7th gen Bulb Replacement List - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 7TH GENERATION HONDA ACCORD (2003-2007) > 7G HONDA ACCORD FAQ
Like Tree1Likes
  • 1 Post By 03LXV6Guy
Old March 24th, 2004, 09:40 AM   #1
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Cool
7th GEN. BULB REPLACEMENT LIST
EXTERIOR LIGHTS
Headlights
Low Beam - 9006 (HB4) (51W)
High Beam – 9005 (HB3) (60W)
Fog Lights (oem accessory)
Coupe & Sedan – H11 (55W)
Front Turn Signal/Parking Lights
Coupe & Sedan – 1157A (amber) (27W/8W) (24CP/2.2CP)
Brake Light/Tail Lights
Coupe – 7443 (clear) (21W/5W) <--- ***Needs Confirmation***
Sedan – 7443 (clear) (21W/5W)
Tail Lights
Sedan – 194 (4W) (2CP)
(Note: No separate tail light on coupes.)
Rear Turn Signals
Coupe – 7440 (clear) (21W)
Sedan – 7440A (amber) (21W)
Third Brake Light - In rear window
Coupe & Sedan – 7440 (clear) (21W)
LED Third Brake Light – On oem wing
Coupe & Sedan – ???
(Note: It’s warranted by Honda.)
Reverse Lights
Coupe – 921 (clear) (18W) <--- ***Needs Confirmation***
License Plate Light(s)
Coupe & Sedan – 168 (5W) (3CP)
(Note: 2 bulbs used on coupes, 1 bulb on sedans.)
INTERIOR LIGHTS
Overhead Light (aka Dome Light)
Coupe & Sedan – DE3022 (8W)
Maplights
Door Courtesy Lights
Coupe & Sedan – 194 (4W) (2CP)
Glove Box Light
Coupe & Sedan – 194 (4W) (2CP) <--- ***Needs confirmation***
Vanity Mirror Lights
Coupe & Sedan - ??? (1.1W)
(Appears to be a special Honda bulb (# TS-14V10P). Looks like a fuse. Available at Honda for only $9.)
Ash Tray Light (oem accessory)
Coupe & Sedan - 74
Trunk Interior Light
Industry standard bulb numbers are given.
Additional information such as color, aliases, W (watts) or CP (candlepower) is provided when known.
***Needs Confirmation*** MEANS __ I believe the bulb listed is correct, but it really needs a confirmation. If a coupe owner will actually confirm the info, I will update the list. Please, no assumptions, guesses, or “should-be-the-same-as”s.
Regarding 168 vs. 194 interchangeability…….They are not the same bulb. They are the same physical size and fit in the same holder, but they are not the same bulb. A lot of people use them interchangeably, but they really are different bulbs. (Think about standard household bulbs.... the 40 watt and 100 watt fit the same holder, and are the same physical size, yet they are different bulbs. Same principle here.)
The 168 is a .35 amp, 4.9 watt, 3.0 scp (spherical candle power) bulb.
The 194 is a .27 amp, 3.8 watt, 2.0 scp bulb.
In other words, the 168 is a 29% to 50% brighter/more powerful bulb (depending on what spec you're comparing).
Mods - I feel my first sticky coming on. Am I worthy of stickyness?
Randomhero likes this.
Old March 24th, 2004, 08:07 PM   #2
NightShift's Avatar
Send a message via AIM to NightShift
Re: 7th gen Bulb Replacement List
7440 for the coupe's rear turn
$9 for a stupid bulb that small?
Yes make this thread a sticky!
AMS
OIL Dealer&mpt=[CACHEBUSTER]">
NightShift is offline   Reply With Quote Quick reply to this message
Old March 25th, 2004, 08:46 AM   #3
03LXV6Guy's Avatar
That is a clear bulb, isn't it?
Old March 25th, 2004, 03:45 PM   #4
_________________________
DaveDB's Avatar
Good post. Sure wish the owner's manual were as complete.
DaveDB is offline   Reply With Quote Quick reply to this message
Old March 25th, 2004, 03:54 PM   #5
C'mon, sticky this quick!!!!! We don't want it to drop off the first page in a year or two with all the posts here.
j/k, great post! It really should be a sticky, just in case this sub-forum gets crowded.
sami is offline   Reply With Quote Quick reply to this message
Old March 25th, 2004, 07:02 PM   #6
NightShift's Avatar
Yea, the coupes have a red turn signal lens...
AMS
Old March 25th, 2004, 07:17 PM   #7
I AM LOST....
brex's Avatar
bumb for sticky.. good job...
Old March 26th, 2004, 07:26 AM   #8
03LXV6Guy's Avatar
Originally posted by DaveDB on March 25th, 2004 at 05:45 PM
Good post.
Thanks.
I hear ya. The owner's manual is about useless concerning bulb data.
Old October 1st, 2006, 10:53 PM   #9
St. Louis!
Kingof3rdinput's Avatar
Great post again, used this thing like 20 times.
Old November 6th, 2006, 09:23 AM   #10
I want to buy yellow H11's bulbs to replace the stock bulbs in my OEM fog lights (04 coupe)...anyone have experience with this ??? I've searched and haven't come across a thread that addresses bulb replacement in the stock fogs...any help would be greatly appreciated!! Buying two bulbs for $10 is a helluva lot cheaper than buying the yellow fog after market replacements on ebay...plus i already have the stock wiring and switch.
kaldereta is offline   Reply With Quote Quick reply to this message
Old November 6th, 2006, 01:02 PM   #11
girl powah!!
03aV6cpe's Avatar
I think most people here use the nokya h11 bulbs, some use piaa, etc... try searching in the show mods section, you'll have better luck there
