Need help with parts I need. - Honda Accord Forum : V6 Performance Accord Forums
Old October 23rd, 2008, 11:30 AM   #1
SandFanatic's Avatar
I bought a magnafuel efi 600 and regulator and need an adapter to install AN- type fittings to the fuel rails?? Anybody make any? My tuner says he can net me some gains using the adjustable regulator with my Autronic ECU.
Secondly, What brand injectors are you guys using? I see people are retrofitting alot of different kinds from other hondas but does a reputable injector company make any?
I am feeding a J35A4 boosted at 10psi.
Thanks!
SandFanatic is offline   Reply With Quote Quick reply to this message
Old October 23rd, 2008, 05:58 PM   #2
Anybody??
Old October 24th, 2008, 09:01 AM   #3
NBP UA7
StiLLHeRe153's Avatar
Send a message via AIM to StiLLHeRe153
k-series rc injectors ftw
StiLLHeRe153 is offline   Reply With Quote Quick reply to this message
Old October 24th, 2008, 10:28 AM   #4
chiefy's Avatar
pics or ban
Old October 24th, 2008, 10:44 AM   #5
jessewhitlow's Avatar
pics or ban
LMAO
jessewhitlow is offline   Reply With Quote Quick reply to this message
Old October 24th, 2008, 10:49 AM   #6
j35 psi 6sp
capnff's Avatar
rdx injectors( with modifications) or just get some RC'S. removethe stock FPR install a an fitting, run braided line to the new FPR and done. part number for the correct fitting on a j35a4 is= EAR-991945ERL
Old October 24th, 2008, 10:51 AM   #7
j35 psi 6sp
capnff's Avatar
also make sure your tuner does a good job because at 10psi on the j35 is risky. its a high compression engine. 10:1, i wouldnt pass 8psi. trust me ive popped 3 j32's and one j35 lol
Old October 24th, 2008, 01:28 PM   #8
NVA-AV6's Avatar
Get a set of rails from a 99 AV6, they will give you a good base to start with, from there I drill them out from 6mm inside to 8mm, then drill and tap and chamfer the ends for an6 o-ring fittings on the TB side and tap for 10mm banjo fittings, then to fit the RDX injectors drill out the injector holes to 9/16", then ream out to 13.5mm. Plumb up the rail;s in parallel to get full flow thru the 8mm centers since an6 is 3/8 (10mm) ID.
Old October 24th, 2008, 02:44 PM   #9
J35 6Spd
that looks liiiiiiike my car
Old October 24th, 2008, 02:59 PM   #10
NVA-AV6's Avatar
^Why yes it is
Old October 25th, 2008, 07:50 AM   #11
Thanks ALL !!!!
Exactly what I needed.
Sorry. no pics but I can tell you she hauls the mail...
Most of the hondas running offroad are at 10psi.. spanking LSx's all dayyyyyy looonggggg..... Alot of these guys are using stock computers believe it or not. I know that isn't such a big deal in the street world but in the desert we are on boost 90% of the time. I am running an Autronic and H20/Meth injection. I do notice that folks are burning up the top ends with just intercoolers. Either rings or valves but they start burning oil like a diesel. The folks that use h20/meth are not experiencing problems.
The LS owners get pissed when they realize they just got spanked by a 1500 junkyard motor...
Old October 25th, 2008, 01:38 PM   #12
Awesome.
Old October 29th, 2008, 06:55 PM   #13
Hey Capnff,
I got that fitting but not seeing where it attaches?
The stock FPR ends with a o-ringed fitting onto the FI rail. Not seeing any threads?
BTW NVA,
That is a sick setup. I am going to go to the junkyard and pick up some fuel rails and try that out. I need to try and bump my hose sizes to 8an eventually.
