Cleansweep question - Honda Accord Forum : V6 Performance Accord Forums
Old March 7th, 2006, 11:59 PM   #1
Cleansweep question
Iam thinking about getting a clean sweep for my car but after all the search I still have a few questions if someone can answer.
1> Intalling clean sweep means connecting all the speakers outputs from the headunit to cleansweep to get 2 RCA outputs, question is How the speakers will be connected? through the amp which recieves the input from CS? or when connecting the speaker output to the CS, do we need to just tap into the speaker output into CS.
Simply, how the regular speakers will recieve input? through CS, H/U or amplifier?
Old March 8th, 2006, 12:03 AM   #2
sonnieeeeboi's Avatar
i don't have a cleansweep, but from reading about it, shouldn't the cleansweep ultimately be just a line out converter. I mean it does have the ability to undistort and change the signals from the speakers. Basically, your amps would are connected to the cleansweep with RCA cables. Your amps would then be the point where all speakers are connected to.
Old March 8th, 2006, 12:41 AM   #3
I feel da need 4 6-speeds
flyvtec's Avatar
Here you go. You can download the manual from this link:
http://mobile.jlaudio.com/products_c...hp?prod_id=369
Old March 8th, 2006, 01:42 AM   #4
registered n00b
sumptimwong's Avatar
HU > line-output > JL CS > RCA patch cable > amplifier > speaker wire > speaker
- wong
Old May 10th, 2007, 08:25 AM   #5
-Brian
NexsoN's Avatar
I am still confused, how exactly do we tap into the oem harness?
Old May 10th, 2007, 09:53 AM   #6
Formerly VTEC-v6!
N54TT's Avatar
Splice time
Old May 20th, 2007, 09:32 PM   #7
Brooklyn Representer
Stixx55's Avatar
Send a message via AIM to Stixx55
Question...
I'm new here & for some reason, I can't post a message yet...but has anyone ever installed an iPod adapter in their car? I was thinking about buying one from iCarKits.com. What do you think?
I'm far from being GOD, but I work GOD damned hard.
Stixx55 is offline   Reply With Quote Quick reply to this message
Old May 21st, 2007, 05:23 AM   #8
clean sweep is just a very very fancy line out converter. it will use a demo cd to equalize the factory sound at a certain volume to make it flat. a $20 loc will leave the factory tuning present, making the sound not flat and constantly changing at different volumes.
head unit -> splice speaker wires to extend -> speaker wires goes into clean sweep -> RCA from clean sweep to amps -> amps connect to speakers
droopy is offline   Reply With Quote Quick reply to this message
