HeadLight Black Housing - Honda Accord Forum : V6 Performance Accord Forums
Old January 19th, 2006, 11:30 PM   #1
Hi, I have been seeing many Black Housing Head Light pictures around the forum, but i couldnt really find a thread that gives directions on how to make the housing. is there such a place where i can see how its done? thanks..
PakCord786 is offline   Reply With Quote Quick reply to this message
Old January 20th, 2006, 12:18 AM   #2
i<3 my P.O.S.
04accordcoupe's Avatar
Send a message via AIM to 04accordcoupe
maybe maybe not but i am in the process of doing mine...Its fairly easy you jusy have to take teh headlight apart and paint what you wnat black thats all with high temp paint...i'll post some picture when i am done
04accordcoupe is offline   Reply With Quote Quick reply to this message
Old January 21st, 2006, 11:41 AM   #3
but is there a perfect way to do this?... does any particular way painted make it look better?
Old January 21st, 2006, 02:30 PM   #4
6MT
SlayerGTR's Avatar
i think... u preheat ur oven to some degree and put headlights in for 5-10 min and take it out
the silicon that holds the headlight housing together should be losen and u can ply ur headlights apart. Paint w/e and after u done,.... i dunno the rest ;P
Old January 21st, 2006, 03:32 PM   #5
Ok it is really easy to do this mod. All you have to do is preheat you oven to 350. When you oven gets to the temp stick your headlights in for 4 mins. Your silicone should be soft by then. Pry your headlights apart. I used a flat head screw driver and just worked my was around the headlight. Paint your headlight with hight temp paint. Use your desired color. It really isnt that hard. If you have anymore q's than send me a pm.
Here4u2nv151 is offline   Reply With Quote Quick reply to this message
Old January 21st, 2006, 03:47 PM   #6
keepin' it OG
or you can use a heat gun. i've seen the oven option go bad before.
KIET
Old January 21st, 2006, 06:01 PM   #7
i<3 my P.O.S.
here mine been sitting in my closet finally got the time to do it ...I use high heat flat black paint but i don't know if i should do like a semi gloss clear or a high gloss on it or jsut leave it the way it is
these are going to be regular projector high beam whit ACURA TL Bi xenon for low/high and CCFL andgel eyes
