where is the firewall? - Honda Accord Forum : V6 Performance Accord Forums
Old February 26th, 2005, 01:11 PM   #1
pics if possible?
ziggyziggy is offline   Reply With Quote Quick reply to this message
Old February 26th, 2005, 02:24 PM   #2
vroom vroom
ctsport's Avatar
Lol
Old February 26th, 2005, 02:42 PM   #3
Old Member
Du3ce's Avatar
ha ha what are you trying to install, system or something?
Old February 26th, 2005, 04:19 PM   #4
8th World Wonder
GotVtec's Avatar
inbetween your engine and cockpit.
GotVtec is offline   Reply With Quote Quick reply to this message
Old February 26th, 2005, 06:22 PM   #5
im trying to install an amp and sub so i need to run power and ground back to battery thru firewall.
Old February 26th, 2005, 08:24 PM   #6
Tofu Delivery Boy
The_Tofu_Shop's Avatar
Send a message via AIM to The_Tofu_Shop
.....i dont know if you shoudl be installing a sub and amp if you dont know where the firewall is...
but anyways, the firewall is the metal barrier in between the cabin of the car and the engine compartment. If you look in the drivers foorwell... just keep going forward past the pedals, thats the firewall..
you will probably have to drill to get in there. be careful though, you dont wanna drill into anything else...
Andy 2
SoCal Pride
G-Spec Points: 40
The_Tofu_Shop is offline   Reply With Quote Quick reply to this message
Old February 26th, 2005, 08:31 PM   #7
CeRtiFiEd PimP
re
Lol
Old February 26th, 2005, 08:34 PM   #8
Accord_V6_400m's Avatar
Its the same thing that protects you from hackers lol
Old February 26th, 2005, 08:40 PM   #9
7yr / 120K
Celestion's Avatar
Mine is sitting on my CPU..... its a linksys!!!
But seriously.... if you can't find a way through the firewall.... or even the firewall itself, you should NOT be putting a system in the car! Seek professional help QUIK
Celestion is offline   Reply With Quote Quick reply to this message
Old February 26th, 2005, 08:59 PM   #10
original member!
Nittanys1's Avatar
Old February 26th, 2005, 09:05 PM   #11
Formerly VTEC-v6!
N54TT's Avatar
Look behing the pedals towards the left, see if theres a foam pat cutout. There's often a pre-drilled hole behind a foam pad you just gotta pull off
If not, check the other side of the metal before you drill, nothing more fun than a hole in your master cylinder
Old February 27th, 2005, 03:58 AM   #12
DO NOT CONNECT THE AMP GROUND TO THE BATTERY!!!!!
Get your boom-boom installed by a pro. No offense, but I can tell from your posts that you have no idea of what your getting into.
drunken6speed is offline   Reply With Quote Quick reply to this message
Old February 27th, 2005, 12:02 PM   #13
The amp groundwire isn't even long enough to connect to the battery even if you wanted to. You would have to have a custom length cable for that but that is still a no-no The only wire you want to connect to the battery is the amp power cable, which is red. Ground wire is a brownish color, remote wire is blue.
Old February 27th, 2005, 08:45 PM   #14
JDM FTW!!!11one!
JBLAccord's Avatar
well, if your still willing to trythe install yourself, which i really would not advise doing unless you know your stuff..there is a hole in the firewall on the passengar side op top of there the AC drains. i ran my power cable through here about 8 months ago and no problems. just be sure to use a rubber grommet and some silicone. also make sure that you put the ac drain pipe back in place!
JBLAccord is offline   Reply With Quote Quick reply to this message
Old February 27th, 2005, 08:50 PM   #15
OMG dude you shouldnt be installing a system, hehe.
6SpeedMaster is offline   Reply With Quote Quick reply to this message
Old February 27th, 2005, 09:01 PM   #16
Old Member
Du3ce's Avatar
he hasnt responded yet, maybe he electrecuted himself ha ha just messing with you man..
