TCS and Sunroof button light bulb replacement? - Honda Accord Forum : V6 Performance Accord Forums
Old April 21st, 2005, 06:37 PM   #1
The Originator
Anyone know what kind of bulb is in the TCS and Sunroof buttons? My lights just went out, and I'm considering changing them into LEDs if possible. Thanks
dj mikel is offline   Reply With Quote Quick reply to this message
Old April 24th, 2005, 12:33 PM   #2
I though they were LED in there, stock.. There is no way those should ever burn out... U prolly got somethin else going wrong there if there out....
Old April 24th, 2005, 02:10 PM   #3
The Originator
Well I recently took out my aftermarket fog lights which are currently wrapped up in electric tape. I think what possibly could have happened was that somehow, when I disconnected the fogs, the switch that turns the fogs on may have caused the other 2 swiches to die... On another note, do you guys think this is replaceable under warranty??
Old April 24th, 2005, 03:06 PM   #4
Did u check to see if u have any blown fuses or disconnected wires by ur switches.. Most likely this is what has happened.. Don't know what kind of a surge would make those things burn out like that... They might fix it under warranty if they can't tell u been doing stuff under the dash.... Dunno... Give it a shot.
Old April 24th, 2005, 04:21 PM   #5
The Originator
Yeah, I checked the fuses, they are all good. I also checked the bulbs or led's themselves, and it seems that they are blown, because once i put power to them, they wont light up whereas other bulbs do.
Old April 24th, 2005, 05:57 PM   #6
Wow that's weird.. Well hopefully ur dealer will fix it for free then....
Old April 25th, 2005, 10:42 AM   #7
Scott Si's Avatar
Here ya go:
Bulb for sunroof switch: 1090911
Bulb for TCS switch: 1090912
I noticed my sunroof switch was out just last week
How difficult do you think it is to replace?
Scott Si is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 01:51 PM   #8
The Originator
not difficult at all, just open up the panel, and pry open the lights with a phillips flathead screwdriver.....Thanks for the info..
Anyone know what leds can replace these stock bulbs, I want to go all blue
Old March 31st, 2006, 09:32 PM   #9
original member!
Nittanys1's Avatar
man my girls lights are going out all over the place!!!! first the heated seat switch and now the sunroof one....this is stupid too!!!! I have had a 5th gen and a 6th gen and not one problems with bulbs....
thing is alot of ppl say go to the dealer and get them to replace it...well she bought the car used and it wasnt from them and they are not helping us out very much....infact they tried to con us on a few other things...
Old March 31st, 2006, 10:14 PM   #10
registered n00b
sumptimwong's Avatar
Common problem, you're definitely not the first.
DIY LED conversion for the switch (make sure you use a resistor, the OE light is NOT an LED, it's a "micro lamp"):
http://www.v6performance.net/forums/...ghlight=switch
DIY micro lamp replacement (sorry, I know the link is dead, but the context is still there):
- wong
Old April 1st, 2006, 07:19 AM   #11
i<3 my P.O.S.
04accordcoupe's Avatar
Send a message via AIM to 04accordcoupe
Hey thats my DIY LoL yeah its pretty easy to change these light are so freaking sensitive they blow very easily
04accordcoupe is offline   Reply With Quote Quick reply to this message
Old October 4th, 2006, 04:40 PM   #12
are there any visuals for the sunroof light?
LycheE is offline   Reply With Quote Quick reply to this message
Old October 10th, 2009, 03:31 PM   #13
CeRtiFiEd PimP
does anyone know if the sunroof light is the same light bulb as the heated seats one???
Old October 10th, 2009, 06:06 PM   #14
H22 VTEC's Avatar
7: 35850-SDN-A01 BULB
8: 35851-SDN-A01 BULB
9: 35852-SDN-A01 BULB
10: 35853-SDA-A01 BULB (14V 60MA)
11: 35871-SAA-003 BULB, NEO-WEDGE
these are part numbers according to illustration number.
im assuming they are diff part numbers for the base but if your replacing with LED's than all bulbs are the same. just cant remember what the bulb type is off the top of my head.
H22 VTEC is offline   Reply With Quote Quick reply to this message
