shaving the emblem leaves paint disfigured.. - Honda Accord Forum : V6 Performance Accord Forums
Old March 19th, 2005, 06:10 PM   #1
Banned By *********s
Send a message via AIM to Jkvan87
Angry shaving the emblem leaves paint disfigured..
where the adhesive was on... it leaves some sort of smeared paint... if you look at it from 2-3 ft, you can see the outline of the accord and v6 symbol. do i need to buff or do some sort of treatment with it?
Jkvan87 is offline   Reply With Quote Quick reply to this message
Old March 19th, 2005, 06:20 PM   #2
Send a message via AIM to gabedabomb
I got the same thing. I think it's cuz the adhesive ate into the clearcoat.
Don't stand so close when you look at it.
gabedabomb is offline   Reply With Quote Quick reply to this message
Old March 19th, 2005, 06:26 PM   #3
repaint it?
kwanzor is offline   Reply With Quote Quick reply to this message
Old March 19th, 2005, 06:28 PM   #4
there is nothing you can do about it...because the paint is discolored from the rest due to the adhesive...you can usually use Paint Cleaner...or any kind of micro abrasive cleaner to help get rid of it...but other than that there is nothing you cna really do get rid of it completely
Wht2kAccord is offline   Reply With Quote Quick reply to this message
Old March 19th, 2005, 06:54 PM   #5
ic...gay...
Old March 20th, 2005, 01:22 AM   #6
polish?
Old March 20th, 2005, 03:08 AM   #7
I'll bet no one will notice except for you and the people you tell it to before you show them. I'd just stop thinking about it, if you can. A polish/abrasive could just lead to bigger problems. Good luck though.,
MysterGoode is offline   Reply With Quote Quick reply to this message
Old March 20th, 2005, 05:42 AM   #8
uhh..i had that on my car but then i rubbed it out with my finger...lol...it jus more of that adhesive crap
a504boi is offline   Reply With Quote Quick reply to this message
Old March 20th, 2005, 12:58 PM   #9
JDM FTW!!!11one!
JBLAccord's Avatar
same thing happened to me when i shaved the rear emblems. i tried waxing and buffing it but it didnt help much. the clearcoat where the badges used to be is completely flaked off. just curios if anyone else has had any luck with this problem?
JBLAccord is offline   Reply With Quote Quick reply to this message
Old March 20th, 2005, 01:18 PM   #10
say hello to angels..
BlaCCord Guy's Avatar
it'll even out after a while...trust me you won't notice it
it worked for my ACCORD and V6 emblems...i'm not sure bout the H's though
Old March 20th, 2005, 05:28 PM   #11
♠ 2009 Pontiac Vibe GT ♠
lowincash's Avatar
Send a message via AIM to lowincash Send a message via MSN to lowincash
i took my emblem out a long time ago and it left like a tan on it or something...i still see the word "accord" and the "v6" logo on it lol
lowincash is offline   Reply With Quote Quick reply to this message
Old March 20th, 2005, 05:49 PM   #12
i guess it depends what color car you have
my black coupe doesn't show anything anymore...it did at first though
Old March 20th, 2005, 05:59 PM   #13
Claybaring the section might remove it. Search here for more info.
Old March 21st, 2005, 12:11 AM   #14
i did a search and find nothing about this problem
RP V6 coupe is offline   Reply With Quote Quick reply to this message
Old March 21st, 2005, 12:19 AM   #15
1bLwN_AcCoRd's Avatar
Send a message via AIM to 1bLwN_AcCoRd
i used meguiars clear coat and wax, and buffed it out with a orbital make sure you do it in the shade... my buddy did it in the sun and it messes it up....
1bLwN_AcCoRd is offline   Reply With Quote Quick reply to this message
Old March 21st, 2005, 08:44 AM   #16
i guess he should read the direction before doing the waxing? hahahahha
i guess i can try that
Old March 26th, 2005, 01:33 PM   #17
peshford55's Avatar
Send a message via AIM to peshford55
I used scratch X then i used meguires 3 stage, and it came out just fine. You cant tell where it was...
peshford55 is offline   Reply With Quote Quick reply to this message
Old March 27th, 2005, 11:20 AM   #18
My "ACCORD" and "V6" emblems came off fine. My HFP badge left its mark. Not too noticeable. I'm not going to bother fixing it.
Supernova is offline   Reply With Quote Quick reply to this message
Old March 27th, 2005, 02:36 PM   #19
My emblems took paint off with them...I think the paint on my car wasn't completely dry when they put the emblems on...which were put on crooked, I should add. I ended up having to get that area re-painted.
It sucked but the guy I took it to basically did it for free since I was having other work done (I was sideswiped while parked).
Scubaman3D is offline   Reply With Quote Quick reply to this message
Old March 28th, 2005, 04:07 PM   #20
Send a message via AIM to littodevil
This is what happens guys. You know how you get tan lines and etc because clothing are covering part of your body but not others? That's exactly what happens to the area behind the emblem. That's one thing, the other thing is the achseive used is strong enough to the point where if your not careful, you'll start cracking the urathane clear coat but it shouldn't happen. The urathane clear coat is a pretty strong layer that won't typically come off compared to the color paint underneith it.
The color difference is because the rest of the paint around it got exposed to the sun and that's why you can't have a body shop color match something without the vehicle actualy being there. The body shop could use their colormatching code formula from PPG or Stando and do it perfectly to the very .01 oz and it still might not come out perfect as the rest of the color on your car, unless the car was fresh from the factory.
My father owns an auto body collission shop as well as an auto specialist shop so that's how I learn my info hehe.
Best Regards,
Larry
HID Performance
(650) 703-0911
[email protected]
littodevil is offline   Reply With Quote Quick reply to this message
