7th Gen Accord TSB's (PDF Files) - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 7TH GENERATION HONDA ACCORD (2003-2007) > 7G HONDA ACCORD FAQ
Like Tree1Likes
Old April 26th, 2004, 01:17 PM   #1
Northcoast Tuner
Exclamation 7th Gen Accord TSB's (PDF Files)
Okay, here is the new thread with all the TSB's I have, posted in one thread instead of many (thanks to willshire for making me do all this extra work )
I will update these as I come across new ones.
Last update 7/16/04
TSB 02-002 - Squeak at the Clutch Pedal (notchiness when shifting)
TSB 03-007 - Headliner Sags in the Back
TSB 03-017 - Factory 6-Disc Changer does not load, play, or eject
TSB 03-018 - Rattle Fron the Rear Shelf
TSB 03-019 - Wipers Smear or Streak the Windshield
TSB 03-029 - Accord V6 Multiplex Integrated Control Unit
TSB 03-035 - Door Window Molding is Wrinkled
TSB 03-036 - Vehicle Drifts to the Right
TSB 03-037 - Roof Molding Channel Leaks Water
TSB 03-040 - EVAP Canister Drain Joint
TSB 03-041 - Accord L4 Multiplex Integrated Control Unit
TSB 03-042 - Accord L4 No Reverse
TSB 03-043 - Intake Air Breather Pipe Separates
TSB 03-057 - Wind Noise at Front Window
TSB 03-058 - Creaking or Popping When Accelerating or Decelerating
TSB 03-069 - Front Brake Noise or Judder
TSB 03-070 - PCM Update with Automatic Transmission Replacement
TSB 03-079 - Long Crank Time or Hard Starting
TSB 03-085 - Wind Noise From Upper Rear Corner of Front Door
TSB 03-091 - Sulfur Smell in the Interior
TSB 04-012 - Brake Pedal is Hard to Press at Start-Up
TSB 04-017 - Lumbar Support Does Not Work
TSB 04-020 - Product Update : Out-of-Specification Automatic Transmission Case
TSB 04-023 - Right Side Trunk Trim Panel Hangs Down or Does Not Fit Properly
TSB 04-024 - 03-04 A/T Engine Vibrates While Idling in Gear
TSB 04-026 - ABS Light Comes On
TSB 04-037 - Recall : Accord V6 Automatic Transmission Second Gear Inspection
http://members.cardomain.com/josephip
Old April 26th, 2004, 01:27 PM   #2
The Poker KING
good looks mayne
'preciate it.
2003 SBP Honda Accord EX V6 Coupe
OEM Aero Kit
OEM Rear Wing Spoiler
OEM Navigation
AEM V2 CAI
TL-S Rear Sway Bar
Tein H-Tech Springs
Ingalls Rear Camber & Toe Kit
35% Tint
Old April 26th, 2004, 01:33 PM   #3
sami is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 01:46 PM   #4
_________________________
DaveDB's Avatar
DaveDB is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 01:52 PM   #5
Great work.
Thanks!
APOLLON is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 03:39 PM   #6
Excellent.
Thank you very much!!!
ahngo is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 04:26 PM   #7
Thanks! This will be very useful for some.
willshire is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 05:22 PM   #8
The Poker KING
I can swear my car has the 03-058 TSB problem, but my VIN is not listed, the TSB ends with the 22xxx, and mine is in the 23xxx, if I ask my dealer to still check it out, you think they might fix it? This has happened to me many times, like it's rubbing against something, hmmm.
I already got 6 TSBs that my VIN falls into place, lol.
OEM Aero Kit
OEM Navigation
AEM V2 CAI
TL-S Rear Sway Bar
Tein H-Tech Springs
35% Tint
Old April 26th, 2004, 08:12 PM   #9
Northcoast Tuner
The VIN #'s are more of a guideline. When the cars are produced, they have no idea that these problems will arise. What they do is study the statistics of people who complain about problems, like the brake rotors warping, and if it turns out a lot of people are having similar problems, they will issue a TSB. VIN #'s on the TSB may be calculated from the frequency of problems within a similar range, or if a certain part from a certain lot is known to be defective, the VIN #'s listed may be the cars produced that use that certain part from that certain lot. It does not mean that if your VIN falls into that range that your car will DEFINITELY develop that problem, nor does it mean that if your VIN is excluded from that range, that you will NOT develop that problem. TSB's are updated on an ongoing basis, and many times the VIN range will increase as more cars report the same problem. It's basically a gudeline for predicting the PROBABILITY of a cetain problem occurring in a certain VIN range. So if your VIN is included in a TSB, it does not mean that the dealer is obligated to replace any parts if you are not showing symptoms of the problem, and if your VIN is NOT included, it does not mean that the dealer will NOT fix your problem if you DO have one.
