Wiring Colors Guide - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 7TH GENERATION HONDA ACCORD (2003-2007) > 7G HONDA ACCORD FAQ
Old April 8th, 2004, 04:17 PM   #1
Wiring Colors Guide
2003 Honda Accord
Code:
FUNCTION .... WIRE COLOR .... POLARITY .... LOCATION
12volts .... white .... + .... ignition harness
Starter .... black/white .... + .... ignition harness
Ignition .... black/yellow .... + .... ignition harness
Accessory .... black/red .... + .... ignition harness
Second Accessory .... white/red .... + .... ignition harness
Keysense .... red/white or red/black .... - .... ignition harness
Power Lock .... pink/black .... - .... grn plug, L side of fusebox
Power Unlock .... pink/blue .... - .... grn plug, L side of fusebox
**These wires will meter while using the passenger door lock switch.
Lock Motor .... yellow/black .... 5wi .... grn plug, front of fusebox
Unlock Motor .... yellow/green .... 5wi .... grn plug, front of fusebox
Disarm Defeat .... yellow .... 5wi .... large wht plug above fusebox
Parking Lights+ .... red/black .... + .... large wht plug above fusebox
Parking Lights- .... black/red or blue/red .... - .... in steering column cover
Hazards .... green/red .... + .... large wht plug above fusebox
Turn Signal(L) .... red/blue .... + .... large wht plug above fusebox
Turn Signal(R) .... brown .... + .... large wht plug above fusebox
Door Trigger .... green/red .... - .... grn 5 pin plug behind fusebox
Trunk/Hatch Pin .... blue/black .... - .... driver kick, harness to rear
Hood Pin .... yellow/red .... - .... hood pin switch in latch
Trunk/Hatch Release .... yellow/green .... + ..... driver kick, harness to rear
Factory Alarm Arm .... white/red .... - .... driver door module in door
Factory Alarm Disarm .... white .... - .... driver door module in door
Disarm No Unlock factory alarm disarm
Tachometer .... blue/red or blue .... AC .... ECM/PCM
**The ECM/PCM is on the front of the transmission tunnel.
**The connectors are on the passenger side.
**On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25.
**On the 6 cylinder models it is in the gray connector A, pin 23.
Horn Trigger .... green/yellow .... - .... steering column
Speed Sense .... blue/white .... ECM/PCM
**On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
**On the 6 cylinder models it is in the gray connector A, pin 11
Wipers .... blue (L), yellow (H) .... - .... windshield wiper motor
LF Window up/dn .... red/black - red/yellow .... LF window switch in door
RF Window up/dn .... red/blue - red .... RF window switch in door
LR Window up/dn .... red/white - blue/black .... LR window switch in door
RR Window up/dn .... red/white - blue/black .... RR window switch in door
Sun Roof open/close .... green/yellow - green/black .... moonroof motor, rear of roof
**Only on the sedans.
**Coupes: the moonroof motor is integrated into the moonroof control unit not allowing
**access to the motor wires.
Radio 12v .... white/green .... + .... radio harness
Radio Ground .... black .... - .... radio harness
Radio Ignition .... yellow/red + .... radio harness
Radio Illumination .... red/black .... + .... radio harness
Power Antenna .... yellow/green .... + .... radio harness
LF Speaker +/- .... green/black - lt. green .... radio harness
RF Speaker +/- .... grn/yel - gray or gray/red .... radio harness
LR Speaker +/- .... blue/white - blue/black .... radio harness
RR Speaker +/- .... pink - blue/yellow .... radio harness
Old September 23rd, 2016, 08:53 PM   #2
Hope you can help. I own an 07 v6 6mt sedan with navigation. I was pulling my work gear out of the trunk today and noticed a grey connector hanging down from the rear deck that has 2 wires. The first wire is a green/red wire with silver dots and the second is a green/yellow stripe. I climbed into the trunk (not fun when old and fat) and looked at the back of the DVD reader for an outlet, thinking that it simply got knocked out. Nothing. On closer inspection I saw that there are 2 pieces of electric tape on the wire harness that look like they had gotten cut but were in about the right spot for this wire to be retained at. My question is, what is this connector for? Is there an accessory that is meant for or is this a diag port? I also noticed that there is what looks like an empty plastic box next to the DVD unit that this cable could potentially reach.. I thought that I had every option that was offered in 07 with the kick ass 6 speed. Am I wrong?
Yuppyyoda is offline   Reply With Quote Quick reply to this message
