changing H emblem - Honda Accord Forum : V6 Performance Accord Forums
Old April 19th, 2005, 10:20 PM   #1
CeRtiFiEd PimP
changing H emblem
can i replace my H emblem in the back with a diffrent .like those ones wit the redback ground??
Old April 19th, 2005, 11:20 PM   #2
TDotCord's Avatar
Send a message via AIM to TDotCord
I believe that you can...you'll just have to place the new emblem over top to cover the two small holes..
my cousin did it on his 6th gen sedan...but you have an 7th gen coupe...but I don't see why not
TDotCord is offline   Reply With Quote Quick reply to this message
Old April 19th, 2005, 11:47 PM   #3
i changed mines with the dc5 H emblems...all u need is 3M and stick them on....but those emblems are expensive...lucky my frend had an rsx and got them for free...
DarkVillian is offline   Reply With Quote Quick reply to this message
Old April 19th, 2005, 11:54 PM   #4
CeRtiFiEd PimP
so i cant get any other type cuz they fit right?
Old April 20th, 2005, 10:42 AM   #5
I suggest doing omething different and inexpensive.
On my 94 accord I took off the emblem. Then I got a a small square piece of left over vinyl from my body graphics (2" x 2"). I traced the outside line of the emblem an the two holes onto the vinyl, then I cut it (using a really sharp razor). Then I put the vinyl (with the backing) and the emblem back onto the car. I made some more markings, and traces, and then took every thing off. I made some final trims and cuts to make it fit perfectly. Then I finally applied the vinyl permanently with soap water and squegeed the water out. Then I put the emblem back.
It looked pretty good for the cost of nothing. Then in the future if you don't like it, you just take it off. No messing around with 3M tape.
baldo is offline   Reply With Quote Quick reply to this message
Old April 20th, 2005, 11:31 AM   #6
hmmm...
i took off my back emblem and replaced it with the red "H"..it cost like 10 dollars i think...i just got some super glue and glued it on..
Old April 20th, 2005, 01:13 PM   #7
CeRtiFiEd PimP
you glued it on>??? does it tabs that goes into the trunk or sometihng...u got pics of it?
Old April 20th, 2005, 04:20 PM   #8
hmmm...
yea..the tabs are for the oem emblem, my red one didn't come with tabs....if you wana see how it would look like, look at mqike's car...he has the red emblem on his trunk...
Old April 20th, 2005, 04:37 PM   #9
CeRtiFiEd PimP
how is it meant to stick on the car
Old April 20th, 2005, 04:42 PM   #10
CeRtiFiEd PimP
oh..and can i biu any H emblem..and it should fit rite? or i need one gfor 7th gen only