Old February 27th, 2005, 09:18 PM   #17
Make sure you get good wiring too, a kid in Auto-Mechanics didn't and blew out all the wiring in his sound system, white smoke everwhere !
Old February 27th, 2005, 10:27 PM   #18
i dont kow what is so funny about this thread? i ask for where is the firewall, not what. i have installed an amp and sub in my previous car, a civic. i just dont know where i should run the power cable thru. some cars have the firewall opening on the passenger's side, some on the driver's side. i dont wanna drill my own hole and just use the pre-drilled hole. i just dont know where it is because i never searched for it. thanks for all of u that actually posted useful replies. btw, the ground wire of the amp should be connected to an unpainted metallic surface in the trunk and should be no longer than 1 foot.
Old February 27th, 2005, 10:37 PM   #19
Formerly VTEC-v6!
N54TT's Avatar
It's funny because you ask where the firewall is...the firewall is the entire barrier between the engine bay and cabin.
It's funny because you reference running a ground wire back to the battery, yet now you claim otherwise...
It's funny because it seems you are attempting an install that given your display of technical knowledge, may be over your head.
You must also remember that all of us on this board are die hard car nuts and think it's funny that somebody doesn't know what the firewall is...
And I wouldn't have mentioned that you previously had a civic, these guys are gonna bash on you for that too
Old February 27th, 2005, 10:37 PM   #20
original member!
Nittanys1's Avatar
i feel bad....I'm sorry i just couldnt pass that by.....
I have used the hold thats about the brake pedal....and for my ground I used the seatbelt mounts in the back....
where are you gonna mount the amp at?
Old February 28th, 2005, 07:48 AM   #21
"Stupid is as stupid does" -I think we all know who said that
2001 Pitboss is offline   Reply With Quote Quick reply to this message
Old February 28th, 2005, 10:26 AM   #22
7yr / 120K
Celestion's Avatar
Originally Posted by ziggyziggy
pics if possible?
Old February 28th, 2005, 10:47 AM   #23
Your right its not funny, umm never mind that question was pretty damn funny
Old February 28th, 2005, 10:48 AM   #24
Thats like askiing wheres my hood, but u gotta undersatnd its all in fun. Thanks for the laugh.
Old February 28th, 2005, 10:52 AM   #25
Yeah it was a great question to laugh at next time maybe he wont be so vague (that is if he really knew what a firewall was lol ;p).
Old March 3rd, 2005, 05:06 PM   #26
so is it hard to push another wire thru the hole behind the pedals? do i need to use a wire hanger to push another wire thru? btw, it was an error when i referred to running the ground wire back.
Old March 3rd, 2005, 05:49 PM   #27
7th Gen ACcord
xjdMb16a2six's Avatar
lol give this guy a break. anyways looks like you got a auto so the firewall hole should be on top of the dummy pedal. your going to have to remove the panel under the steering to actually see it. there is to screws on the right side and left side of the panel. its not really hard to take off if you take your time. but yea once you take off the panel there should be a rubber thing with wires going thru it. just to use a wire hanger to get the wire thru the engine. if your using a stock headunit you should wire the on/off wire to the ACC fuse. just wrap it aroound on one of the pin on the fuse and stick it back in. for the ground you should ground it in the trunk. if you take off the cover of the spare wire cover there will be a ground there so just use that.
BTW remember to remove the neg from the battery before you hook up the 12v wire. and make sure you got the radio code
Old March 4th, 2005, 05:13 PM   #28
thanks a bunch, exactly what i was looking for
Old March 4th, 2005, 05:18 PM   #29
FREUNDE MIT DEM TEUFEL
jimmyrecluse's Avatar
I say go for it. Trial and error is the best way to learn.
jimmyrecluse is offline   Reply With Quote Quick reply to this message
Old March 4th, 2005, 08:47 PM   #30
7th Gen ACcord
np man. if you need more help just IM on at k247thgenaccord.
and ya like jimmyrecluse said just do it. when i installed my system i have never done it before and i did it all by myself. anyways once you get thru the firewall everything else is easy.
