Problem installing my IceLink on Navi & XM Accord - Honda Accord Forum : V6 Performance Accord Forums
Old June 8th, 2005, 03:12 PM   #1
Ok, call me stupid -- but where the hell is the plug? I got the storage bin out in a snap, but I see no harness or port? The diagram and pictures show that the port should be directly on the bottom of the radio, unfortunately it's not. Do I have to undo the radio from the brackets and slide it forward? Is the port on the back of the radio as opposed to the bottom?
I remember seeing a pdf floating around from Honda that described in detail how to do remove navi equiped radios, does anybody know where I can find it?
Thanks,
-N
Nabbs is offline   Reply With Quote Quick reply to this message
Old June 8th, 2005, 03:22 PM   #2
Here's the pdf: http://handaaccessories.com/accord/03-dvdwmoon.pdf
Looks like I'll have to take the upper dash out. What a pain.
-N
Old June 8th, 2005, 08:00 PM   #3
7th Gen ACcord
xjdMb16a2six's Avatar
yup if you got navi you have to remove the HU.
Old June 8th, 2005, 08:47 PM   #4
Do you know where the cable is on Navi cars? Or have a link/pic of it?
-N
Old June 8th, 2005, 09:22 PM   #5
Send a message via AIM to bagbklyn
Cable
-N
I tried following the honda accessories instructions when I was installing my navi, it didn't work for me. I used a butter knife around the edges near where the clips are. It make a little indention on the plastic dashboard, but you can just run it out. At first it will scare you but don't worry it isn't that bad
On the back of the Navi unit you will see a white plug, I believe its the one in the middle. That should be where the XM is connected.
bagbklyn is offline   Reply With Quote Quick reply to this message
Old June 8th, 2005, 10:11 PM   #6
You have to take the navi screen out to see it. Its on the left side.
