Anyone has this Interior Trim Kit from Ebay Installed? - Honda Accord Forum : V6 Performance Accord Forums
Old April 27th, 2005, 02:22 AM   #1
Anyone has this interior trim kit installed? How are they holding up and do you have any pix? Thanks!
V6Perform is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 02:42 AM   #2
Tofu Delivery Boy
The_Tofu_Shop's Avatar
Send a message via AIM to The_Tofu_Shop
those kits always depend on who installs them really. some i have seen come out really nice. others... not so nice.
Andy 2
SoCal Pride
G-Spec Points: 40
The_Tofu_Shop is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 07:59 AM   #3
[QUOTE=V6Perform]Anyone has this interior trim kit installed? How are they holding up and do you have any pix? Thanks!
Well, I just recently purchased a similar kit from www.edashkit.com. I know www.veneerz.com sells these dash kits too, but they were a little more expensive. I have navigation on mine, so I had to get one that'll fit. I'll post up pictures when I get them installed. They say it's pretty easy to install. Just clean the area and apply. That'll be my weekend project next week.
lawwoo11 is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 09:56 AM   #4
Tofu Delivery Boy
which style did you get lawwoo11?
Andy 2
SoCal Pride
G-Spec Points: 40
Old April 27th, 2005, 10:48 AM   #5
I ended up getting the Brushed Aluminum. Hopefully it'll look good. I have the stock carbon fiber that comes with the ex-v6, 6spd, but I wanted to give it a change. So we'll see how that goes....shrugs.
Old April 27th, 2005, 11:12 AM   #6
Tofu Delivery Boy
just make sure you post pics when youre done.
and take your time!
Andy 2
SoCal Pride
G-Spec Points: 40
Old April 27th, 2005, 11:20 AM   #7
I have the Brushed Aluminum Kit installed in my ride. Bought it off of eBay for like $130 or so. Very easy to install and takes less than 15mins. The instructions and install kit come with it. Here is a pic of mine installed:
This is from 2 yrs ago and I still have had no problems with it. Just make sure when you do the install that the weather is really warm outside so it sticks to the dash very well. Good Luck !!
DesiEGO is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 11:27 AM   #8
nycsam786's Avatar
Send a message via AIM to nycsam786
^^ looks phat
nycsam786 is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 12:04 PM   #9
Man...looks really nice. I hope mine turns out half as good as yours.
Old April 27th, 2005, 05:07 PM   #10
I bought it and installed it. It is not real aluminum but it looks really good, everybody who has seen it has complimented it. The sticker thay are talking about is actually a 3M adhesive, really strong stuff, industrial strong. We use it where I work at.
Looks good but it's coat is like soft plastic (gel/vinyl). It has a glossy shine. You need to prep up all the plastic with plastic promoter, which they do not give you enough. Yo can buy some at an aouto parts store. I strongly reccomend you go to auto zone or pep boys and buy the promoter. It is best if you use a cue tip to apply the promoter. If you wipe the promoter with a cotton swab or a cloth, it will eat some of the plastic which will make it look ugly. Remember if this were to happen, you are still going to cover the area. I reccomend apllying small amounts using the cue tip.
It looks good once it is installed properly. Its kind of is a small pain to install. Once it sticks, it is hard to remove. If you do install it, remember not to stick part of it and then force the rest of it in a different shear direction, or else it will crack in the future. Some kits have more parts than what is needed, and thos extra parts if installed would make your car look tacky. You be the judge of what parts ot put on.
It is a less expensive alternative to buying the Honda trim kit, and it has more trim parts.
I haven't had any problems, just one part on the steering wheel which did not stick good because of the contours, so I just added adhesive and fixed it.
baldo is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 07:52 PM   #11
Thanks for all the replies... DesiEGO, yours looks very nice... I have ordered mine from ebay... Hopefully I get be4 the weekend so I can work on it this weekend.
Old April 28th, 2005, 06:17 AM   #12
^No problem man. You are gonna like it a lot. Just remember to take your time and align it properly and make sure you clean the surface well with the adhesive that they provide and you should have no problems.
Good luck and post the pics once done.
Old April 28th, 2005, 10:58 AM   #13
arom's Avatar
One thing to keep in mid is when the summer heat turns the interior into a tepid 200degrees oven, those peel n sticks have a tendency to lift up from the dash
arom is offline   Reply With Quote Quick reply to this message
Old April 28th, 2005, 04:38 PM   #14
I would have to diagree, do you have any experience with this?
Old April 28th, 2005, 06:36 PM   #15
I was also thinking of gettin one of those kits of ebay too... Hopefully it works good, be sure to get lots of pics
Old May 2nd, 2005, 11:28 PM   #16
UPDATE with pix - I didn't install every piece that came with it.
Old May 2nd, 2005, 11:34 PM   #17
Nice interior! Man, mine hasn't even come yet and I ordered it last monday. Was it hard to install? Any additional tips? Did all the parts fit ok?
Old May 2nd, 2005, 11:44 PM   #18
Banned By *********s
Send a message via AIM to Jkvan87
wonder what it would look like in a tan interior...
Jkvan87 is offline   Reply With Quote Quick reply to this message
Old May 3rd, 2005, 12:01 AM   #19
I ordered my last Monday too and it came today.
Anyhow, the installation was way easier than I thought - all the parts fit very nicely.
1. Clean the surface with alcohol (come with the kit)
2. Apply Adhesion Promoter (come with the kit)
3. Peel off the plastic and apply
As "baldo" suggested above, use Q tip to apply the promoter.
Old May 3rd, 2005, 05:22 AM   #20
ex scientia vera
kramer2k's Avatar
V6Perform, VERY nice indeed!! I like it a lot.
BTW, that's a nice shift knob you've got there.
Old May 3rd, 2005, 12:43 PM   #21
Tofu Delivery Boy
nice mike!
you'll have to come out to a meet so i can see it in person!!!
Andy 2
SoCal Pride
G-Spec Points: 40
Old May 4th, 2005, 01:15 AM   #22
Hahaha...... yeah thanks to you!
Old May 4th, 2005, 01:18 AM   #23
nice mike!
I will try to make it next time. I really like to come, but I am jsut so busy!
Old May 4th, 2005, 01:47 AM   #24
Tofu Delivery Boy
i hear you mike, im busy too. i am way behind with everything cause i always go to the meets.
like, im supposed to be writing a paper right now...
Andy 2
SoCal Pride
G-Spec Points: 40
