sound gate ? - Honda Accord Forum : V6 Performance Accord Forums
Old March 16th, 2005, 10:11 PM   #1
sound gate ?
i jus brought a soundgate adapter .....one qiuestion....since im using the sound gate ........how am i surpose to power up the head unit( i bought a sony aftermarket mp3 headunit) i need help with this
any comments and advices is appreciate.
thank you kim
bogoshipyo is offline   Reply With Quote Quick reply to this message
Old March 16th, 2005, 10:13 PM   #2
aceofspades626's Avatar
So, you're installing the sony unit in addition to the stock HU?
Old March 17th, 2005, 04:45 AM   #3
accord03's Avatar
ummm if ur getting a new headunit..then u bought the wrong thing....u need to buy a dash kit with a wire harness...u wire up the harness to the new headunit...and then u hook it up to ur car...u dont use ur stock headunit after u get a new one.
RIP
Hello Prius.
old sn: AwSoMNaMjA
Old March 17th, 2005, 06:58 AM   #4
currently i am using the indash kit with the wiring harness......i thought if i install it with the sound gate i can use the controls on the steering wheels.......and one other thing , eventho i install it with the wiring harness......my radio doesnt work.....anyone can help me with that too ?
Old March 17th, 2005, 07:17 AM   #5
I think you got an extra piece partner. The soundgate will pipe your steering wheel controls to a Sony Disc changer, but a headunit uses the wiring harness to connect to the car replacing the stock stereo, the soundgate connects to the existing stock stereo.
Unless I'm wrong, and someone made an adapter to do so I don't think you can use your steering wheel control on an aftermarket Head Unit.
Orange_Lazarus is offline   Reply With Quote Quick reply to this message
Old March 17th, 2005, 09:44 AM   #6
you gotta tell us more about this "soundgate" you have. Do you have a part number? Did you buy it to use the steering wheel controls with the sony head unit? Most of the peices I've seen like that have an IR transmitter and require the head unit to have a IR remote- maybe thats what you're trying to do? tell us more...
PurdyLXV6 is offline   Reply With Quote Quick reply to this message
Old March 17th, 2005, 02:37 PM   #7
accord03's Avatar
wht he is talkin about it hookig up the heaunit to the stock headunit...so he can control the stock volume with the steering controls...its possible to do...u just nneed to get power from another source....maybe tap into the cigerette lighter...ground to the chasis..and for the remote just tap into the stock harness. but do u need it that bad? sound quality is not going to be as good as just the sony headunit.
RIP
Hello Prius.
old sn: AwSoMNaMjA
Old March 17th, 2005, 04:53 PM   #8
St. Louis!
Kingof3rdinput's Avatar
You bought extra parts is right. If you want to run the Sony mp3, AND the existing radio, you can, but the steering wheel controls will be absent. You can power it off whatever you want, but the quality will lack, going through the aux input.
Old March 17th, 2005, 04:59 PM   #9
6MT
SlayerGTR's Avatar
what if u wanted to have 2 systems, u kno when u walk in some those car audio shops and in their sound rooms, u can press a button and it turns on one system etc...
that be pretty k0o, cuz u could use stock system sometimes, den if u get tired u can flip a switch and use the aftermarket system
Old March 17th, 2005, 05:25 PM   #10
St. Louis!
i think there are splitters for wire harnesses.
Old March 17th, 2005, 09:57 PM   #11
wellz right now im running on the mp3 unit.........one major problem with that is that i cant play radio
2nd....i brought the sound gate thinkin that it can help me so i can use the controls on the steering wheel
3rd..... connecting two unit together, because of the aux the stock unit offer.......i was thinking that if u can connect a factory honda mp3 unit on the bottom why cant u do it with as aftermarket ?.....o yeah like i mention i try....it goes thur and the aux works but i dunno how to power up the unit.....maybe i need something from the honda dealership ??
so now im stuck with either stock unit with radio ........or mp3 with no radio and no steering controls
the soundgate i got is SNHOND3 - http://store.yahoo.com/logjam/sounsnhond3.html
p.s.......will this help ? http://www.sjgreatdeals.com/sgtdockhond1v2.html
Old March 17th, 2005, 10:17 PM   #12
St. Louis!
you can power the 2nd unit from any power source, use the lighter. You'll have to hardwire it in. Best Buy or anywhere charges maybe 30 for it, if you cant DIY.
Old March 18th, 2005, 01:38 AM   #13
accord03's Avatar
well ur radio aint working cause ur not puttin in the stock antenna...the antenna wire is one wire...so its going to go into the stock radio or the aftermarket...one or the other....
if u need mp3 with stock controls the best thing is just get the stock mp3 player...simple as that...the way u are doing it is beating around the bush....too many factors to over come and just not worth it in the end. either stick with aftermarket or stock with the mp3 upgrade. i would get aftermarket if i was u.
RIP
Hello Prius.
old sn: AwSoMNaMjA
Old March 18th, 2005, 04:10 AM   #14
i know what u mean, thats why im staying with my mp3.....thanks a lot guys.....ill probably sell out the soundgate and go to a local install and jus get it done for 30 buckz den getting confusing DIY....)o=`,
k ! M c |h !
