4 channel amp install - Honda Accord Forum : V6 Performance Accord Forums
Old March 27th, 2005, 04:05 PM   #1
I'm gonna be installing a 4 channel amp soon, just wondering if anyone is kind enough to draw out a electronics schematic on how the wiring is to be runned.
The positive, ground, and remote are obvious wires that i dun need drawn, but i'm a bit confused on how to re wire the speaker wires since we don't have RCA outputs on our stock deck. I know there is some slicing to be done, but don't know exactly where the wires go.
I've installed a sub before no problem, that was a cut and paste project, easy..but getting a signal from the speakers to the amp i'm still a bit confused after reading all the previous posts through a search. I'm usually just upgrading subs into all my previous cars, but this time i wanna go for an upgrade into speakers since i don't want to drop an xtra $100 pounds of equipment into my car trunk for a sub. A schematic would solve all my problems! thx =)
Btw, if anyone has a diagram of the back of the HU, that would be good too, only could find the NAVI diagram through search, nothing for the regular deck, but i'm assuming it's similar, minus the vid inputs/outputs?
Old April 5th, 2005, 02:37 PM   #2
Why try?
before anything you need to get a a line out converter
BlackAccord03 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2005, 03:02 PM   #3
accord03's Avatar
Radio 12v .... white/green .... + .... radio harness
Radio Ground .... black .... - .... radio harness
Radio Ignition .... yellow/red + .... radio harness
Radio Illumination .... red/black .... + .... radio harness
Power Antenna .... yellow/green .... + .... radio harness
LF Speaker +/- .... green/black - lt. green .... radio harness
RF Speaker +/- .... grn/yel - gray or gray/red .... radio harness
LR Speaker +/- .... blue/white - blue/black .... radio harness
RR Speaker +/- .... pink - blue/yellow .... radio harness
i dunno how valid this is..got it from accordtuner.com....cause lookin at the colors....seems like the positive and the neg colors dont match....but maybe use this as a guide....again u should test it out. but just wire 4 set of regular 16g speaker wires, and 2 sets of rca wires from the front to back (along with the power, and remote on the oppisite side of the car)..and hook up the amp output to the according speakers in the stock wire harness(yes ur going to have to cut the stock up, unless u buy a new headunit....which i recomend)...and then put in line out converters and rca them up with the according slots on the amp...and your done.
Old April 24th, 2010, 11:18 AM   #4
Sn3@k3r@dd!K's Avatar
What's the best way to run the power wire from the battery to amp? (i.e. thru firewall or door)
Help please
Sn3@k3r@dd!K is offline   Reply With Quote Quick reply to this message
Old April 24th, 2010, 12:05 PM   #5
Euro accord wannabe
aznboi128's Avatar
^ mine is thru firewall
aznboi128 is offline   Reply With Quote Quick reply to this message
Old April 24th, 2010, 12:39 PM   #6
Help please
Just put the amp in the engine bay! thats all! Hahahaha! Just kidding man! Go through the firewall!
californium90 is offline   Reply With Quote Quick reply to this message
Old April 24th, 2010, 04:39 PM   #7
ok i couldn't find an opening for the firewall so i ran thru the fender (just behind the mirror) and into the rubber cover by the door hinge. It looks a bit tacky but will do for now.
Can anyone possibly take a pic of where the wire is running thru.
Old April 24th, 2010, 05:14 PM   #8
Send a message via AIM to rjp6262
i put a hole in the steering column boot...thing. running 1/0 wire through it no problem!
rjp6262 is offline   Reply With Quote Quick reply to this message
Old April 24th, 2010, 09:20 PM   #9
paperboy42190's Avatar
u guys realize this is a 5 YEARS OLD thread?!!!
Nighthawk Black Pearl 2007 Acura TL Type-S
paperboy42190 is offline   Reply With Quote Quick reply to this message
Old April 25th, 2010, 08:25 AM   #10
Bodyboarder
Rich's Avatar
Send a message via AIM to Rich Send a message via Yahoo to Rich Send a message via Skype™ to Rich
my former username trader rating:
Xbox Live Gamertag: BeachBum561FLA
Rich is offline   Reply With Quote Quick reply to this message
