2 1/2 vs. 2 1/4 - Honda Accord Forum : V6 Performance Accord Forums
Old February 3rd, 2009, 08:12 PM   #1
so JDM my blood's Type R
simdono6's Avatar
2 1/2 vs. 2 1/4
Hey everyone, just wanted to know which is the best size for the exhaust pipe on a v6 6 speed. 2 1/2 or 2 1/4. I will only be putting a single outlet instead of the dual. Thanks for any advice.
simdono6 is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2009, 08:15 PM   #2
✔ Verified Member
otsb708's Avatar
Since your going single I'm going to say 2 1/2"
Old February 3rd, 2009, 08:21 PM   #3
nOrcaL7thgen's Avatar
with dual mufflers, would 2.5 sound ok? Is it deeper/louder? 2.25 seems pretty big when the muffler guy showed me the piping, and 2.5 was just
nOrcaL7thgen is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2009, 08:24 PM   #4
chiefy's Avatar
i think stock is 2 1/4 but 2.5 is pimp go for it
spool or be schooled!
Old February 3rd, 2009, 08:26 PM   #5
✔ Verified Member
otsb708's Avatar
I'm running 2.5" on my duals and I like it.
Old February 3rd, 2009, 08:58 PM   #6
theres no way stock is 2.25. Cause I got 2.25 and its pretty big
Old February 3rd, 2009, 08:59 PM   #7
chiefy's Avatar
maybe 2 then
Old February 3rd, 2009, 09:07 PM   #8
Very Inspired
haiyter's Avatar
Send a message via AIM to haiyter
it is 2.25 from the cat to mid-resonator but then it goes down to around 1.75 after the mid resonator to the dual mufflers
haiyter is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2009, 09:14 PM   #9
hmm it just seemed bigger for some reason. I should have gone with 2.5. Whoever started the whole magnaflow muffler set up was saying 2.25 was better, or someone in that thread said so... Either way, it sounds good
Old February 3rd, 2009, 09:29 PM   #10
resident noob
quick kid 87's Avatar
2.5 all around will probably drone alot inside the cabin at highway speeds.
quick kid 87 is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2009, 09:29 PM   #11
it drones already but i dont have pre muff and reso
Old February 3rd, 2009, 09:36 PM   #12
resident noob
hmm, if i ever get an exhaust for my car, im definitely leaving on a resonator then.
Old February 3rd, 2009, 09:45 PM   #13
yeah you should. I sorta got used to it but I definitely recommend putting pre muffler or resonators on
Old February 3rd, 2009, 09:47 PM   #14
Sonnick's Avatar
2.25 is too small for the V6 6 speed, even for the 4 cyl. 2.5 is okay I wouldn't go any smaller on the V6. There have been great gains with 3.0" piping on both 4 cyl and V6s from P2R Racing. Speak to Sean over there he has some good info.
Old February 3rd, 2009, 09:49 PM   #15
. So upset I didn't go with 2.5. I was mis-informed and have been doing the same to others. Oh well, now I know. I may re-do this and get 2.5.
Old February 3rd, 2009, 09:51 PM   #16
J33 w/TL LSD 6 Speed
05AV6's Avatar
2.5 maybe slightly too big for our cars, My custom exhaust produced far lower tourque numbers (8-10 lbs through most of the RPM range) with 2.5 inch piping, than my GReddy does with 2 1/4, our engines, especially if naturally aspirated, need some backpressure or you can kiss your low-mid end tourque bye bye. Plus bigger piping = more drone.
Old February 3rd, 2009, 09:54 PM   #17
CRV_33's Avatar
so you are suggesting running 2.25" right?
Old February 3rd, 2009, 09:55 PM   #18
I <3 My J30A4
qnzthg89's Avatar
hmmm i was told that 2.25 would be perfect depending on what u want to do i just plan on having some bolt on's. I would believe that 2.25 would be good since greddy uses the size of a 2.25 in there pipeing, and its sounds amazing and does give performance gains, stock pipeing is a 1.75. I personally am doing a custom straight pipe for preference but size wise i will be doing 2.25 because paul "nva-av6" beleives that is the best for my car, others have said that also. With going with a too much of a big pipe we can loose low end tourqe our cars as paul said to me need the back pressure, but then again this is just for my car with an intake crank pulley and j pipe i do not know what else u plan on having with your accord. Hope this helps, and once again i am speaking from what he told me on what my mods are..
Old February 3rd, 2009, 09:56 PM   #19
ok I'm confused. I felt low end torque was gone as well. Changing lanes on the freeway was not as easy as before. Oh well. I'll keep researching
Old February 3rd, 2009, 09:56 PM   #20
I <3 My J30A4
qnzthg89's Avatar
Hey Kev me and you are on the same page lol i say 2.25 as well bro
Old February 3rd, 2009, 10:04 PM   #21
05AV6's Avatar
Based on my experience in every day driving, at the track and dyno results, i would 1000% percent suggest 2.25" piping, your killing tourque with anything above that (I would scan my dyno results to support/prove but I don't have acceess to a scanner at the moment)
Old February 3rd, 2009, 10:17 PM   #22
Sonnick's Avatar
It's not only the size piping but mufflers, bends, resonators, etc. There are dynos on Acurazine of a 3.5L CL with a 3" exhaust that gained a buttload of torque from that size. I'm not saying everyone should go with 3" piping, but if done right it's beneficial.
Greddy Evo2 is 2.25" piping for the Accord V6 Are you sure?
Old February 4th, 2009, 09:44 AM   #23
simdono6's Avatar
well thanks for all the advice it really helped. I am planning on putting piping straight through with no resonators so 2.25 it is. I will also be getting the j pipe and test pipe installed hopefully today. let you guys know how it goes.
Old February 4th, 2009, 09:47 AM   #24
Super Mod
aprevo15's Avatar
can't believe you guys don't like the drone on the freeway. i love it!!!
Old February 4th, 2009, 10:09 AM   #25
simdono6's Avatar
what exactly is drone?? I don't mind my car being a little loud but I just don't want a ricy loud I want I nice tone to it and I am only gona be putting a single outlet not two so idk if 2.5 will be better for that.
Old February 4th, 2009, 10:18 AM   #26
Super Mod
aprevo15's Avatar
i am assuming drone is if you hear your exhaust while in your car. if its something else then nvm. lol.
my magnaflows have a very nice tone inside my car. i really like it alot. sometimes i don't turn the radio on cause i like the sound of my exhaust.
Old February 4th, 2009, 11:22 AM   #27
Archangel72's Avatar
yup, drone is the vibrations you hear while in the cabin. It is usually most noticable at lower rpms.
Old February 4th, 2009, 11:23 AM   #28
✔ Verified Member
otsb708's Avatar
and I have Flowmaster mufflers.
Old February 4th, 2009, 02:15 PM   #29
I <3 My J30A4
qnzthg89's Avatar
Yes i am sure... that is why i plan on using that size but a straight pipe i wont loose any low end torque @ all only gain a little but hey i rather gain a lil then loose a lil
Old February 4th, 2009, 02:23 PM   #30
Crimson Tide
Blackhawk's Avatar
Send a message via AIM to Blackhawk Send a message via Yahoo to Blackhawk
My OBX-R is a gem. Quiet at idle and cruise, and semi-quiet at WOT. Intake over-tops it in volume which is what I like.
Anyway to stay on topic, my exhaust is 2.5" from cat to the y-pipe junction, only one resonator
Blackhawk is offline   Reply With Quote Quick reply to this message
