Got New Parts . - Honda Accord Forum : V6 Performance Accord Forums
Old April 13th, 2008, 12:46 PM   #1
Senior Member
chaqui74's Avatar
Got New Parts .
I finally made my decision and i bought a V2 intake and a Outlaw Engineering ThermoBlok Spacer Kit . Here are some pics.
Old April 13th, 2008, 01:47 PM   #2
chiefy's Avatar
good mods.. good upgrades.. whats next?
Old April 13th, 2008, 02:25 PM   #3
Senior Member
chaqui74's Avatar
Probably a Full Exhaust System.
Old April 13th, 2008, 02:45 PM   #4
Moderator
00Accord4cyl's Avatar
What wheels do you have?? i like them
Does the spacer do much for performance? if so what?
00Accord4cyl is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 03:53 PM   #5
hella flush
lilfotoman's Avatar
whats the spacer suppose to do?
Old April 13th, 2008, 04:29 PM   #6
Abailey4's Avatar
Outlaw Engineering ThermoBlok spacers are thermal insulating replacements for your stock intake manifold and throttlebody gaskets. Made from a heat blocking phenolic laminate, ThermoBlok spacers increase power from your engine by keeping the intake cooler.
Key benefits:
» Produces a cooler intake manifold and intake charge resulting in MORE POWER
» A cooler intake charge also reduces the tendency for
detonation, meaning ignition timing can be advanced for
MORE POWER
» Almost invisible modification, looks stock for the stealth factor
» Better gas mileage
» Replaces stock gaskets
» Reusable over and over
» No undesirable side effects
Courtesy of Outlaw Engineering's website
Abailey4 is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 04:53 PM   #7
Senior Member
chaqui74's Avatar
Tork Image 19x8f 19x9r. I put back on the stock wheels today .
Old April 13th, 2008, 05:14 PM   #8
Better gas mileage
Wouldn't this decrease fuel mileage? I know a lot of fuel mileage nuts have "hot air intakes" with an intake tract that takes air from around the exhaust manifold, which raises MPG. Hell, some even replace the resistor in the IAT sensor, but that only works with certain kinds.
Colder intake air = more oxygen density. More oxygen, or air, necessitates more fuel otherwise it will obviously run lean. The ECU won't allow this and will inject more fuel to make up for the excess intake. I am already starting to notice an increase in my MPG now that winter is starting to give way to spring. The reason colder intake air is better for performance is the reason why it will lower your mpg. Even my D16 Civic produces a discernable amount of torque when it's cold outside compared to warm weather.
I have seen that the Hondata intake manifold gasket gives about 5 more whp to basic Honda 4 cylinders. I would imagine that this will produce a few hp, but I just can't stand when advertisements lie about increasing your MPG. The only way I can see this happening, is if you can modify the IAT to make it
"sense" the intake air is very hot, while the air is actually cooler because of the gasket. But that will produce dangerously lean A/F mixtures.
Somebody correct me if I'm wrong.
Accord6-6wanter is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 05:41 PM   #9
Pilot & Accord
TonyWare's Avatar
Originally Posted by Abailey4 View Post
..... Replaces stock gaskets
Their site contradicts their installation instructions that state that the spacer should be on top of the stock gasket.
TonyWare is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 07:09 PM   #10
AccordingToSean
AccordingToSean's Avatar
Send a message via AIM to AccordingToSean
wonder if its worth buying....
AccordingToSean is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 07:38 PM   #11
Senior Member
chaqui74's Avatar
Don't feel any diffrence with the v2 . I guess i need to go to the track and see .
Old April 13th, 2008, 08:17 PM   #12
Too Fast TOO FURIOUS
enigmaos's Avatar
nice job! what kind of drop?
enigmaos is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 08:17 PM   #13
99VTECCoupe's Avatar
Send a message via AIM to 99VTECCoupe
Originally Posted by Accord6-6wanter View Post
Better gas mileage
This is assuming that a "CAI" actually produces dramatically colder air than a stock air box, which is not true when the vehicle is in motion. Its main benefit is reducing the flow restrictions in the OEM airbox.
99VTECCoupe is offline   Reply With Quote Quick reply to this message
Old April 13th, 2008, 09:20 PM   #14
bigviet23's Avatar
i like the V2, hoping to get one too
bigviet23 is offline   Reply With Quote Quick reply to this message
