Aftermarket Stereo/Navigation conflict - Honda Accord Forum : V6 Performance Accord Forums
Old May 16th, 2005, 10:34 PM   #1
I just recently had my speakers and amp installed by a local stereo shop. And when they did the install, I found out that they used aftermarket speaker connections rather than using the existing factory ones because of the sound quality. Now when I type in a destination in my navigation, the lady voice that speaks to you can no longer be heard. I'm sure this is because the connection from the navigation to speakers that allowed this to be heard was from the factory speaker harness.
Now my question to anyone is how would I be able to get the talking navigation to be heard again while using my aftermarket speaker connections and not converting back to my stock harnesses?
Any help is much appreciated
Old May 16th, 2005, 11:02 PM   #2
orion4096's Avatar
Send a message via AIM to orion4096
Is this with the stock HU/stereo? If so, I think you could just hook up pins 12 and 13 RG +/- from the 20pin factory harness (lt blue) where RG stands for Route Guidance to the new wiring harness which replaced the factory one and you should be set. Pins 12 and 13 can be seen with the end you plug in facing away from you starting from the upper left and counting along the top row (1-10) and then counting the bottom row starting on the left going to the right (11-20).
pin 12 has a blue/red wire
pin 13 has a white wire
The stock HU already does all the mixing of the two signals.
orion4096 is offline   Reply With Quote Quick reply to this message