Hope this clarifies things
Old April 26th, 2004, 08:19 PM   #10
Eccenpix
Eccen's Avatar
You are the man... !
hmm you are a 'man' right?
2003 Honda Accord 2.4L | 2013 Hyundai Santa Fe 2.0T AWD
Eccen is offline   Reply With Quote Quick reply to this message
Old April 26th, 2004, 08:31 PM   #11
Northcoast Tuner
Haha I was last time I checked
Old April 26th, 2004, 08:32 PM   #12
The Poker KING
Josephip, great explanation, I got it now.
By the way, how did you get the PDF files on all these?? or is that top-secret information? I was just wondering cause on the ODI website, they list the TSB's, but not the PDF files.
OEM Aero Kit
OEM Navigation
AEM V2 CAI
TL-S Rear Sway Bar
Tein H-Tech Springs
35% Tint
Old April 26th, 2004, 08:32 PM   #13
Senior Moderhater
abram2001's Avatar
stickied
Old April 26th, 2004, 08:36 PM   #14
Northcoast Tuner
Originally posted by abram2001
stickied
Thanks abram2001
Took a lot of searching to get all of them. Honda does not want them released to the public, so I just acquire them here and there. I've been keeping an ongoing collection of them since September of 2003 when I bought my 03 Accord.
edit: Also, if you have a specific TSB # that is not posted yet, let me know and I will try to get it.
Old May 2nd, 2004, 12:40 PM   #15
YOU SO RULE! This was the most useful post I have ever seen here. All these little problems that I thought I was going crazy with...wiper streaking, wind noise in the door, clutch pedal popping...now off I go to get it all fixed.
Oh, BTW, is there a TSB about the center compartment outlet not working?
Snatchface is offline   Reply With Quote Quick reply to this message
Old May 7th, 2004, 12:17 AM   #16
josephip
Thanks for the TSB'S
Do you think you can find the one for the ignition key getting warm. I think the # is 603, but that doesn't look the same as the rest of the TSB'S.
Mine is going in as soon as the parts come in for
Hard starting
Rattles in both front doors with windows down
Wind noise at both the front & rear of the front door glass
Noise in the right side of dash panel
The ones they could not find, because the noise only happens when the body is cold and the weather has been hot here in SoCal are
Rattle in the steering column
Instrumant cluster hood rattle
Noise in the a-pillars
Thanks again for the TSB'S, they have been a help.
Tim
never stock is offline   Reply With Quote Quick reply to this message
Old May 7th, 2004, 02:12 AM   #17
nice, very nice =D
thanks alot.
hehe we're going to have a field day at the dealership
avenger408 is offline   Reply With Quote Quick reply to this message
Old May 9th, 2004, 03:51 PM   #18
josephip
I have more info on the warm key TSB. The date is 6/16/03 & the NHTSA # 10003204. There is also a TSB called GRADE LOGIC CONTROL INFORMATION, # 06-0103, NHTSA # 10002699. This might have something to do with another problem I am having intermittantly that Honda can not find. On rapid acceleration, not wide open throttle, the trans will delay for 1 to 2 secs, down shift from 5th to 4th then to 3rd then open the throttle and then the rpm will come up and your off. This happens between 45-70 mph when running in 5th gear.
I am getting the front door rattle fixed and will try to get Honda to give me a copy of the TSB. It has #11-1703
Thanks Tim
Old May 10th, 2004, 12:23 AM   #19
Northcoast Tuner
I will try to get a hold of those for you
Old May 10th, 2004, 08:52 PM   #20
josephip
I talked to the dealer today and they found the warm key TSB. It basically says that the shift interlock solenoid is located in the column next to the ignition lock cylinder, the heat from the solenoid warms the lock cylinder & key, the warm key is a normal condition. My key gets very warm when the car is driven for a long time.
