foglight problem. help.. - Honda Accord Forum : V6 Performance Accord Forums
Old April 29th, 2006, 06:43 PM   #1
oopsi4ted's Avatar
i just finished wiring up my aftermarket foglight system and when i tried to turn it on, the lights for the fogs dont light up.The switch for the fog lights come on though and i wired it up like the honda instructions told me to. Any kind of help would be really appreciated.
oopsi4ted is offline   Reply With Quote Quick reply to this message
Old April 29th, 2006, 08:47 PM   #2
Rolling on 19's
00&03Accords's Avatar
Seems all the inside wiring was done correctly.
Check all the grounding points under the hood.
Did you put in the fuse in the fuse box?
Re-do all the steps.
00&03Accords is offline   Reply With Quote Quick reply to this message
Old April 29th, 2006, 09:20 PM   #3
I ♥ My Honda
ephyouckay's Avatar
Send a message via AIM to ephyouckay
make sure your bulbs are not dead and make sure they are plugged in all the way. check for loose wiring and make sure you put in the fuse.
ephyouckay is offline   Reply With Quote Quick reply to this message
Old April 30th, 2006, 07:25 AM   #4
Hidden User
eVTEC's Avatar
Lightbulb
Did you turn on the headlight? If you followed the installation from the factory method, foglight can only be turned on while the headlight is on.
eVTEC is offline   Reply With Quote Quick reply to this message
Old April 30th, 2006, 01:42 PM   #5
My Third Accord!
acb384's Avatar
Send a message via AIM to acb384 Send a message via MSN to acb384
if you used a wiring harness from a depot (ebay) kit then the relays are incorrect and the headlights have to be off
acb384 is offline   Reply With Quote Quick reply to this message
Old April 30th, 2006, 04:57 PM   #6
-Brian
NexsoN's Avatar
turn ur highbeams on (with ur headlights) and see if they come on.
Old May 1st, 2006, 03:17 PM   #7
mikenjulie2's Avatar
If the foglights are from Vertex, and the foglight do come on with your high beams. Then you need to replace the relay. I had the same situation.
http://www.hondaautomotiveparts.com/...5=FOGLIGHT+KIT
There is the link to Majestic Honda, where i bought the relays. Supposedly you only need one, I believe it's RC2201, but I bought both to be sure. Yeah it's another 80 bucks, but since I only paid 85 for the kit, it was still cheaper than the OE fogs. If you have any questions you can drop me a message. Also if you search Vertex Racing I think my previous post is there regarding this issue. Once that relay was replaced, they work like buttah!
Mike
mikenjulie2 is offline   Reply With Quote Quick reply to this message
Old May 1st, 2006, 05:53 PM   #8
My Third Accord!
acb384's Avatar
you could just do the mod so that the fogs come on with all lights (parking,low,high.) you just have to jumper two wires together at the switch. save $80...you'll have to do a search for the details.
Old July 19th, 2006, 03:35 PM   #9
datboiroy's Avatar
Send a message via AIM to datboiroy
i just finished wiring up my fogs, everything was done from the honda instructions, when i turn on the lights, the switch lights up but when i push the switch, the on indicator doesnt come on. i grounded my wire in the front next to the hood latch, the fuse is in. could anything be wrong?
datboiroy is offline   Reply With Quote Quick reply to this message
Old July 20th, 2006, 06:48 AM   #10
lol, i installed oem honda foglights, and even the switch does not signal that it's on It's kinda sad, I followed all instructions to the letter and that damn thing doesn't work btw, is it normal that parking lights are on with the lowlights (in the low-light position)?
Anzial is offline   Reply With Quote Quick reply to this message
Old July 20th, 2006, 01:59 PM   #11
datboiroy's Avatar
the switch or the fog? i just found out what my problem was, i forgot to connect the 3pin connector, i thought that was there for future if i wanted to hook something up. are you talking about ur parking lights comin on with ur lowbeams? ya thats normal.
Old July 20th, 2006, 02:56 PM   #12
neither switch nor fogs light up, I tried all possible combinations... I guess i need to go thru it again, check for possible screwups
btw, anyone knows where exactly that corrugated tube is supposed to go to? I didn't find the place instructions were referring to, so I skipped that step
Old July 20th, 2006, 05:00 PM   #13
well, i got it finally - it was the 6pin underdash plug.. I plugged it into the fuse box upside down, couldn't see there very well Now I finally have a set of working fog lights Now, onto the next stage - retros
Old July 21st, 2006, 10:47 PM   #14
datboiroy's Avatar
heres a couple pics i took........
Old July 21st, 2006, 11:06 PM   #15
JDM FTW!!!11one!
JBLAccord's Avatar
turning on fogs without headlights
click that link, follow instructions, enjoy your working fog lights. i went thru the same problem with the aftermarket fog kit and after looking around for a few days found this info on another forum. i tried it out and voala it worked.
JBLAccord is offline   Reply With Quote Quick reply to this message
