Installed hi flow cat - Honda Accord Forum : V6 Performance Accord Forums
Old December 28th, 2003, 12:34 AM   #1
Exclamation Installed hi flow cat
I saw a high flow cat on ebay for our car for $50 so i decided to buy it and give it a try. It actually looks really nice, it is stainless and straight through. It even came with new bolts. So finally I decided to put it on today. After finally getting the rusted "old" one off i put it on. It weighs about 5-8 pounds less than stock and like I said earlier looks really nice (I'll post pics soon). My car is otherwise stock (except for removing the intake resonator) so I was unsure if I would feel any difference. Well it actually didn't make any noticable difference in performance or sound but I suspect with other breathing mods it might. On my old civic hb hybrid, replacing the cat with a straight pipe made a HUGE difference, but that car was also heavily modded. Just thought I would share a bit of info on my new mod.
Christopher23 is offline   Reply With Quote Quick reply to this message
Old December 28th, 2003, 01:06 AM   #2
so no sound at all?
03accord03 is offline   Reply With Quote Quick reply to this message
Old December 28th, 2003, 01:15 AM   #3
You said yourself you dropped roughly 8 lbs. That in combination with an aftermarket exhaust will free up flow and drop roughly 10-15 pounds off the car. Less weight never hurt anyone.
mlvswoll is offline   Reply With Quote Quick reply to this message
Old December 28th, 2003, 02:57 AM   #4
you gotta rub to dub!
relentless's Avatar
You should get rid of the 2 resonators in the system after the cat. I had everything replaced with a straight pipe except for the 2 catalysts at the engine block. Once Comptech releases their J pipe, more hp should be released from the restrictive crimped pipes.
If you want sound, definately remove your resonators.
Old December 28th, 2003, 03:43 AM   #5
fonda my honda
Send a message via AIM to tx03coupe
i removed the resonators and it sounds a little better but nothing huge.
tx03coupe is offline   Reply With Quote Quick reply to this message
Old December 28th, 2003, 06:10 AM   #6
i want to just wait for a group buy for the magnaflow exhaust instead of removing the resonator and premuffler. I was originally just gonna do that but i noticed my exhaust is kind of rusted and the pipe is small. Maybe it makes slight difference in sound having the hi flow but not too noticable.
Old March 13th, 2004, 09:46 PM   #7
mishima8's Avatar
Send a message via AIM to mishima8
Any word on pics and an update?
2003 Accord 6 Speed
"sweetness is in the speed"
mishima8 is offline   Reply With Quote Quick reply to this message
Old March 13th, 2004, 11:09 PM   #8
I AM LOST....
brex's Avatar
From what I read before, Accord CAT are NOT very restrictive like other models.. and hence.. does little after being replaced.. non-the-less.. the weight difference can play some role..
I doubt you need any CAT replacements from ebay.. just ask muffler shop to chop up the pipe and put it on.. might weight even less if use good materials..
Old March 14th, 2004, 02:49 AM   #9
How does this affect the ability to pass smog?
Old March 14th, 2004, 03:08 AM   #10
I AM LOST....
brex's Avatar
Accord is SULEV.. and there are still two CATs that we can't touch.. so removing one shouldn't be a prolbem..
Old March 15th, 2004, 07:29 PM   #11
mishima8's Avatar
Sounds good. I will hold off on anything and just do the Borla then. Better safe then sorry.
2003 Accord 6 Speed
