Factory amp - Honda Accord Forum : V6 Performance Accord Forums
Old May 17th, 2006, 12:59 PM   #1
Factory amp
Quick question, does the 7th gen have a factory amp under the back seat or near the car jack (ala Acura CL)? or is the amp built-in the head unit?
dozorca is offline   Reply With Quote Quick reply to this message
Old May 17th, 2006, 01:03 PM   #2
registered n00b
sumptimwong's Avatar
No amp. HU sends out 30W peak on some models, and 45W peak on the EX HU, I believe.
- wong
Old May 17th, 2006, 01:15 PM   #3
Top Gear Baby!
OrangesOfCourse's Avatar
Send a message via AIM to OrangesOfCourse
i think only on the 6MT as that is the only one with 180watt(?) system.
OrangesOfCourse is offline   Reply With Quote Quick reply to this message
Old May 17th, 2006, 01:26 PM   #4
Yeah, I don't think there is an external amp either. The head unit just has a little higher peak output. Its likely nothing to brag about either. Peak power ratings are pretty much useless, I prefer root mean square/continuous ratings to determine the capability of an amplifier. For some reason, car stereo equipment is the worst for misleading specifications, IMO.
TheDuggler is offline   Reply With Quote Quick reply to this message
Old May 17th, 2006, 01:33 PM   #5
-Brian
NexsoN's Avatar
hehe then whats that big silver thing?
Old May 17th, 2006, 03:23 PM   #6
registered n00b
In the trunk, you mean? I could be your nav control unit.
- wong
Old May 17th, 2006, 03:41 PM   #7
Thanks for the info guys... was hoping to attach my remote-wire from the amp to the factory amp (if there actually was one)...
thx again.
Old May 17th, 2006, 03:43 PM   #8
registered n00b
The remote power wire for an aftermarket amp hookup has been discussed here several times, see if a search will uncover that info.
Two common places to tap for remote power: 12v cig lighter (in center console) and A/C fuse (in-cabin fuse slot #30, I believe).
- wong
Old May 17th, 2006, 03:49 PM   #9
Saw this on Acura CL... thought it could work for us...
http://silverknight.clickhere2.net/sound.html
Old May 17th, 2006, 05:10 PM   #10
6MT
SlayerGTR's Avatar
i used to have a auto and i swapped to a manual, thats a 120 -> 180 watt experience and i must say, the 6MT sounds much better
highs are more crisp and i can hurt my ears if i blasted it loud enough w/ treble maxed out
Old May 18th, 2006, 10:57 AM   #11
03ondubs's Avatar
I ran my remote wire to the fuse for the passenger window. It works as a custom bass switch,
lock ur windows for no bass- killing the power to the wire
unlock it for the bass to kick on-giving the wire power
03ondubs is offline   Reply With Quote Quick reply to this message
Old May 18th, 2006, 10:57 PM   #12
registered n00b
LOL, great idea =)
- wong
Old May 20th, 2006, 02:22 AM   #13
This is how mine is and I love it... great idea. Whenever I'm sitting in the car, I'll kill the amp. Is there a way to turn up the master volume on the stereo, and I don't mean the volume knob master volume
MysterGoode is offline   Reply With Quote Quick reply to this message
Old May 26th, 2006, 01:15 PM   #14
how do you tap the remote power to the cigarette lighter?
kimds is offline   Reply With Quote Quick reply to this message
Old May 26th, 2006, 05:53 PM   #15
A friend of my was testing the fuses for power and he attached the remote-power cable to one of them. I wasn't sure which one. So for about a week, I was driving around, and then I wanted to play a joke on my friend and disable the back windows and what do you know...the amp turned off
Great tip.
