cel fuel injector problem help - Honda Accord Forum : V6 Performance Accord Forums
Old December 5th, 2008, 08:01 PM   #1
hc_416's Avatar
I have a 2003 honda accord v6 6 speed manuel. I change the spark plugs and noticed that they were turned wight. This is obsviely meaning the engine is running lean. I found it on all the cylanders. Then the cel came on. I brought it to the dealer and they told me i might need fuel injectors. This would make no senes for the fact all the fuel injectors failing at once would basice stop the car. so they took a snap shot and sent it to honda. they called me back and said we need to run a fuel line test. This i can belive because lack of fuel pressure would cause a lean condition. Also what set the cel was a misfire. I didn't trust the honda dealers so i read up on the forms and found that the fuel system is a none reture type, and over six grand rpm your fuel mixture leans out. I would like to know has this happned to anyone and can you upgrade the fuel system to pump more fuel.
hc_416 is offline   Reply With Quote Quick reply to this message
Old December 6th, 2008, 02:40 PM   #2
Archangel72's Avatar
I have not read about your issue in particular happening to others. I know that the fuel only feeds too one side in the 7th gens. Paul NVA-AV6 has perfected a way to feed fuel from both sides.
Old December 6th, 2008, 03:16 PM   #3
Bobby Lane Racing
nighthawk04v6's Avatar
a kink in the fuel line can cause problems such as this.
Old December 6th, 2008, 11:29 PM   #4
hc_416's Avatar
i am going to check for a kink but wouldn't that degrade the performance so much that i couldn't drive the car. They said it wasn't a true missfire, and they really had no clue what it was i think they were part shopping, but is it true that the car leans out at above six grand.
Old December 6th, 2008, 11:30 PM   #5
hc_416's Avatar
and thank you for your advice, the funny thing is i ran a bottle of fuel injector cleaner and it seemed to fix the problem so i am at a lose for words.
Old December 6th, 2008, 11:38 PM   #6
hc_416's Avatar
