Tofu_Shop's Avatar
Send a message via AIM to The_Tofu_Shop
pop the hood find the bulb.
you may have to twist a bit before pulling out the bulb
easy as pie.
Andy 2
SoCal Pride
G-Spec Points: 40
The_Tofu_Shop is offline   Reply With Quote Quick reply to this message
Old February 19th, 2005, 06:22 PM   #4
7th Gen ACcord
xjdMb16a2six's Avatar
the passenger side you can just change it thru the hood. unless you got some fat arms.
Old February 19th, 2005, 07:11 PM   #5
Yes, the passenger one is easy to get to through the engine bay. The driver's side is a major major pain in the ass unless you've removed the intake resonator / have an intake. I would just remove the battery to get to the driver's side low beam.
And SlayerGTR,
"u jus open hood
its kinda like pulling a plug outta a wall"
Sorry dude, you've obviously never changed the low beams on this car.. I wouldn't go pulling everything out like pulling a plug "outta a wall".
