foglight bulb question - Honda Accord Forum : V6 Performance Accord Forums
Old July 4th, 2005, 12:29 AM   #1
H11 bulb = foglights
9006 = low beam
is there a difference b/w the 2? cuz they both look like the same bulb...
ie) 9005 and 9006 pretty similar..
would 9006 or a 9005 fit if i replace the H11 fogs?
kwanzor is offline   Reply With Quote Quick reply to this message
Old July 4th, 2005, 12:45 AM   #2
the base is probably different.. and the bulb socket things.
chinoamigo is offline   Reply With Quote Quick reply to this message
Old July 4th, 2005, 02:21 AM   #3
St. Louis!
Kingof3rdinput's Avatar
+1....Different base. You can modify the bases on 9005/9006 I know. Just compare the 2 first.
Old July 4th, 2005, 02:23 AM   #4
registered n00b
sumptimwong's Avatar
sorry, dunno about the fogs, but 9005 and 9006 are definitely different. 9006 is the low beam, 51W stock (yes i know its kinda weird). 9005 is the stock high beam, 62W. there is a simple way to retrofit 65W 9005 bulbs to fit in your low beam sockets. it improves light output by at least 300 lumens, and does not pose any significant risk of electrical overheating or shorting the fuse from decreased resistance. ive had a 9005 retrofit in my car for a few months now, im lovin it. ask if u want details
- wong
Old July 4th, 2005, 08:54 AM   #5
how did u retrofit 9005 into 9006? thanks
Old July 4th, 2005, 11:14 AM   #6
J35A2K23B18CSRDETT2JZLOL
SIRSIG's Avatar
9006 = low beam
i have a similar question before. i compared the H11 and 9006 HID bulb.
first picture on the right is the H11 bulb.
i think that the 9006 HID base need to be shave a bit to fit.
SIRSIG is offline   Reply With Quote Quick reply to this message
