Whistling Intake? - Honda Accord Forum : V6 Performance Accord Forums
Old September 19th, 2003, 12:33 PM   #1
Whistling Intake?
Anybody elses intake have a slight whistling noise that happens at the lower rpms like around 2,000-3,000? I checked all the tubes and fittings and everything seems fine, didn't check the filter yet though. wanted to make sure there was a problem before I go through the process of taking the bumper off. I've got a AEM cai. One more thing, I did notice it sometimes with the stock airbox.
JoeySmallz is offline   Reply With Quote Quick reply to this message
Old September 19th, 2003, 12:36 PM   #2
I have that same sound too. Im assuming its normal. didnt do any damage nor lose hp.
ScorpiOxNY is offline   Reply With Quote Quick reply to this message
Old September 19th, 2003, 01:02 PM   #3
KFL
Batmobile
KFL's Avatar
Send a message via AIM to KFL
normal.
KFL is offline   Reply With Quote Quick reply to this message
Old September 19th, 2003, 01:06 PM   #4
Cool, I was thinking about resetting my ecu too, anybody do it when they put the intake on?
Old September 19th, 2003, 01:54 PM   #5
I reseted my ecu because i took out the battery when I installed it. I also have a Injen CAI and I don't have a whistling noise but my friend does on his car with the AEM CAI.
edge genius is offline   Reply With Quote Quick reply to this message
Old September 19th, 2003, 02:00 PM   #6
03 AV6 Coupe
hondav6's Avatar
its normal
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old September 19th, 2003, 03:43 PM   #7
fonda my honda
Send a message via AIM to tx03coupe
i have injen and it does whistle. is there any way to get rid of it? what's an easy way to reset the ecu w/ out disconnecting the battery?
www.crushkerry.com
tx03coupe is offline   Reply With Quote Quick reply to this message
Old September 19th, 2003, 03:59 PM   #8
I think disconnecting the battery is the easiest way, other wise you gotta mess with the fuses and I have no idea which ones to pull.
Old September 19th, 2003, 05:33 PM   #9
03 AV6 Coupe
hondav6's Avatar
You don't need to reset your ECU. Your computer will learn the new curve after you drive it for a couple of weeks. Your ECU is easy to reset. Its under the hood in the only fuse box you can see. It shows you on the Fuse Box which one your ECU is.
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old September 19th, 2003, 05:39 PM   #10
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
I don't believe anybody has actually determined EXACTLY which fuse we should pull to reset the ecu.
Old June 19th, 2005, 02:13 PM   #11
I got the same sound and was getting ready to post about it but i was searching around and guess what! i found this thread, search is a great thing ain't it?
wicked400ex is offline   Reply With Quote Quick reply to this message
Old June 19th, 2005, 02:17 PM   #12
oSCaR
v6_ccord_2k5's Avatar
i noticed it since the day i got it installed... but i thought it sounded kinda cool so i dont really wanna fix it, . kinda sounds like a turbo spooling or somethin... mine does it when i barely have my foot on the gas. some of my friends have noticed it too...
Old June 19th, 2005, 03:09 PM   #13
pitabread's Avatar
that's how a intake sounds
pitabread is offline   Reply With Quote Quick reply to this message
Old June 19th, 2005, 08:34 PM   #14
St. Louis!
Kingof3rdinput's Avatar
I like tapping on it real quick. It does kinda sound like a turbo.
Old June 20th, 2005, 12:05 AM   #15
Banned
Lxcord's Avatar
Bah CAI,
i love my SRI, at wot my car sounds a lot like a cammed LS2....
God, i love these J-series engines.....
Old June 20th, 2005, 01:00 AM   #16
_
0430Steve's Avatar
noise is normal
Old June 20th, 2005, 08:34 PM   #17
I have the aem V1 and it makes it only a certain rpm range and at a certain thorttle position. but yeah i love that sound
n2accord is offline   Reply With Quote Quick reply to this message
Old June 20th, 2005, 11:06 PM   #18
get'cha roll on...
v6SicksSpeed's Avatar
same exact thing-- def like the way it sounds.
is there any pattern to those of us that have it vs those that dont. not all people with the cai get it. i have a 03 6spd w/ injen rd cai and borla exhaust. for those of you that have it, what other I/E combos are you running?
