07 TL type S swap (j35a8) - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
Old March 24th, 2008, 01:33 PM   #1
Bobby Lane Racing
nighthawk04v6's Avatar
I've been thinking about doing this swap since my motor is burning oil and I'm going to have to take it apart either way. Since I'm still modding my engine, I have a good reason to have a spare engine on the side. Hopefully the blower bolts up directly, and I won't have to modify anything, but if it doesn't, it'll just mean i'll have to spend more than a day on the swap to modify some stuff to make it fit.. Wish me luck guys, I'm about to throw about 3 grand on this engine. =D
Old March 24th, 2008, 01:45 PM   #2
Tee-Ooh-Double-Dee
Accordian's Avatar
Good luck man! Can't wait to see the outcome. How exactly do you come by an engine that new? Totalled car or straight from Acura?
Old March 24th, 2008, 01:47 PM   #3
weezo's Avatar
good luck... pics or it didn't happened
weezo is offline   Reply With Quote Quick reply to this message
Old March 24th, 2008, 01:48 PM   #4
Bobby Lane Racing
totalled car with under 10k.
Old March 24th, 2008, 01:54 PM   #5
I thought the TL s motor wouldn't bolt to our cars?
rookie7 is offline   Reply With Quote Quick reply to this message
Old March 24th, 2008, 02:21 PM   #6
M90SC Boosting 13PSI
NVA-AV6's Avatar
I am not sure (And really doubt) the J35A8 would bolt up to our trannies, now if you can get the tranny also it would increase your chances alot.
Old March 24th, 2008, 03:16 PM   #7
Bobby Lane Racing
Paul, I'm hoping to purchase it with the tranny aswell for 3500.. Hopefully they'll budge it do that.
Old March 24th, 2008, 04:22 PM   #8
NVA-AV6's Avatar
If this does happen, any chance of seeing if the 7th gen tranny will bolt up?
Old March 24th, 2008, 04:32 PM   #9
MADE IN THE PHILIPPINES
aV6Pinoy's Avatar
<---subscribed.
aV6Pinoy is offline   Reply With Quote Quick reply to this message
Old March 24th, 2008, 04:36 PM   #10
Bobby Lane Racing
Definitely,
thats probably the first thing i'm going to try.
Old March 24th, 2008, 05:04 PM   #11
NVA-AV6's Avatar
^Pic please, lots of them.
Old March 24th, 2008, 05:06 PM   #12
NVA-AV6's Avatar
Also if it was totaled, look really long and hard at where the pass side mount bolts up on the block, they snap real easy and then it is new block time> I have gotten a few J35A5s like that dirt cheap ($500 or less) for heads, crank and rods.
Old March 24th, 2008, 06:47 PM   #13
346hp/300tq @ 4psi
04accordcpe's Avatar
ewwww nice kiet def keep us posted.
this was the swap i wanted to do originally before i bought my j32a3. i know for a fact the blower and everything will bolt right up. my only concern was, does the TL-S engine and tranny (auto or manual) fit directly into our cars? . i did alot of homework on this one and from what ive read, the TL-S subframe was redesigned, so i wasnt sure if that plays a role in fitment issues.
im also 100&#37; sure our trannys will not bolt on to any j35 engine. so i think your only chance is to swap out the auto for the TL-S 6spd. it was made exclusively to fit the TL-S, since thats the only manual available for the j35 series, in any honda/acura. i believe its beefed up interanlly to handle the added hp too . unless their is a way you can use the TL-S auto trans with your stock ecu, i dont think theres any other way to do it other than converting to a 6spd
anyways, GL with everything kiet. hope it works out for you
Old March 24th, 2008, 08:20 PM   #14
NVA-AV6's Avatar
Well, after looking at the OEM parts catalog, at least the drawings look different for the bell housing mounts, the clutch cases are different part numbers and what is pretty daming here is that the oil pan part numbers are also different, at least the 04-06TL and 03-07 AV6 shared the oil pan and several other parts including the clutch case, oil pan, rear main seal plate, among many other castings. Most of the parts are now RYE series which is completely new.
Old March 24th, 2008, 08:31 PM   #15
v not some model, my girl
99v6sedan's Avatar
ill be watching....... good luck.
