Tuning J33 - Honda Accord Forum : V6 Performance Accord Forums
Old November 10th, 2008, 07:29 PM   #1
J36 - 6MT LSD
Stheman's Avatar
Tuning J33
So I'm considering upgrading to a J33. The only issue that I have left to solve is how to tune it. From what I have gathered my best bet would be to go with AEM. I was also curious an ECU out of a TL would do the trick or even the stock ecu. Any input would be appropriated.
Stheman is offline   Reply With Quote Quick reply to this message
Old November 11th, 2008, 12:19 AM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
don't waste your money on the TL ecu, just buy a piggyback. many have been tested here to be successful. we're all using emanage blue/ultimate in cali, however i'm sure a full stand alone could be wired up. just an expensive system that's all. I'll see what hondata can do for us in the coming future.
Old November 11th, 2008, 04:46 AM   #3
M90SC Boosting 13PSI
NVA-AV6's Avatar
AEM Fic FTW.
Old November 11th, 2008, 08:27 AM   #4
J36 - 6MT LSD
Stheman's Avatar
If AEM is the way to go I might do a 3.5. Can I use the j30 block or would it better to use the j32 block.
Old November 11th, 2008, 08:51 AM   #5
NVA-AV6's Avatar
J32A3 block has to be used to get to a 89mm bore, J30 block is only 86mm and can not be bored more than 1mm over and even then you can not boost it reliably after removing the material.
Old November 11th, 2008, 09:51 AM   #6
Archangel72's Avatar
Do we know for sure that the AEM FIC will stick and not de-tune? Or is this in the testing stage?
Old November 11th, 2008, 11:30 AM   #7
J36 - 6MT LSD
Stheman's Avatar
Thanks so J33 stick with the j30 and swap the crank and rods. To do the J35 go with the j32 block and have it bored to 89mm. My issue with the J32 is finding a inexpensive short block.
Old November 11th, 2008, 12:20 PM   #8
NVA-AV6's Avatar
No, the J32 block is 89mm from the factory and a new block from acura is $600.
Old November 11th, 2008, 05:36 PM   #9
J36 - 6MT LSD
Stheman's Avatar
Thanks I found it I kept looking at the short block price rather then the block ass. price. One last thing will the RL pistons fit the block without machining?
Old November 11th, 2008, 05:49 PM   #10
NVA-AV6's Avatar
05 RL pistons will, they are also 89mm
Old November 11th, 2008, 08:33 PM   #11
J36 - 6MT LSD
Stheman's Avatar
So I need an J32s3 block, 05 RL pistons, and 06 Odyssey crank and rods along with all the misc. parts bearings rings head gaskets new timing parts.
Old November 11th, 2008, 08:43 PM   #12
NVA-AV6's Avatar
Low end gasket kit....
Are you going to do any head work, P&P, TL-S cams????
Old November 11th, 2008, 10:35 PM   #13
J36 - 6MT LSD
Stheman's Avatar
I have the cams already. As for the head haven't decided what I wanted to do about that. A friend of mine that works at a machine shop said he would do the head work for me for a good price. He offered to assemble the whole motor and do the head work if I painted his car, but I'm not really feeling that deal because he wants a candy paint job witch is a PITA not to mention at least $1000+ in materials.
Old November 12th, 2008, 05:04 AM   #14
NVA-AV6's Avatar
You have PM.
Old November 12th, 2008, 07:22 AM   #15
Carpe Diem
ikethegreat's Avatar
off topic a bit but where in Baltimore do you reside Stheman?
Old November 12th, 2008, 06:00 PM   #16
J36 - 6MT LSD
Stheman's Avatar
Perryhall
Old November 13th, 2008, 07:10 AM   #17
Carpe Diem
damn your pretty close, I'm surprised I haven't seen your car around. I'm in whitemarsh.
Old November 13th, 2008, 05:56 PM   #18
J36 - 6MT LSD
Stheman's Avatar
I'm around don't really go over by the mall to much and I drive my pickup a good bit.
Old November 16th, 2008, 03:47 AM   #19
Aem
widomkr is offline   Reply With Quote Quick reply to this message
