Legend GS calipers on a V6 AUTO? - Honda Accord Forum : V6 Performance Accord Forums
Old March 10th, 2009, 02:09 PM   #1
Envious of J35's
AcCoCuOpReD-04's Avatar
Ive read in some posts about the 94-95 legend GS calipers on a 6MT accord and was wondering if they would work on an AUTO?.. Also, am I limited to only running 10.1" front rotors or can I run the 6MT 10.8's?
IF I do this, I also purchase legend GS pads and rotors? or will the accord rotors work and which ones the 10.1" or 10.8"?
THanks
AcCoCuOpReD-04 is offline   Reply With Quote Quick reply to this message
Old March 10th, 2009, 02:47 PM   #2
chiefy's Avatar
rotors u can leave and get new pad if u need for the accord... when i did the swap on my 6th gen i didnt have to change rotors or pads
spool or be schooled!
Old March 10th, 2009, 03:01 PM   #3
Envious of J35's
Cool, thanks.
Anybody with a 7th gen auto try this? Which rotors did you use?
Old March 12th, 2009, 10:35 PM   #4
if you have a v6: use old rotors and only buy calipers (loaded/semi-loaded)
if you have a 4cyl: get new rotors + calipers (again, loaded/semi-loaded)
suleman is offline   Reply With Quote Quick reply to this message
Old March 13th, 2009, 08:53 AM   #5
Envious of J35's
its a V6, what does loaded/ semi loaded mean?
Old March 13th, 2009, 11:52 AM   #6
please explain load ans semiload
Old March 13th, 2009, 01:34 PM   #7
Tee-Ooh-Double-Dee
Accordian's Avatar
Loaded means it comes with pads, unloaded means without pads.
Old March 13th, 2009, 01:47 PM   #8
cna
cna's Avatar
I have done this mod in the pass its easy just swap calipers and bleed breaks on my v6 03 auto
cna is offline   Reply With Quote Quick reply to this message
Old September 29th, 2009, 01:32 AM   #9
How are the aftermarket brake caliper? I am looking at A1 Cardone caliper since I cannot find the factory Legend GS caliper.
HA_V6 is offline   Reply With Quote Quick reply to this message
Old September 29th, 2009, 04:21 PM   #10
03 AV6 Coupe
hondav6's Avatar
THanks
The 7th gen auto has 10.8 up front and 10.1 in the rear. I think the 6MT has 11.1 in front.
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old October 14th, 2009, 08:28 AM   #11
Czechopino
vasekvi's Avatar
Ok I have stock sized rotors coming in that are slotted and cross drilled. If I find a set of these 94-95 Legend GS calipers they will bolt right up? And which pads should I get? Accord pads or Legend GS pads?
I have a 2003 V6 Auto Sedan
Old October 14th, 2009, 09:18 AM   #12
Czechopino
vasekvi's Avatar
Ok I found some at autozone.
Here is a thread someone wrote up on this conversion
http://www.v6performance.net/forums/...ght=brake+pads
sy272004 states and I quote "Important Note: you have to replaced OEM Right caliper with GS Left caliper for reason to have bleed screw at the top"
In the thread, however, I see that the bleed screw is different on both calipers, indicating that he got both a right and a left caliper.
If anyone can clarify please do because I am ready to go get a set of these calipers at autozone
Drivers Side
http://www.autozone.com/autozone/cat...me=Fenco+Reman
Passenger Side
They are 117.99 each with a core charge of $44.00 for a price minus core of $73.99 each.
Hopefully they wont mind if I give them back Accord cores.....
