'06 shifter on my '03 DIY (pics) - Honda Accord Forum : V6 Performance Accord Forums
Old March 23rd, 2006, 10:17 PM   #1
My Third Accord!
acb384's Avatar
Send a message via AIM to acb384 Send a message via MSN to acb384
just changed my shifter to the 06 model:
NOTE: Some modification required;
-You need part 54130-sda-a53zc (leather knob) for 34.76 from majestic honda.
here are instructions that will make sense if you are looking at the parts i guess.
-You need to cut the shaft shorter as well as the rod that does down the middle.
i learned that a simple pipe cutter works well BUT will disfigure the inside diameter of the shaft so the white bushing does not fit back in...a hacksaw would be better...but dont go all the way through...you want to keep the rod inside intact and test/trim it later. i had to do the cutting process 2x used the hacksaw the 2nd time.
-after you figure out how much you need to take off the shaft to get the screw holes to lign up then trim down your rod in the midle so that the shifter action works. do this little by little so you dont get it too short.
-You have to make your round hole in the console part square, a razor blade will do the trick.
-You need to cut a little off the bottom of the new shifter so it will go down far enough. (cut it off even with the notch so its flat all the way around then make a new notch) probably about an 8th inch.
-The screw holes are slightly further apart so you will only be able to use one.
My Cars:
'07 Civic SI Sedan (FA5)
'03 Accord EXV6 Sedan Sold.
'96 Accord EXL 5spd Sedan Sold.
'90 Accord EX Sedan Sold.
'87 Nissan Maxima GXE Sold.
acb384 is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2006, 10:23 PM   #2
joedanger11's Avatar
loooks goood. i didnt realize that was the 06 knob. looks like a cobra.
Old March 24th, 2006, 02:11 AM   #3
registered n00b
sumptimwong's Avatar
Cool. I think a Dremel with a cutting wheel would be even easier though ;D
- wong
Old March 24th, 2006, 05:13 AM   #4
My Third Accord!
acb384's Avatar
wish I had a dremel
Old March 25th, 2006, 12:45 AM   #5
registered n00b
I personally think you ought to invest in one. It is arguably one of the most versatile tools that I have ever owned. $40 for a basic one at walmart, $60 for a pretty nice one. I got the $60 flavor, and I wouldn't trade it for anything. I also purchased a $30 accessory kit, which makes the Dremel an even MORE useful tool. Highly recommended for ANY aspiring DIYer.
- wong
Old March 25th, 2006, 06:10 AM   #6
WORD
Old March 27th, 2006, 03:41 AM   #7
VERY nice!
so this part# --> " 54130-sda-a53zc " is all i need to order from a honda dealer?
comes with (illust. no 29) in link below right?
http://www.hondaautomotiveparts.com/...+LEVER+%281%29
i live in canada so i want to make sure i get the part # right since majestic doesnt ship to canada
thanks!
fobjarexx is offline   Reply With Quote Quick reply to this message
Old March 27th, 2006, 06:40 AM   #8
My Third Accord!
acb384's Avatar
yeah, part no 29 is the one i ordered., mine is the leather one.
on my invoice is says 54130-sda-a53zc KNOB NH167L list $46.35 and Net $34.76
Old March 27th, 2006, 11:01 AM   #9
_
0430Steve's Avatar
nice job, welcome to the club.
i did mine a while back. didn't worry about the second hole yet, but will so i can get 2 screws in. and i didn't cut it down in size, just left it tall. will modify at some point when it bugs me, but for now it's chill.
you ever have problems pushing in the button? mine will get stuck here and there so i have to move it up to park, down to 1, back up to park and it unlocks.
chill for a free mod.
