Exhaust Question - Honda Accord Forum : V6 Performance Accord Forums
Old December 13th, 2008, 02:30 PM   #1
Speeddemon8689's Avatar
Exhaust Question
I was reading through previous posts and i couldn't find much on custom exhausts, so i was wondering since i have the 05 V6 sedan, what mufflers would be best to go with and what size pipe would be good to use to keep or gain the most power, without sounding like a fart can? Any help or advice would be great. Thanks.
Speeddemon8689 is offline   Reply With Quote Quick reply to this message
Old December 13th, 2008, 02:36 PM   #2
b20vem1
CG_TypeR's Avatar
my .02 would be to get 2.25 piping with some magnaflows. remove the resonator, get a high flow cat. that should significantly give you a power gain. and with the 2.25 piping you wouldnt lose too much torque i think. anything higher than 2.5 inch piping and you would lose torque.
2.5 inch piping and up should be left for turbo applications.
CG_TypeR is offline   Reply With Quote Quick reply to this message
Old December 13th, 2008, 03:00 PM   #3
I <3 My J30A4
qnzthg89's Avatar
i believe that 2.25 is best in which we do not loose low end torque, and i hear that 2.25 is also best because our cars need the back pressure and 2.5 inch will not do so
Old December 13th, 2008, 03:43 PM   #4
2.25 piping with magnaflow would be ur best bet or apexi ws2
Old December 13th, 2008, 05:33 PM   #5
you could always get the borla cat back system for the coupe. It bolts right up. The rear bumper just needs to get some cutouts put in. I have that on mine but when I did my cutouts I messed up and they are not even. I would have a shop do that part. Also when getting the exhaust get richies j-pipe and test pipe.
Old December 13th, 2008, 06:44 PM   #6
Wheelgap = sleeper mod
mbr311's Avatar
I have intake, Richie's j-pipe, and am about to install his test pipe and the borla catback. That's 2.25" straight through - anyone think I'm going to lose some low-end torque with this setup? Just curious...
Old December 13th, 2008, 06:46 PM   #7
mbr311's Avatar
When you say the rear bumper needs cutouts with the Borla, I presume you don't have the HFP lip kit...right? I hope I don't have to cut my bumper to make the borla fit...(I have the HFP kit all the way around).
Old December 13th, 2008, 08:28 PM   #8
Send a message via AIM to rjp6262
on the coupe, there should be cut outs already made for you if you have a V6. the 03-05 sedans have their exhaust pipes going below the bumper without cut outs.
rjp6262 is offline   Reply With Quote Quick reply to this message
Old December 14th, 2008, 02:57 AM   #9
Sonnick's Avatar
You will not lose torque with 2.25" piping nor 2.5". People have seen gains NA in both hp and torque on the V6 with 3.0 inch piping
Old December 14th, 2008, 12:59 PM   #10
Honda Rookie
pbook4g5's Avatar
No, you won't lose anything noticeable. I have that same setup. Just a word of caution on that Borla... its quiet. I removed the resonator and pre-muffler and now it just sounds awesome.
Old December 14th, 2008, 02:20 PM   #11
mbr311's Avatar
Yea, I've heard vids and it is quiet. I'll have to see how "quiet" it is when I put everything on. I couldn't pass up on the Borla - got it for $415 overnighted w/ only 7k miles on it.
If it is too quiet, I'll probably go the route you did. Out of curiosity, do you notice any droning on the highway when you removed the resonator and pre-muffler? And how much did it cost you to have a shop put in a straight pipe in place of the pre-muffler and resonators? What kind of material did you have the shop use for the straight pipes? I don't want something that will rust out early. Thanks!
Old December 14th, 2008, 05:21 PM   #12
+1 for me. I just bought a Borla exhaust with the same amount of miles for around the same price. haha! cool. I also want to know how much to put in a straight pipe.
99accordJoE is offline   Reply With Quote Quick reply to this message
Old December 14th, 2008, 07:09 PM   #13
Honda Rookie
pbook4g5's Avatar
If you are cruising around 65-70, there is no drone. But as soon as you give it gas to pass someone, there is a tiny bit of drone. It's not bad. It's just not silent, either. You can hear it.
Also, I just traded a shop my old catalytic converter for the work to replace the resonator and pre-muffler. I didn't get it made with stainless because stainless is EXPENSIVE, but it was made with some other heavy duty steel pipe. It will probably rust out in three years or so, lol. I can post pictures next time I get it in the air.
Old January 16th, 2009, 03:27 AM   #14
Is $450 a descent price to pay for 2 magnaflow mufflers and a custom 2.25 catback exhaust?
Old January 16th, 2009, 10:29 AM   #15
On the whole that doesn't sound like too much for a custom catback system but it depends on which mufflers they are selling, what type of metal they are using, and if they are going to mandrel or crush bend it, make sure you get the answer to these questions before you decide on anything.
Mandrel > crush (don't even think about crush bends).
stainless > aluminum (although aluminum is cheaper).
Remember that it will be very loud and possibly raspy with no resonator.
josh6spdv6hfp is offline   Reply With Quote Quick reply to this message
Old January 31st, 2009, 01:50 PM   #16
I asked the guy at the shop that quoted me the $450 for the cat-back with mufflers and he said that there is no place in fresno that does mandrel bends and he said it shouldnt sound too raspy with just the 2 mufflers, but if i wanted the resanator he said that it would be an extra $35. And for muffler choice he basically said that he could order any magnaflow i wanted to get, but im assuming he said the mufflers would be the standard magnaflows, not the expensive ones.