Old June 20th, 2005, 11:11 PM   #19
with mine it only happens when the engine is cold.. and i usually let it warm up before driving so i dont hear it that often. but once the engine is warm the wistling becomes much quieter. I figure its just normal. btw i have a v2
BasicAV6 is offline   Reply With Quote Quick reply to this message
Old June 20th, 2005, 11:28 PM   #20
oSCaR
i just have the V2
you might be right, ill testify to that as soon as im able to check on it... sounds reasonable thou...
Old June 21st, 2005, 12:30 AM   #21
I feel da need 4 6-speeds
flyvtec's Avatar
I have the V2/Comptech set up and I don't hear a whistling sound. I do hear a psssst sound when I shift gears and that addicting grrrrrrrr sound at WOT...but no whistling.
Old June 21st, 2005, 02:37 AM   #22
_
0430Steve's Avatar
i have the injen rd, and no other performance mods. mine makes the noise at 2500rpm or so, whistling. it also makes 2 different noises when i turn it off. i was wondering who has which noise.
mine usually makes a cough like noise a second after you turn off the car. occationally in the morning, or if i don't run the car long it makes a reverse like exhale, or like its breathing slows and stops. my friends rsx with aem cai makes the second, which i like better, don't really care for the cough. would rather have the sucking noise.
which does yours make and when, which intake?
^^^hell yeah padres
Old June 21st, 2005, 09:10 AM   #23
Wheelgap = sleeper mod
mbr311's Avatar
^^^hell yeah padres
Mine's the same way, its totally normal. I have the AEM CAI V1 and it whistles at about 2500rpms and when I shut it off, its like a release of air/cough noise as you described. I heard both noises on the RSX-S when I had it as well. Totally normal.
Syracuse Orange 15-0, #1 AP/ESPN/USA
Old June 21st, 2005, 12:13 PM   #24
_
0430Steve's Avatar
i wasn't worried about it. i was just wondering who else has either of the noises and which intake you have.
this is for everyone to answer......does your intake cough or suck/blow air when you turn your car off? which intake you got?
my injen cai usually coughs, sometimes sucks, like my buddy's rsxs with aem cai.
Old June 21st, 2005, 01:31 PM   #25
flyvtec's Avatar
My V2 makes a cough/fart sound after I turn off the engine.
Go Padz!!!! Jake Da Snake Peavy was brilliant last nite! BEAT L.A.! BEAT L.A.! BEAT L.A.!
Old June 21st, 2005, 01:48 PM   #26
mbr311's Avatar
My intake kind of coughs when the car shuts down. I have an AEM CAI V1
Old August 27th, 2005, 12:49 AM   #27
i have AEM sri + magnaflow cat... didn't notice any 'whistling' sounds yet..but when u floor the gas it roars? i haven't truly WOT my car (weak tranny) but ive gunned it alot.... how many times a day do u guys floor(wot) the car??? at a stoplite i gas it good but i don't floor the pedal! any spirited drivers WOT alot each day?
Old August 27th, 2005, 02:27 AM   #28
flyvtec's Avatar
I WOT a few times a day just to hear my car growl! V2 + Comptech = vrooom! vroooom! I like flooring it when merging into freeways about 90% of the time. I love the engine of our cars. The V6 is sweet.
Old August 27th, 2005, 03:22 AM   #29
_
0430Steve's Avatar
daily wot, 2nd transmission, 25k miles.
the whistling noise is heard around 2,500 rpm while cruising slowly in my car.
Old December 15th, 2005, 05:21 PM   #30
im a noob
i have the stock intake but i have a whistling noise when i go above 50. it sounds like what everyone is talkin bout so i dont know if its the same thing. not sure where the noise coming from though. i read another post bout the alternator doing the same thing. any help be awesome
droppedv6 is offline   Reply With Quote Quick reply to this message
