NAV Ipod Install Question - Honda Accord Forum : V6 Performance Accord Forums
Old June 30th, 2006, 07:46 PM   #1
6MT
SlayerGTR's Avatar
I got navi and I took everything apart.
I read the DIY http://www.beaufordbuddy.com/ipod_install_5.htm
but I can't seem to find the plug since I got NAVI. Anyone here w/ navi got a DIY or know how to reach the plug? I'm gonna unplug my XM and just use the USA Spec.
Thanks
Old June 30th, 2006, 07:54 PM   #2
It says it works with the factory navi
http://www.logjamelectronics.com/blitzhonauxdmxv2.html
Old June 30th, 2006, 09:03 PM   #3
6MT
SlayerGTR's Avatar
i been aware it works
i'm wondering how others have accessed the XM plug... cuz I can't seem to reach/see/find it w/ my eyes.
Do I need to pull out navi? or perhaps is there some secret techique used to reach the plugs that i'm not aware of?
Old July 1st, 2006, 10:09 PM   #4
I have an 2004 w/Navi and you have to remove the radio to get the XM plug for your IPod.
I had the same question too because I think the non-Navi cars the XM connector is under the big center box (you have to remove that box to get to it), but the Navi units are not as easy
You can use this link to see how to remove the parts on the car:
http://handaaccessories.com/accord/03-dvdwmoon.pdf
Basically once you get the center counsil and glove bax area apart there are 2 bolts under the radio that come out and you need to pop off/up the top vents and there are 3 screws on the of the radio that need to come out...then it should come out.....
Hope this helps
JGS93GT is offline   Reply With Quote Quick reply to this message
Old July 1st, 2006, 11:49 PM   #5
6MT
SlayerGTR's Avatar
thanks a bunch I'll attempt this monday
MY LAST MOD. I am done.
Also, did u have to pull whole navi out? or just enough to unplug?
I'm really lazy. I pulled everything out except navi at 1st. I didn't even remove my shift knob or anything lol. I left everything plugged in.
