sunvisor bulbs - Honda Accord Forum : V6 Performance Accord Forums
Old January 10th, 2006, 01:23 PM   #1
sunvisor bulbs
Anyone know the bulb size on our sunvisors? i want to put some led's
in there . If this has already been discussed whats the search word i can look under?
Eloy213 is offline   Reply With Quote Quick reply to this message
Old January 10th, 2006, 07:56 PM   #2
keepin' it OG
heheh, like thiiis.
KIET
Old January 12th, 2006, 02:18 AM   #3
Originally Posted by Kiet
heheh, like thiiis.
Awesome dude. Exactly like those. Where can i get those and how much?
Old January 12th, 2006, 03:40 AM   #4
keepin' it OG
their just 5mm (or i 3mm) bulbs i have wrapped around.. i dont think anyone carries exact replacement for these bulbs, well not that i have seen of anyways.
i think the yellow shows better, i think. i havent really compared compared with both bulbs at night, but i dunno.. not like i even use them anyways.. so they are just for aesthetic purposes only.. lol.. but i do have a comparison picture of the regular and the led in the visor..
KIET
Old January 12th, 2006, 01:52 PM   #5
registered n00b
sumptimwong's Avatar
wow, the halogen bulb is WAY brighter. im sure honda stocks replacements
- wong
Old January 12th, 2006, 02:38 PM   #6
6MT
SlayerGTR's Avatar
yup i have yet to change those too, but i jus couldn't find out the bulbs to use in those
Old January 12th, 2006, 07:32 PM   #7
keepin' it OG
its just the design of both of the bulbs.. the led is shaved, so light is only illuminating at one direction compared to the regular stock bulb which is illuminating from all angles of the perspective, which makes it seem like there is more light than it really is... it also depends on the angle of how the led was cut as well... at certain directions of the cut led, it may seem that there is more light, and at different angle, it may look like there is les light... thats how led somewhat are if anyone has worked with them before.
it all depends on what the owner wants... the color or the lighting performance... keep in mind how small the space is.. its possible you can put two leds in there... just takes a little more effort in the making of it... but possible...
KIET
Old January 12th, 2006, 07:39 PM   #8
CRV_33's Avatar
Might be a worth a shot to check, try opening the visors again with your parking lights on.
Old January 12th, 2006, 07:41 PM   #9
keepin' it OG
they only turn on while your parking lights are on.. otherwise, it wont turn on. if someone was wondering why theirs wont turn on.
KIET
Old May 18th, 2006, 11:57 AM   #10
Bai Se Feng Che
GPerlAccord's Avatar
Did anyone ever figure out what type of bulbs these sunvisor/vanity mirrors take?
GPerlAccord is offline   Reply With Quote Quick reply to this message
Old May 18th, 2006, 11:00 PM   #11
registered n00b
Yea, but I didn't provide the exact p/n. Just use a small screwdriver to pry the diffuser off, and you'll see a 1-2W glass-cylinder type bulb. p/n should be stamped on the metal contacts of the bulb.
- wong
Old June 10th, 2006, 01:06 PM   #12
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Here's the best I can offer........
http://www.v6p.net/forums/showpost.p...55&postcount=1
Old June 10th, 2006, 01:22 PM   #13
NightShift's Avatar
Send a message via AIM to NightShift
custom...about the same brightness as stock:
NightShift is offline   Reply With Quote Quick reply to this message
Old June 10th, 2006, 01:24 PM   #14
nice...where did u get the bulbs or how did you get it like that?
Sin-R V6 is offline   Reply With Quote Quick reply to this message
Old June 10th, 2006, 02:27 PM   #15
NightShift's Avatar
since the original bulbs look like fuses... i found some old fuses..broke the glass and unsoldered the fuse pieces from the outside bases, then used a resistor on one side and just a piece of the wire from the shortened resistor for the other side, and a white SMD (led) in the middle
i thought i had a pic somewhere..still looking
Old June 10th, 2006, 02:32 PM   #16
LaLaLaLa
stupidaznmunkey's Avatar
hey kiet, you just retro-ed the 3mm in right? i think ours are fuse type bulbs, and im sure there is a part # for it, but its not as popular to make LEDs for like the 168/194 size bulbs
Old June 10th, 2006, 03:52 PM   #17
Bai Se Feng Che
yea seems like no one makes these bulb typed in leds. Most are custom which I have yet to find out how since I have a few extra 3mm led bulbs in white laying around.
If anyone has a DIY that would be great. To make my own bulb would take some work though. Might not have the time?
Old June 10th, 2006, 06:44 PM   #18
keepin' it OG
yeah i put a 3mm in there. If i have time, i'll see what i can do.