Tim
Old May 10th, 2004, 11:17 PM   #21
The Originator
Josephip, i just wanted to say GREAT POST...I HAVE 10 of these problems....too many to mention....:-p, but im hoping that i can get them fixed some time soon, after i get my lil fender bender fixed and my dvd and lcd installed :-d, For one of the problems they said that they had to replace the transmission, but it was a rebuilt one, and im guessing this means a refurbished one? But yea, i guess, if I dont think theres anything wrong with it, it shouldnt be fixed, even though its on the list right?..iono...
dj mikel is offline   Reply With Quote Quick reply to this message
Old May 11th, 2004, 02:51 PM   #22
There is also a new TSB for 4 cylinder Accords and Engine Vibration.
I guess there is a new kit out that has new engine mounts to take care of the vibration (really felt when AC compressor kicks in).
My dealer said it just came out and they have engine mounts on order for me. It would be good to see the actual TSB so I can make sure everything is done.
Bryan
bacevedo is offline   Reply With Quote Quick reply to this message
Old May 13th, 2004, 10:20 PM   #23
Northcoast Tuner
Bryan
It's there now
Old May 13th, 2004, 10:27 PM   #24
Eccenpix
Eccen's Avatar
you da man josephip!! btw, where do you get all this TSB?
Old May 14th, 2004, 10:29 AM   #25
Yes! Thank you!
My car is at the dealership now having the full kit installed.
My advisor was right that it had just come out when I took it to them last week. The date is 5/4, and I think I took it to them on 5/4 or 5/5.
I hope you don't mind that I put a link to the TSB on vtec.net, because I have a post over there about this TSB and people wanted info on it. If you would like I can remove it from there.
Thanks again!
I too want to know how you are getting the pdf files - I am guessing you have access to the actual Honda website where these are stored. I can't remember the URL, but I know it was a Honda website that you have to pay for. It is meant for techs (presumably at non-Honda shops, so they can look up the same info for fixing cars.)
Bryan
Old May 14th, 2004, 05:23 PM   #26
Northcoast Tuner
I actually get them from a bunch of places. Sometimes I search the internet, sometimes people e-mail them to me. I have a brother who works for an insurance company and a couple friends who work at dealerships so people just send them whenever they come across them, or sometimes I have to look for them, but whenevr I get new ones, I'll post them just so I'm sure there are extra copies floating around in case I lose mine
Old May 19th, 2004, 10:30 AM   #27
Clueless Newbie
GraphiteI4's Avatar
What exactly do they mean by vibration in the I4 Accords? I think I might have that problem - I just never have frickin' time to take it to the dealer. (They always seem to drag their feet) I don't have excessive vibration the entire time - however, when at idle I feel it vibrate every 20-30 seconds like the fan kicks in or something, then vibration goes away.
GraphiteI4 is offline   Reply With Quote Quick reply to this message
Old May 19th, 2004, 10:47 AM   #28
Yep - that's the exact vibration I have and still have after the TSB was applied to my car. The TSB seemed to make it a little less, but it is still there and noticable. I will have the dealer look at it again at my next service and make sure the TSB was applied correctly or that there isn't anything wrong with my AC compressor.
It only does it when I have my AC on and the compressor kicks in. My car vibrates pretty bad. I can feel it in my butt and my seat back and through the steering wheel.
Besides the problems with the brakes, this is the only problem that really is dissapointing. I can live with the rattles and the squeaks, but the vibration is only going to get worse as the car ages.
Bryan
Old May 19th, 2004, 10:54 AM   #29
Clueless Newbie
GraphiteI4's Avatar
Bryan
Hey Bryan - thanks for the response. And yea it was only with the AC on. My dad owns the exact same car as I do and his definitely does not do it (although his VIN falls under the ones listed) But I can feel it exactly like you can though. Guess I'll have to get off early tomorrow to make an appointment.
2004 LX I4, Graphite Pearl
Satin Interior / TL rear sway / Type-S Front Speakers / Dynamat Xtreme / Infinity Basslink / Pioneer DEH-P7700MP
Old May 25th, 2004, 10:16 AM   #30
Thanks josephip! I love printing out these TSBs and handing them to the service manager. I think they actually appreciate it because they don't have to figure out how to fix it- I've already done their homework for them.
