i think my engine is going to die - Honda Accord Forum : V6 Performance Accord Forums
Old February 21st, 2009, 09:06 PM   #1
in first gear when i start going the oil pressure light is coming on till around 2.5k rpms and there was a cel on but it went off right before i went to go scan it but it was solid till around 3.5k rpms then it would flash until i went bak into the lower rpms then it would go back solid. I had the oil changed around 2k miles ago and they said the coolant was a little low. i dont remember if they said anything about the oil but it never overheats or anything, and i havent noticed any oil on the ground anywhere.Its been running like crap lately too. im going to go check the oil level now. Any ideas? hondas probably going to tell me thats normal or something
airborne_accord is offline   Reply With Quote Quick reply to this message
Old February 21st, 2009, 09:11 PM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
Get a compression check, the oil pressure light means that you probably have a bearing clearence issue when the engine can not maintain proper oil pressure.
Now another interesting thing is the oil change, what oil did they use? I know some oils break down real fast and will also give low oil pressure, just for shiz and giggles, maybe drop the oil you have now and throw in some castrol 10W-30 and see if that gets rid of the oil light.
Now another senario that comes to mind is a cam issue, it can cause both the low oil pressure and lousy engine performance.
Old February 21st, 2009, 09:14 PM   #3
well i just checked the oil, theres really none in it, there is a little at the tip of the dip stick, but i know there was oil in it because after every oil change i always check it because im scared they wont put any in. thanks for the quick response paul. um they used pensoil platnum synthetic 5w20 ive been using the same oil sine around 20k miles
edit: i also cannot find a leak or sign of a leak anywhere, and the cam thing, please elaborate because ive already took the car to honda because of valve train noise and they said it was normal
Old February 21st, 2009, 10:42 PM   #4
update: i ran to walmart and put some mobil 1 in it, but i think shes toast im geting a knock from around cylinder 2( rear bank first cylinder on left) so i guess im at hondas mercy now
Old February 22nd, 2009, 12:14 AM   #5
Bobby Lane Racing
nighthawk04v6's Avatar
wow, sorry for the bad news bud. I hope you get everything fixed at a fair price. You probably could buy a used J30 for fairly cheap. Our engines are known to consume oil, especially if you love vtec + fully synthetic. I've taught myself to always check the dipstip at every fill up, and top it off and still keep up with the every 3k change.
Old February 22nd, 2009, 01:06 AM   #6
whats horrible is the engine only has 39k miles on it
Old February 22nd, 2009, 02:28 AM   #7
SSM_AV6-6
NHB_AV6-6's Avatar
Jesus Christ that's low mileage for an engine to go in one of, if not the most reliable model of car on the road. What I don't understand is, how can it be using oil AND coolant without any discernable burning of either, or mixing of coolant into the oil? That means either some information is inaccurate, or your car is breaking the law of conservation of matter. I highly doubt it's the latter scenario You should keep an eye on the coolant yourself, because A. it's leaking somewhere, and anybody who changes the oil will see evidence of this, or B. a head gasket is blown, and the oil will look like chocolate milk, which is unlikely to miss if you check the oil like you say, or C. it's not using any coolant.
Maybe, worst case scenario, a cylinder wall is cracked, which can explain the coolant disappearing and the car running like poop? Maybe because it's winter you are burning coolant but think the white exhaust is normal? This is unlikely, but who knows, a guy I know drove around his old Protege with a cracked cylinder until it just kicked the bucket and he pulled the head off to unexpectedly find the reason for it's demise.
Do a compression test like NVA-AV6 said, and that could hint at what is wrong.
Old February 22nd, 2009, 06:31 AM   #8
NVA-AV6's Avatar
Sounding more and more like a bad cylinder......
If Honda isn't goint to replace it let me know, I have a J30A4 long block here with only 42K miles on it that I recently pulled for STheMans car when I did his J36 swap, we can drop in yours in a long day, I only need the castings off of it, so even if the piston, bearings are damaged in your engine it would be just fine for my usage.
And thank you for your service....
Old February 22nd, 2009, 10:22 AM   #9
i apreciate all the advice guys, ill see what honda says and ill find a place to get a compression check. ill get back to u on that j30 paul. but if honda dosent replace it then i want to go bigger, mabybe we can go 3.5?
