9006 rebased D2R bulb fitment - Honda Accord Forum : V6 Performance Accord Forums
Old January 13th, 2006, 09:10 PM   #1
Anyone know how to fix loose fit for 9006 rebased D2R bulbs? I have stock headlight. The bulbs are quite loose inside the housing. I am worried that bulbs will come out.. I put duck tape right now, but is there any other way to make it tight fit??
supasoju is offline   Reply With Quote Quick reply to this message
Old January 13th, 2006, 09:16 PM   #2
7th Gen ACcord
xjdMb16a2six's Avatar
you can find a washer at home depot and cut a ring to fit it around the bulb. thats what i did and it worked fine.
Old January 13th, 2006, 09:23 PM   #3
ah ha. thx.
Old January 14th, 2006, 02:22 AM   #4
carlrx7's Avatar
i can't seem to find any company to make rebased d2r bulbs.. they all use d2s bulbs
if it was me i would wrap some electrical tape around the base and call them good.
carl.
:: Fix it Till it's Broken!! ::
2005 Honda Accord Ex V6 SEDAN
264hp/246tq at the wheels
Yes, I have Nitrous
carlrx7 is offline   Reply With Quote Quick reply to this message
Old January 14th, 2006, 02:49 AM   #5
registered n00b
sumptimwong's Avatar
yikes, that is probably a bad idea. if you alter the position of the bulb in the housing, you may move it out of the housing's intended focal point for the bulb. if you move the filament outside of that focal point, you will get MUCH MUCH more glare, and light will be scattered every which way, making the HID even more potentially dangerous to oncoming traffic.
what you should check first is that the 3 phillips screws that secure the bulb to the housing are TIGHT. if they're cranked all the way down, it is likely that you wouldnt even be able to get the bulb to fit, much less have them be loose. check that first, and if that STILL doesnt work, then add thin washers/rings until it does. gl!
- wong
Old January 14th, 2006, 11:10 PM   #6
7th Gen ACcord
^^^ nah. the washer i got is really thin, but still made the bulb fit tight.
Old January 14th, 2006, 11:12 PM   #7
7th Gen ACcord
carl.
here you go. i bought mine from this guy.
http://cgi.ebay.com/ebaymotors/Hella...spagenameZWDVW
