V2 installed -- Check Engine Light??? - Honda Accord Forum : V6 Performance Accord Forums
Old October 12th, 2008, 12:04 PM   #1
So Everything is cool until I stepped on it to hear the V2 growl. Next thing I know the Check engine light started flashing. It went off. Today i was driving on the interstate and floored to get on the on ramp and the check engine light came on and now STAYS on.
What is going on?? Any suggestions?
Thanks
05BlackedOutV6 is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 12:14 PM   #2
i would check the opening where the throttle body meets the v2...see if some plastic is stuck on the ends. if that is the case, everytime you step on it, the plastic piece or any tape would get sucked into the throttle body, throwing off the comp.
(happened to me when i bought the car, from some shady dealership....who wrapped tape around the throttle body)
thaialism is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 12:30 PM   #3
the bolt that i put in the side of the V2---i left out the O-ring on it because it was very shi**y. Think that would be a problem?
Old October 12th, 2008, 01:02 PM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
Need codes......
Old October 12th, 2008, 01:03 PM   #5
Originally Posted by NVA-AV6 View Post
Need codes......
what do you mean?
Old October 12th, 2008, 01:51 PM   #6
Tee-Ooh-Double-Dee
Accordian's Avatar
Yep, that's probably it. You're probably sucking air in and it's screwing with your sensor. I'd get a new rubber O-Ring pronto. I bet that's your problem.
Old October 12th, 2008, 02:04 PM   #7
i put like bolt sealant on the bolt instead of an O ring. I did this because when you tighten the bolt, the O ring just squishes out and serves no purpose.
Old October 12th, 2008, 02:30 PM   #8
just disconnect the battery to turn it off... then replace the O ring.
john32 is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 03:05 PM   #9
Need codes......
not everyone has access to a $5,000 OBD II scanner.... California prohibits the lending out of these scanner to customers...autozone use to do this.
Old October 12th, 2008, 03:46 PM   #10
the light actually flashes due to an emissions problem (since you put the V2 on). so it shouldnt mean anything harmful to your car.
Old October 12th, 2008, 05:05 PM   #11
other then that, maybe its coincidence and has to do with something else. i could see it being the what people are saying... Either tape or whatever sucking in when you gas it
sLoPoKe7thGen is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 05:06 PM   #12
so is this going to go on forever?? I dont think there is anything wrong with the v2, i just think it is wierd how the check engine light will not go off
Old October 12th, 2008, 05:46 PM   #13
NBP UA7
StiLLHeRe153's Avatar
Send a message via AIM to StiLLHeRe153
did you touch the coolant line and vaccum line that is attached to that aluminum bar thing... the vaccum line if run directly will yield a cel
StiLLHeRe153 is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 05:48 PM   #14
I havent had the problem since i disconnected my battery. it flashes sometimes if you step on it, but it usually goes off. i have a friend who is a honda tech. and he said not to worry about it.
Old October 12th, 2008, 06:59 PM   #15
Well ya, I re-routed the coolant and vacuum lines like the directions said. I didn't screw anything up, just placed a new hose to re-direct everything.
Old October 12th, 2008, 07:00 PM   #16
I am not worried about it, just annoyed that everytime i look down i see that dumb orange check engine light
Old October 12th, 2008, 07:28 PM   #17
Pilot & Accord
TonyWare's Avatar
Is the light flashing or is it solid? Flashing, without looking at codes based on my experiences it usualy means cylinders misfiring. Check the codes stored just to make sure.
TonyWare is offline   Reply With Quote Quick reply to this message
Old October 12th, 2008, 07:42 PM   #18
it flashes for a second and now it is solid all the time. However, when I WOT it, it flashes irregularly
Old October 12th, 2008, 07:46 PM   #19
If you're that worried about it, I would just go take it in for diagnosis, but that will cost a hundred or so just to see what's wrong. Other then that, I don't think it's a huge issue. Obviously something happened while installing, and I can't imagine it being something too harmful.
Go walk around the garage at honda and try to get someone to stick an obd scanner in it real quick lol. I've done it, cool guy.
Old October 12th, 2008, 08:16 PM   #20
J33 w/TL LSD 6 Speed
05AV6's Avatar
The flashing CEL is usually an indicator of mifires random/multiple...It happens because the Crank Position Sensor sense something it doesn't like during VTEC crossover, they do have a TSB on it I believe and replacing the sensor took away this issue in my case...as for it staying on solid, I have no idea.
Old October 12th, 2008, 08:54 PM   #21
ok lets talk english for this noobie...What is CEL, OBD, and TSB??
Old October 12th, 2008, 09:44 PM   #22
Bobby Lane Racing
nighthawk04v6's Avatar
LOL you should not modify your car if you don't know what a CEL is.
Old October 12th, 2008, 09:57 PM   #23
NBP UA7
ok ignore the coolant line but put the vaccum hose back the way it was with that metal bar you took out
I got a cel immedietly when I followed the directions, cut a hose in 2" and put it with the metal bar there and the light went away right away, i don't listen to instructions lol
Old October 13th, 2008, 12:59 PM   #24
Im 23 and this is my first Car. Ive been working on sub-'92 jeeps before this. I never had to deal with a check engine light before! ha...
Yah, those directions were some of the stupidest things ever. Ill try this on Wednesday and see if it works.. Thanks
Old October 13th, 2008, 01:34 PM   #25
Tee-Ooh-Double-Dee
Accordian's Avatar
I followed the directions to a tee and no CEL for me. Shrug.
Old October 13th, 2008, 01:49 PM   #26
Honda Rookie
pbook4g5's Avatar
http://www.restockit.com/CodeScout-7...F1&Bvar7=100F1
Not $5,000.
Old October 13th, 2008, 02:35 PM   #27
jessewhitlow's Avatar
Installed a CAI on my friends car, and the check engine light came on, got an obd 1/2 code reader and cleared the error code that was causing the check engine light, no more light, cars fine since then, pick up a code reader and save some money next time ur light comes on
jessewhitlow is offline   Reply With Quote Quick reply to this message
Old October 13th, 2008, 03:33 PM   #28
cunning linguist
MorePower4me's Avatar
Originally Posted by pbook4g5 View Post
And I just saw one for less than $40 at the local Harbor Freight (all car guys should know where the closest one of these is anyway!)
Old October 13th, 2008, 03:40 PM   #29
✔ Verified Member
otsb708's Avatar
Old October 13th, 2008, 07:01 PM   #30
Originally Posted by otsb708 View Post
I removed the "hose loom" as AEM's directions call it that contains the vacuum line and the coolant line. I redirected both lines with the hosing that came with the kit. All hoses are tight and on properly. I guess my accord just doesnt like foreign objects...
Also, how close should the intake be next to the throttle body. There is prob like a 1/2 inch gap inside the rubber gasket btween the intake and the throttle body. Should the intake be touching the throttle body or is a little space between ok?
THANKS!
