Removing the rubber protective trim junk... - Honda Accord Forum : V6 Performance Accord Forums
Old March 13th, 2005, 05:05 PM   #1
_
0430Steve's Avatar
So I want to take off my protective trim around the wheel well and the side of the doors. is there much to this? any advice? will I need some cleaner/stick remover or anything? should I worry about paint? anyone else taken off these strips? I want to take off the medflaps too. any info would be appreciated. These are the 3 things I want to remove.
Old March 13th, 2005, 06:02 PM   #2
odk
odk's Avatar
With respect to the splash gaurds, they are easily removed just replace the screws/bolts. The only problem could be some minor paint blemishes where the edge of the gaurd contacts the paint. These may be correctable with Scratch-X or they may require professional attention.
odk is offline   Reply With Quote Quick reply to this message
Old March 13th, 2005, 06:10 PM   #3
Steve,
The previous post is right, scratch-ex will remove any scratches. As for adhesive that is left over, us WD-40. It will remove any adhesive left over, and will NOT harm the paint.
Chuck
cbberry is offline   Reply With Quote Quick reply to this message
Old March 13th, 2005, 07:09 PM   #4
original member!
Nittanys1's Avatar
dont use WD-40...use goo gone....
Old March 13th, 2005, 07:26 PM   #5
_
0430Steve's Avatar
alrighty. but anything I need to know before i try. or am I just going to go out there and pull it off and then just get the goo off. do I need to remove anything to get these strips off?
has anyone done this?
Old March 14th, 2005, 12:37 PM   #6
I Jumped Off Da Bandwagon
Hongda's Avatar
You can just peel it off with you fingers. A hair dryer might be useful also.
