White Light.....Bulbs - Honda Accord Forum : V6 Performance Accord Forums
Old February 10th, 2006, 12:27 PM   #1
girl powah!!
03aV6cpe's Avatar
I don't like the yellow light for the licence plate lights or the door courtesy lights.
Can someone recommend me a good replacement bulb for these. I don't want to do LED's, I just want to replace the bulb but with one that gives white light not yellow.
Thanks
Old February 10th, 2006, 01:16 PM   #2
I ♥ My Honda
ephyouckay's Avatar
Send a message via AIM to ephyouckay
yea i changed mine... you can use either polarg or piaa bulbs
http://www.sylvania.com/ConsumerProd...RG-Results.htm
ephyouckay is offline   Reply With Quote Quick reply to this message
Old February 10th, 2006, 02:28 PM   #3
girl powah!!
03aV6cpe's Avatar
hey eph!
I'm not sure which one is better in quality. Which one did you get?
thanks
Old February 10th, 2006, 02:59 PM   #4
registered n00b
sumptimwong's Avatar
keep in mind that, if you are sticking with halogen, and using the same wattage bulbs, having a "whiter" appearance is achieved only by tinting the glass blue, which also has the effect of reducing the brightness
- wong
Old February 10th, 2006, 04:35 PM   #5
7yr / 120K
Celestion's Avatar
This guy is totally correct! Blue tint is soo 90's LED is probably the only way to go if you want truely white light.
Celestion is offline   Reply With Quote Quick reply to this message
Old February 10th, 2006, 04:47 PM   #6
go with LED's....I did that with mine and it looks like the new Lexus GS & IS Licence plate lights. Make sure you get a bulb that has a Wide spectrum or it will look silly. The bulb I bought has 4 LED's on the side that face different directions and one down the center.
hondafleet is offline   Reply With Quote Quick reply to this message
Old February 10th, 2006, 08:07 PM   #7
St. Louis!
Kingof3rdinput's Avatar
I have PIAA hyperwhite turn signals, they look great IMO. Not ricey at all.
Old February 10th, 2006, 10:23 PM   #8
girl powah!!
03aV6cpe's Avatar
i saw the new gs the other day and that's what made me want that white light for the licence plate . it wasn't too dim nor too bright...it was just right!!
can you link me to the LED's you purchased? also is it hard to install?
Sorry for all the questions but i want to try and get this done this weekend.
Thanks
Old February 10th, 2006, 11:34 PM   #9
registered n00b
most of the pre-wired LED bulb replacements use weak LEDs. the result is that your LED bulb replacement will be less bright than the halogen which is being replaced. if you want something up to par with OE brightness, you'll have to do some homework to see if there actually exists any quality direct replacements. otherwise, you will either have to put up with the diminished output, or build your own bulb using some quality LEDs and resistors
- wong
Old February 11th, 2006, 02:51 AM   #10
I ♥ My Honda
ephyouckay's Avatar
i have polarg bulbs... i love them... they are actually brighter than stock bulbs.
LED sucks... dont do it.
Piaa and Polarg are both pretty good brand... try getting it on ebay... ive found it the cheapest there and i never ran into problems.
Old February 11th, 2006, 08:25 AM   #11
datboiroy's Avatar
Send a message via AIM to datboiroy
i personally like the led's from ledautomotive.com, ive had them for years and no problem.
datboiroy is offline   Reply With Quote Quick reply to this message
Old February 11th, 2006, 03:12 PM   #12
Thanks
took less than a minute. I used the WLED-x5 LED Wedge Base Bulbs
http://www.superbrightleds.com/mini-wedge.html
Old February 12th, 2006, 03:22 PM   #13
Do you have any pics? How is the light output on these LEDs?
neonecko is offline   Reply With Quote Quick reply to this message
Old February 12th, 2006, 05:17 PM   #14
girl powah!!
03aV6cpe's Avatar
pics would help me on this
can both eph and hondafleet please post pics of their licence plate light
i've already removed the 6 clips in my trunk liner to access the licence plate bulb, and i've taken off the lens for the door courtesy light. now i just need to see the results of the led vs polarg thanks guys
Old February 14th, 2006, 12:52 AM   #15
I ♥ My Honda
ephyouckay's Avatar
the light is brighter than that. the picture doesnt do it any justice nor does the smoke liscence plate cover.
those are polargs btw.
