Temp gauge w/ aftermarket OEM fogs - Honda Accord Forum : V6 Performance Accord Forums
Old July 8th, 2005, 09:14 AM   #1
arom's Avatar
Has anybody attempted to install the Temperature Gauge on an Accord that had OEM fog lights installed AFTER MARKET? I noticed there is a statement “temp gauge can not be installed if fog lights have been installed after market” on H&A. I looked at the installation manual and I’m confused as to why because it doesn’t look like it would interfere whith wiring. Any thoughts? Or has someone done this with no issues?
arom is offline   Reply With Quote Quick reply to this message
Old July 8th, 2005, 09:36 AM   #2
arom's Avatar
OK,
I just compared the FOG LIGHT installation guide and the TEMP GAUGE guide and it does look like it uses the same pin connectors near the relay box and under the dash.
SO......, what if you just splice into the connectors, piggy-backing onto the fog light harness'. Any issues with overloading?
Old July 8th, 2005, 12:57 PM   #3
6MT
SlayerGTR's Avatar
don't the EX accords come w/ temp gauge? or at least when u push the trip meter button it'll scroll to the temp. Some ppl have fogs in theirs... so iono why it wouldn't work
Old July 8th, 2005, 01:26 PM   #4
arom's Avatar
DX
LX
Models DO NOT have the temp sensor standard......
Old July 8th, 2005, 03:12 PM   #5
Stalls @ every light
AZ-V6-Hybrid's Avatar
As I understand it...
If you have the temp unit stock it uses it's own harness thus leaving the one for OEM fogs. If you don't have it then you can only use that harness for one or the other. Seems lame but that's what I've heard...
AZ-V6-Hybrid is offline   Reply With Quote Quick reply to this message