Old February 22nd, 2009, 10:33 AM   #10
NVA-AV6's Avatar
3.5 or 3.6, same cost....
Old February 22nd, 2009, 10:38 AM   #11
Bobby Lane Racing
honda shhould replace it. you're still under warranty
Old February 22nd, 2009, 01:33 PM   #12
ahhhz's Avatar
i thought warranty only lasted 3yr/36,000 miles?
ahhhz is offline   Reply With Quote Quick reply to this message
Old February 22nd, 2009, 01:55 PM   #13
NVA-AV6's Avatar
^Me too, unless you got extended....
Old February 22nd, 2009, 02:01 PM   #14
mine is till 100k miles but i always have bad luck with honda
Old February 22nd, 2009, 03:40 PM   #15
✔ Verified Member
otsb708's Avatar
^ it sounds like you'll be better off with Paul doing your work than going to Honda..I smell a new engine build thread about to start soon!
Old February 22nd, 2009, 03:56 PM   #16
turbo huh?
lol
Old February 22nd, 2009, 06:11 PM   #17
well i have been really excited about pauls new supercharger, lol, but if i end up paying it. its ether a 3.5 or 3.6 one way or another, oh and the honda dealer thats near me loves to rape military, so there probably going to screw me over
Old February 23rd, 2009, 09:20 AM   #18
J36 - 6MT LSD
Stheman's Avatar
3.6 ftw.
Stheman is offline   Reply With Quote Quick reply to this message
Old February 25th, 2009, 07:41 AM   #19
frumaroll
six6's Avatar
if your 100% stock, and have reciepts for all your oilchanges, or if you got your oil changes done at honda, then you should be good to go.
Old February 25th, 2009, 04:05 PM   #20
ok so i took it to honda, and they said there gona do an oil consuption test, basicly they changed my oil and i have to drive it for 1000 miles and bring it back to see how much oil its using, but they couldnt find any leaks so we will see how this goes
Old May 8th, 2009, 01:04 AM   #21
alright guys today was a sad and happy day, honda kept ****ing me around so, i had to let her go, with me in the army i have to have a reliable car at all times, but that dosen't mean i bought a caravan ether, i found a dealership selling a used 350z for a woman, its a 2006 6 speed manual, its silver with the 18 inch silver wheels. Get this 17,900 out the door and it has 17,000 miles on it with clean carfax, and best of all its 300 hp yay!! anyways so things i have lieing around from the accord is a apexi neo with a boomslang harness, which is basicly new because i never used it, because i haden't installed the acura tl camshaft i have sitting in there boxes, with the thrust cover o-rings, so if anyone is in the market for them post here.
Here is the auto trader link if anyone dosent feel like flaming me for buying a z. http://www.autotrader.com/fyc/vdp.js...standard=false
Old May 8th, 2009, 06:29 AM   #22
Not bad, looks pretty good, and not a bad price for only 17k miles, good luck with that baby, you'll have fun, now don't go mod happy... . By the way which unit are you with at Bragg? I used to be in the 50th Sig Bn(for 4 years), before I went to the national guard
AccordArmy2008 is offline   Reply With Quote Quick reply to this message
Old May 8th, 2009, 08:36 AM   #23
Carpe Diem
ikethegreat's Avatar
airborne, send me a PM and let me know how much you want for the cams. I'm interested.
Old May 10th, 2009, 10:57 PM   #24
sent you a pm yesterday, dont know if you got it
Old May 10th, 2009, 11:24 PM   #25
Picture Perfect
Milan's Avatar
Hmmm...never had that issue. I've gone a few hundred miles shy of 6k miles on Motorcraft 5W-20 Synthetic without eating a drop of oil. Car has 98k miles
Old May 10th, 2009, 11:51 PM   #26
Honda Tech
Matt04V6EX's Avatar
Flame you for getting a Z? we should praise you haha. you upped the motor .5L, cut the mileage on your car in half, upped the HP, and got RWD. That's awesome. Congrats to you ... now go out there and learn how to drift hahaha
Old May 10th, 2009, 11:55 PM   #27
was happening with my 2.4 in the dx...but i also hydrolocked it and fried the rings in it....
jax_mugen_si is offline   Reply With Quote Quick reply to this message
Old May 11th, 2009, 07:30 AM   #28
Carpe Diem
Decided to pass, thanks for the PM though. These would probably sell quickly if you post them in the For Sale forum.