Old February 14th, 2006, 10:13 AM   #16
Nice. I think the sedans have only one light right in the middle? O.o
Old February 14th, 2006, 12:09 PM   #17
girl powah!!
03aV6cpe's Avatar
thans eph for the pics i'm gonna order some polargs. i was thinkin of smoking my licence plate too with a light grey vinyl. can u pm me pics of your licence plate. thanks!!
Old February 14th, 2006, 12:12 PM   #18
I ♥ My Honda
ephyouckay's Avatar
sure... ill try to get some... i used a plastic cover from target...
Old February 15th, 2006, 10:18 PM   #19
I bought the exact bulbs from there and got them installed. Looks great! Thanks hondafleet. Much appreciated
Old February 15th, 2006, 10:52 PM   #20
I found this set of polarg's which says 168 and 194. But in the description they only mention 194... is 168 compatible? I'm definately a noob with LED and lighting. Thanks in advance.
http://cgi.ebay.com/ebaymotors/JDM-P...spagenameZWDVW
briyangiton is offline   Reply With Quote Quick reply to this message
Old February 15th, 2006, 11:57 PM   #21
I ♥ My Honda
ephyouckay's Avatar
yes they are the same thing.
Old February 16th, 2006, 04:06 PM   #22
Sorry been ofline for a while or I would of posted some pics...maybe I can still snap some later and post them for anyone else who might be interested...glad you like them....I get compliments and people asking me about them all the time.
Old February 16th, 2006, 09:13 PM   #23
girl powah!!
03aV6cpe's Avatar
hey hondafleet, i'm still interested in seeing pics i would like to see the comparison of leds to bulbs. thanks
Old February 8th, 2007, 10:15 AM   #24
girl powah!!
03aV6cpe's Avatar
goodness almost a year later....anyway, i've purchased led lights for my licence plate and was disappointed.....too blue and not bright enough. i bought polarg bulbs and the difference was major..the polarg bulbs were more white and brighter.
anyway, i've been following this other thread for a while when i was reserching what to buy and they have made this for the licence plate light, i posted asking the guy if it would work on other vehicles and he stated it would since they use 168 bulb.
for those interested in something bright, white, and weather resistant here is the link, not sure how it would mount for our cars, but just throwing it out for anyone who wants to attempt something with it.
http://www.srtforums.com/forums/show...=297025&page=9
if ur unable to log in here are pics to see if ur even interested
stock output
modified output
http://www.srt-4store.com/images/STP60189.jpg
Joyce
Official Slammed Club Member (Stage 3)
Featured Ride Of The Month (June-July 2010)
Old February 8th, 2007, 10:58 AM   #25
Ayayayay!
Wow! Those are really bright license plate lights. Its almost you had neon lights under the rear fender. It has the fog light effect as well IMO
arkmann is offline   Reply With Quote Quick reply to this message
Old February 10th, 2007, 12:50 PM   #26
wow those are too bright! I rather have it dim!
I really liked the ones from www.superbrightleds.com but the ones that I put in the rear for the license plates started flickering within about a year, but the ones in the doors are perfectly fine. Anyone know why this happened?
black_sedan is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2007, 03:12 PM   #27
joedanger11's Avatar
installed cathodes for my rear plate. used two 4" tubes.
car is fricking dirty cause it rained.
Old February 23rd, 2007, 03:34 PM   #28
Where can I get those waterproof band of LEDs?
Leds for the plate lights on a 6th gen sucks big time!!! I got it and its not worth it. Its not bright enough. You can barely see the plate with it!
Old February 24th, 2007, 10:17 AM   #29
ttt
Old February 26th, 2007, 08:11 AM   #30
girl powah!!
03aV6cpe's Avatar
wow, i wish the coupes had that much free space up there above the plates, then i would buy those led's in a heartbeat!!! i didn't realize the sedans had that much of a gap.....
u can find it in the link i provided above, if u have a sedan then obviously looking at joedanger's pic it would be an easy fit. only thing now is how to have them centered. looks like there is something in the way.....
Joyce
