Linking neons? - Honda Accord Forum : V6 Performance Accord Forums
Old February 25th, 2005, 01:41 PM   #1
Jackthewack's Avatar
Linking neons?
I need help with my neons, how do u link them to gether. I have a 20 " in there right now but i want to tap into that power line to link up two 5" neons. how does the wire pattern go? thnx
Jackthewack is offline   Reply With Quote Quick reply to this message
Old February 26th, 2005, 12:39 PM   #2
most likely u wont' connect it by series. Go Parallel.
Power souce ===> neon #1
===> neon #2
===> neon #3
all u really have to do is put each positive wire to your power source (Where that may be for your current 20inch neon). nothing complicated, and just use the same negative u have currently on your 20inch neon. You'll probably need longer wiring maybe to get the wires to reach your power source.
Old February 26th, 2005, 03:46 PM   #3
You can do that, or splise the wire coming from the power source. Connect all three powers together and same for ground. Then connect them with an adapter and clap it down. Please do not use electrical tape to hold them together.
And make sure you do not put a ground with a positive wire. Wires are usually marked with red /black lines, or + /-.
Devil-Dog is offline   Reply With Quote Quick reply to this message
Old February 27th, 2005, 02:09 PM   #4
Normaly if the wires were colored i would have no problem but i guess street glow thinks im psychic or sumthing, thanks guys, i found out which one was positive by opening up the cig adapter, and looking for which wire conected to the metalic tip. The - ground is conected to the 2 side clips. That is correct right? If so then i got it right. The light blue wire is positive and the darker looking copper wire is ground. Just had to make sure befor i hooked them up.