Old March 24th, 2008, 09:05 PM   #16
08 Altima Hybrid....
6spNaviRacer's Avatar
$3500.00 for a j35a8 with tranny...... wow
Since my 2nd gear stopped working I've been looking at TL 6 speed tranny's and then 3.2L TL engines and I havn't come across that combo for a price that good.
6spNaviRacer is offline   Reply With Quote Quick reply to this message
Old March 24th, 2008, 10:22 PM   #17
hella flush
lilfotoman's Avatar
this is gonna be sick. cant wait. gluck kiet.
gonna get the swap plus with blower? damn!!!
post some pics up when you have time!
Old March 25th, 2008, 12:13 AM   #18
Bobby Lane Racing
thanks guys, i'm determined to do this whether it has some different part numbers or not. if I have to modify the frame a little, i'll have my buddy next door cut and reweld whatever needs to be done, but I honestly doubt that will have to happen. I think the oil pan being different might be more oil pressure related than fitment related they probably added some baffles or something to adjust to the 3.5 liter, and that I will find out soon also. The tranmission is definitely different, but I think different only because it's a better tranny and most likely rebuilt to handle the extra torque/power.(talking about the 6 speed that is as we know the auto is like a special automatic now adays) I'm sure it'll bolt right on, and if not, I will modify whatever it takes to get it in. I'm in need of a new motor, and I see no reason not to try this, especially at the price its going for. Should be worth every penny for a few extra ponies and a motor that won't burn oil like my j30a4. My goal is to get this in before redline timeattack @ california speedway in late July..
Old March 25th, 2008, 04:37 AM   #19
NVA-AV6's Avatar
Good luck, at the end of the day it is still a J block, so I also doubt you will have to modify the frame, you just may need to use the J30 engine mount castings and mounts, the one that I am concerned about and may need some work are the tranny mounts.
Now one thing that is very interesting is that they brought back the tourqe dampener from the 03 CLS, if you look ing the diagram below it is part #12. I wouls see if I could just get the entire K-Frame assembly with the engine and trans still bolted to it.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old March 25th, 2008, 04:45 AM   #20
NVA-AV6's Avatar
Is this your engine???
http://cgi.ebay.com/ebaymotors/07-Ac...QQcmdZViewItem
Old March 26th, 2008, 02:24 PM   #21
Bobby Lane Racing
you could call that my engine Paul, I'm paypaling him tonight once I transfer funds over to the business account. 3500 w/ tranny.
stay posted everyone, 1st TL-Type S 6 speed swap coming up.
Old March 26th, 2008, 02:35 PM   #22
Holy Crap! Fawking Awesome!
V6MT26 is offline   Reply With Quote Quick reply to this message
Old March 26th, 2008, 04:31 PM   #23
v6 6speed's Avatar
wow dude. you are going to have a very, very fast accord.
v6 6speed is offline   Reply With Quote Quick reply to this message
Old March 26th, 2008, 04:36 PM   #24
Bobby Lane Racing
hopefully break the 400chp barrier on the dynapack with 4lbs of boost.
Old March 26th, 2008, 06:54 PM   #25
J35 6Spd
woohoo!
Old March 26th, 2008, 07:23 PM   #26
99v6sedan's Avatar
400chp sounds vuuuuury nice......
Old March 26th, 2008, 11:00 PM   #27
Adventure is out there!
littletruong's Avatar
looks like i've been missing out! good luck with the swap! hope everything works out.
Old March 27th, 2008, 12:02 AM   #28
AccordingToSean
AccordingToSean's Avatar
Send a message via AIM to AccordingToSean
be able to run with GTO's with that power.... possibly my next car in the next few weeks im praying.....
AccordingToSean is offline   Reply With Quote Quick reply to this message
Old March 28th, 2008, 04:12 PM   #29
Half-Breed's Avatar
You get that engine NightHawk? I still see it up for sale. Unless this guy has more
Half-Breed is offline   Reply With Quote Quick reply to this message
Old March 29th, 2008, 04:48 PM   #30
Bobby Lane Racing
im still talking to him about what else he has for the car, i.e ecu, wiring harness, linkages, etc. and a price, and setting up shipping. i'm trying to avoid paypal, so I don't have to pay the 3&#37;, i'm also setting up my own shipping, as his shipping company charges 300 something to get it down here, where as my shipping company will do it across the states for 150
